Honda or BMW rods I think.
As a sidenote regarding strokers, no one going fast and winning races is using one.
Reliability is the problem......but an offset ground crank isn't as much a problem as a fully stroked motor.
If you can still find a Kit Cullen crank, they are built for the 202 mains. I had him turn mine down for the 186.
I had 3.7L with Toyota pistons and stock rods..........machinist stuffed up and put Fraud piston clearance in and killed it.
With a GOOD main girdle, a properly ground head and block, and all the clearancing, there is no reason you can't make good regular torque if you don't aim for 7000+ rpm every time you go out. Really, if I had the money to do it again, I'd girdle OVER the head, to keep it torqued down. It was 25mm out of true at the end of it........
Grant..
