202 "stroker" kits- opinions? +knifedged bmotor cranks
163 replies to this topic
#151 orangeLJ
Posted 20 August 2012 - 09:59 AM
Wow! I should start more threads! :D
I cant comment on the discussion too much,
BUT!
I do know have a 12 port header plate in CAD format, so will be getting some cut in the near future to make more pipes.
Will confirm a price soon, but around $35-$40 should cover them? 12-14mm mild steel, laser cut.
Can also do 9 porters for about the same I think :)
#152 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 20 August 2012 - 10:33 AM
Put me down for a 9 porter.
I'll take one as soon as you have one.
12mm will do.
Cheers,Craig.
#153 orangeLJ
Posted 20 August 2012 - 11:09 AM
I have a few spare from the last batch-
and fitted-
Edited by orangeLJ, 20 August 2012 - 11:10 AM.
#154 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 20 August 2012 - 11:20 AM
I just remembered my exhaust ports are round... so Ive changed my mind for the moment....sorry mate,they look the goods.
Remember this old chestnut? http://www.gmh-toran...ought-this-186/
Its finally coming out to play.
Edited by wot179, 20 August 2012 - 11:26 AM.
#155 _Ned Loh_
_Ned Loh_
Posted 20 August 2012 - 11:57 AM
G'day Grant ,I 'll try to answer your concerns ,The torsional forces against the cylinder walls actually change with the rod to stroke ratio.(std 202 rod/stroke ratio is 1.61) If you build the old falcon crank 234 stroker with short holden rods the (rod/stroke ratio 1.45) greater rod angles place much more force on the cyl walls and the resulting quick piston acceleration from tdc does not work well with the restricted breathing.
The long rod stroker has a rod to stroke ratio of 1.68 which is better than a std 202 .The lesser rod angles actually place less stress and friction on the cylinder walls than a std stroke/rod 202 engine.Also the piston moves slower from tdc due to the longer rod meaning the intake valve is open further before the piston starts moving quickly down which helps with cylinder filling.Mick
IMHO - the change in forces on the cylinder walls is the least of concerns, I can't get over the .100"+ over bore mentioned earlier in the thread...
Also, just to clarify, we really are talking about (roughly) equal capacity gains for the crank and overbore aren't we?
#156 _Ned Loh_
_Ned Loh_
Posted 20 August 2012 - 12:00 PM
BUT!
put me down for a couple of 12 port plates for when it happens.
#157 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 20 August 2012 - 07:35 PM
I use .035 ,.055 or .075 overbores without any problems in 186 or 202 blocks in n/a applications, I wouldnt use .120" overbore in my engine but some people do in speedway applications without problems.the trick is to sonic test the wall thickness to verify a good casting before deciding bore size.capacity increases roughly 9ci from stroke increase and 7ci from the bore increase,it costs roughly the same to grind the crank to either stroke.
#158 _Ned Loh_
_Ned Loh_
Posted 21 August 2012 - 07:15 AM
Hi Mick,
Agree regarding the importance of sonic testing (for high HP applications). What wall thickness do you like to see (after overbore) on the 202?
#159 _CHOPPER_
_CHOPPER_
Posted 21 August 2012 - 02:10 PM
BUT!
So this will suit the new alloy YT 12 port head? What would be the estimated postage to Melbourne?
#160 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 21 August 2012 - 06:57 PM
Hi Mick,
Probably no less than .120" for n/a engines
#161 orangeLJ
Posted 21 August 2012 - 08:24 PM
Chop, probably $15 max. Will know more in the next week or so flr final cost. Yes they suit the new heads
#162 orangeLJ
Posted 27 August 2012 - 02:01 PM
Can anyone who wants header plates (9 or 12 port) please shoot me an email with the quantity of each as well as your postal address (saves me having to tally it up from various threads)
Once I figure out how many I need to get cut, I'll flick you a final price.
Postage should work out at $10 per person, (express post satchels)
Also, if anyone wants some TD04L turbo flanges (WRX turbos) inlet or exhaust, let me know (getting some of those done for myself too!)
#163 _Bomber Watson_
Posted 27 August 2012 - 06:39 PM
Whats your email? Or do you mean a pm?
#164 orangeLJ
Posted 27 August 2012 - 09:57 PM
Shit, yeah, pm I mean.
