202 "stroker" kits- opinions? +knifedged bmotor cranks
163 replies to this topic
#1 orangeLJ
Posted 03 August 2012 - 04:25 PM
http://www.ebay.com....=item3cc9435d21
Seems a lot of money for what looks like an offset ground crank and a new set of rods with basic cast pistons?
On the same note, does anyone have a reccomendation for knifedged blue/black cranks?
I have someone to do the machine work, but the added cost of having it checked and straightened makes it expensive?
Has anyone had any experiences with particular shops? (I have 3 or 4 cranks, just need the work done)
#2 _sunburst73-xu1_
_sunburst73-xu1_
Posted 03 August 2012 - 04:31 PM
Just go all out and buy this lol.
http://www.ebay.com....=item5649c240d1
#3 76lxhatch
  • 7,205 posts
Posted 03 August 2012 - 04:57 PM
Sounds like the completely custom rods are what costs, I wonder if it makes enough difference to be worthwhile
#4 orangeLJ
Posted 03 August 2012 - 05:05 PM
But I'm wondering if they ARE completely custom? and if so, who makes them? (otherwise they may as well be no name backyard jobbies?)
Also wondering what the rod ratio works out like?
#5 _CraigA_
_CraigA_
Posted 03 August 2012 - 05:39 PM
Chris I use a knife edged blue crank and can give you someone to talk to about getting one done.
I will talk to you about it tomorrow at the drags when I come out for a look.
Straightline Performance is Mick. He has a quick 6cyl powered blue early model ute. FJ or FX - can't recall as I usually only see the back of it :)
#6 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 03 August 2012 - 08:47 PM
arent they some kind of honda rod?
#7 orangeLJ
Posted 03 August 2012 - 08:54 PM
They look similar to the scat honda rods I have in the cupboard, so its possible
#8 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 03 August 2012 - 09:08 PM
how long are the ones you have chris?
#9 orangeLJ
Posted 03 August 2012 - 09:40 PM
Id have to throw a tape over them, our engine building guru gave us the specs a while ago and we ordered the rods, then subsequently the je forgies to suit.
#10 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 03 August 2012 - 09:43 PM
sounds good, whats the rest of the plan??
#11 _Quagmire_
_Quagmire_
Posted 03 August 2012 - 10:06 PM
have you tried prostroke (i think that's the name)
they used to do the 235 kits based on the 221 fraurd crank
#12 _ljxu1torana_
_ljxu1torana_
Posted 03 August 2012 - 10:18 PM
to use a stroker motor you have to use a 186 block only=234cu.
#13 _sunburst73-xu1_
_sunburst73-xu1_
Posted 04 August 2012 - 06:29 AM
I thought them kits were long gone.
I have a 186 block here modified for that crank.
#14 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 04 August 2012 - 08:00 AM
As a sidenote regarding strokers, no one going fast and winning races is using one.
#15 warrenm
warrenm
  • 2,117 posts
  • Car:1972 LJ Torana
Posted 04 August 2012 - 08:32 AM
What he said. :spoton:
In my opinion, you are defeating the purpose of using a counter weighted crank if you machine all the weight out of it, you may as well use a red crank.
#16 _stretchlc_
_stretchlc_
Posted 04 August 2012 - 09:04 AM
The Rods are probably SPOOL Rods I'd guess. Prescisions sell them for about $800 a set!!
#17 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 04 August 2012 - 10:57 AM
i thought they were a tad longer than standard size rods which the spool ones are, arent they?
#18 _nzstato_
_nzstato_
Posted 04 August 2012 - 06:12 PM
Something that has come up just recently over here...
http://www.trademe.c...px?id=498994260
#19 _Bomber Watson_
Posted 04 August 2012 - 06:28 PM
Spool is stock = 5.25"
#20 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 04 August 2012 - 07:53 PM
yeah i think the rods from straightline are 5.7something?
#21 _Bomber Watson_
Posted 04 August 2012 - 07:55 PM
They dont seem to know, the Ebay link says 5.73 and the next line says 5.7.....
Still interesting that such things are available off the shelf though :D
#22 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 04 August 2012 - 09:09 PM
ive got a set in the shed that i think are the same. i will measure them tomorrow :)
#23 warrenm
warrenm
  • 2,117 posts
Posted 05 August 2012 - 08:36 AM
They could be small journal Chev rods!
#24 _stretchlc_
_stretchlc_
Posted 05 August 2012 - 03:23 PM
I just picked up a set of these....too cheap to pass up I suppose!!
http://www.ebay.com....984.m1438.l2649
#25 _Ned Loh_
_Ned Loh_
Posted 06 August 2012 - 07:57 AM
IMHO - Call Ian at Crankshaft Rebuilders in Vic and have a chat.
