Hi All
When i pull the light switch on the guages start to read high. All other times they seem to read fine.
Any suggestions ???
SS Cluster Reading High !
etorana
, Jul 30 2012 08:19 PM
5 replies to this topic
Posted 30 July 2012 - 08:19 PM
Posted 30 July 2012 - 10:04 PM
Bad erf to the cluster
Posted 31 July 2012 - 08:20 AM
Mine does that slightly too, I've never found anything wrong with it and the readings seem to be reliable enough either way, I always assumed that it was something to do with the voltage regulator
Posted 31 July 2012 - 08:44 AM
Could be the reg but more likely either the 0V connection to the cluster is bad or you don't have a 0V strap from the battery to the body or it is not connected well eg through paint. Have a look at the 0V terminal of the battery - does it just have the one big cable to the starter? It should have a smaller one to the body too, and the connection to the body should be through a decent connection.
#5 _CHOPPER_
Posted 31 July 2012 - 02:26 PM
The 5V regulator rarely gives out 5V, it always fluctuates due to the nature of the design. An aftermarket reg is the only way you will get a consistant output.
Posted 02 August 2012 - 06:40 PM
the cluster was recond and works fine all the time except for when i put the lights on. earth strap from the battery is good !!.
