Non GTR + XU1 tag verification thread
LJ Torana tag check GTR or XU1?
272 replies to this topic
#1 _flyiflnghigh9_
_flyiflnghigh9_
Posted 12 August 2012 - 12:15 PM
Hi blokes just in the process of buying a torana, I've hit a problem
The numbers on the car match up with compliance plate (the one without paint trim etc)
But the vin tag doesn't match any numbers with compliance or the paint, trim tag
Are they meant too?
Is it possible for it to be registered without it matching?
Done vic vin check got no hits. needs 17 digits/letters apparently
Vin: 8231jh239493
Body:alj 08130b Matches on car But not on paint and trim tag
Any help is appreciated
#2 _Skapinad_
_Skapinad_
Posted 12 August 2012 - 01:10 PM
Hi Riley the vin wont match number on the other tags. The body number on the inner left guard should match.
Your vin is missing a number, 82311jh239493 it should be..
#3 _RichoX1_
_RichoX1_
Posted 12 August 2012 - 01:43 PM
Hi dude the tag near the wiper motor with chassis should match inner guard
any LC or LJ up-to the i think the 6 7 or 8 month 73 Body and Vin tag don't match
After this pearead the PSN changed, Body number and Vin numbers they do match
#4 _flyiflnghigh9_
_flyiflnghigh9_
Posted 12 August 2012 - 08:59 PM
Thanks Adam and Richo, i was missing a number there and to answer both of you the guard and the tag match numbers.
But another thing is that on the last rego sticker there another Vin... well I beleive it to be a Vin
let's just say forget the Vin issue... will it still be registerable? is what im really getting at..
#5 _Skapinad_
_Skapinad_
Posted 12 August 2012 - 09:01 PM
Yes
#6 _flyiflnghigh9_
_flyiflnghigh9_
Posted 12 August 2012 - 09:12 PM
Thanks adam, looks like you all be seeing alot more of me hopefully :P
#7 _pgb73_
_pgb73_
Posted 06 December 2012 - 05:31 PM
hi all just curious if my vin may be correct for my car.
05/73
blj24240a
vin blj8b11dcl242558j
adr and chassie numbers match.
paint trim tag missing.Attached File  004 (640x480).jpg   340.58K   20 downloads
#8 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 06 December 2012 - 06:06 PM
Hi Mate
No problems there. "S" Model 2 door, completed in Adelaide on 30/5/73 and sold by dealer 442 during July '73. The original 173 engine number was CD334254.
Bazza
#9 _pgb73_
_pgb73_
Posted 06 December 2012 - 06:56 PM
thanks a lot bazza, car is running hl 202 block now,9/g not sure then c/e clock 0400, head yella terra fully worked id number removed is this typhical for y/t, other external markings b124 8 . once again thanks.
#10 _toranatime_
_toranatime_
Posted 06 December 2012 - 07:38 PM
That is a nice looking car you have mate. Do you have any idea what the name of the colour is? Or a paint code? It looks great!
#11 _pgb73_
_pgb73_
Posted 06 December 2012 - 07:47 PM
hate to swear ppg (f) blueprint,goes with the (f) diff.
#12 _toranatime_
_toranatime_
Posted 06 December 2012 - 08:02 PM
Thanks for that, just what i was after :)
#13 _LONA-CK_
_LONA-CK_
Posted 07 December 2012 - 05:48 PM
it looks like cyan met 15332, i have a 9-73 that i am re-storing down the shed
cheers gong
#14 _berito_
_berito_
Posted 26 December 2012 - 08:18 PM
hello all im looking at buying a lj 2 door and just would like someone to tell me what the numbers on the VIN mean number is 8C69LGH281667J. any help would be awsone and would also like to no how many plates its ment to have, been trying to do research myself but there is so many people saying different things.
#15 S pack
  • 15,723 posts
Posted 26 December 2012 - 08:25 PM
8 = General Motors Holden
C = level of luxury, in this case an SL
69 = 4 DOOR SEDAN
L = 202 6cyl engine
C (not G) = model year 1973
H2 = Brisbane (Acacia Ridge assembly plant)
281667 = the PSN production sequence number. The 2 in H2 is also the first digit of the PSN.
J = LJ series
The car should have 3 plates. The long skinny one on the right side of the rad support panel.
BTW that vin you have supplied should not be on a 2 door Torana. Or the car in question was a 4 door converted to a 2 door???
There should be a body ID plate on the left side of the rad support panel.
The body plate has the model number, body number, trim and paint codes and drivetrain options.
There should be a compliance plate on the plenum shelf up behind the master cyl and or brake booster.
The compliance plate has the ADR numbers, the month and year of manufacture and chassis number which must match the chassis number stamped in the left front wheelhouse panel.
The compliance plate will also state if the car is a 2 dr or 4dr sedan.
Edited by S pack, 26 December 2012 - 08:35 PM.
#16 Dr Terry
Dr Terry
  • 3,325 posts
Posted 26 December 2012 - 08:26 PM
That VIN belongs to a 1973 LJ SL 202 4-door sedan. I think that the 6th digit should be a C, not a G.
The car should have 3 plates, the skinny VIN plate, the body ID plate & the ADR compliance plate.
Dr Terry
#17 Ice
  • 15,202 posts
Posted 26 December 2012 - 08:27 PM
And should have 3 complaince plates
#18 _berito_
_berito_
Posted 26 December 2012 - 08:59 PM
where is the best place to do vin number checks iv herd there is ment to be a better 1 than revschech is this true?
#19 _berito_
_berito_
Posted 26 December 2012 - 09:40 PM
the compliance plate says that it it a LJ Torana Sedan 2 door
#20 S pack
  • 15,723 posts
Posted 26 December 2012 - 10:49 PM
If the chassis number on the compliance plate matches with the number stamped in the left wheel house panel then that is the most important thing for registration.
Forget about the skinny VIN tag, it doesn't belong to that car and should be removed.
Also, the Model number on the Body ID Plate should be 82311, if it is 82569 then that plate is also from the 4 dr SL.
Edited by S pack, 26 December 2012 - 10:52 PM.
#21 _berito_
_berito_
Posted 27 December 2012 - 12:23 PM
if i can upload the pics the bloke has sent me ill post them so you guys can have a look at what he has sent me
#22 _berito_
_berito_
Posted 27 December 2012 - 12:37 PM
hear is a couple pictures trying to get the other to download but says file to big
#23 _berito_
_berito_
Posted 27 December 2012 - 12:40 PM
hear is the othe pic iv been sent
#24 S pack
  • 15,723 posts
Posted 27 December 2012 - 05:06 PM
The rivets in the VIN tag look to be original so I'm suspecting this 10/73 LJ 'S' 2dr has been repaired using at least the radiator support panel from a 4dr SL, possibly other panels like nose cone, fenders and bonnet from the 4dr SL were also used but that is pure conjecture.
Seeing as the person who repaired the car was obviously too lazy to remove the 4dr VIN tag and install the correct 2dr VIN tag I will assume the Body ID plate (if fitted) currently on the radiator support panel is also from the 4dr SL.
The good news is the Compliance plate and chassis number correlate.
Edited by S pack, 27 December 2012 - 05:06 PM.
#25 _rat64eh_
_rat64eh_
Posted 13 January 2013 - 12:32 PM
hi all
can anyone give me any info on the following please?
LC05906B from the large tag, and body stamp is LC21416A
there is no little tag.
cheers phil
