Non GTR + XU1 tag verification thread
LJ Torana tag check GTR or XU1?
272 replies to this topic
#176 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 17 April 2016 - 02:50 PM
Thanks for the detailed info Bazza. It is a P, does the P indicate SL trim level as dattoman said?
No chassis number yet, the guy is away and not listed with VicRoads but engine number matches, it's registered and it all seems good.
Nick
Hi
Yes, 48P (Sandalwood) is correct for the model 82569 (SL 4 door 6 cylinder).
Bazza
#177 _NickP_
_NickP_
Posted 18 April 2016 - 04:34 PM
Thanks again Bazza, I'm hoping to pick it up next week :)
#178 _999Juz_
_999Juz_
Posted 18 April 2016 - 05:04 PM
Hi I'd love a bit of help with some codes. I couldn't operate the VIN lookup database, and my fat fingers are struggling to pick out one key at a time.
If anyone can help these are off a car I have paid the deposit on. I just want to know if there are any red flags...
It's an LJ SL 202 M21 308 banjo
LJ82569
trim (currently black) 1865-50R
paint (currently green) 567-15332
eng LD1 rraxle G95
body stamp matches compliance plate
08/73
8c69dcl250504
eng#QM828492
TIA
#179 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 19 April 2016 - 08:18 PM
Hi 999Juz
That VIN comes up as a 6 cylinder 4 door SL that was completed in Adelaide on 17/8/73 and sold by Alan Capp Pty Ltd of Wangaratta Vic during Nov '73. The VIN disc records that the car left the factory with a 173 engine (number not recorded) and a 3.36:1 ratio limited slip differential. These items appear on your Body Identification tag as LD1 and G95 respectively. The car also had a 3 speed manual transmission and front wheel disc brakes.
The original colour was Cyan Metallic and the trim black vinyl.
The engine number that you have quoted is not original to the car but appears to a low compression 202 from a HQ/HJ
Bazza
#180 _Mell27_
_Mell27_
Posted 06 July 2016 - 11:58 AM
Hoping someone can help, I'm wondering if these tags are matching and what info they provide. Your help will be greatly appreciated.
Long skinny tag 82311JH237448
Big tag 1,2,3,4,5A,7,8,10A,11,12,14,15,20,22,25,26
6/72 ALJ 07044B
Other tag Model LJ82311M
Body no. 06960B
Trim 1847 41E
Paint 568 13889
Thanks again in advance
#181 _Liamzyy27_
_Liamzyy27_
Posted 02 August 2016 - 09:37 PM
After some info on LC...
BODY ID: MODEL LC82569
BODY 2245-A
TRIM 1179 42R
PAINT 567-10974
LONG TAG: 82569C J218427
FIREWALL TAG: LC11279A
Thanks in advance.
#182 _Blaser_
_Blaser_
Posted 25 May 2017 - 10:05 PM
Hi All.
Just wondering if someone can give me some info on my LJ 2 door 2-74. Vin No: 8B11DDL262490J
Also number on Aus compliance plate is BLJ 35077A. Body No: 99596-A. Engine:LD1
I'd assume it's one of the last LJ's built being Feb '74
Thanks in advance.
John
#183 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 25 May 2017 - 11:22 PM
Hi John
One of the last 80 built at Adelaide. S Model 2 door completed on 9/2/74 and sold by R W E Frazer, Corowa NSW in March '74. There is no engine number listed on the disc but the original would be in the CD43xxxx to CD46xxxx range. It has a 3 speed manual transmission and a disc brake front end. The disc also indicates a 3.36:1 limited slip diff but that could be an error because half the cars on the page also have an LSD recorded against them. It is odd that the Chassis Number does not commence with CLJ as I have details of 2 Brisbane cars built in 1974 both of which have "CLJ prefix" Chassis Numbers.
Bazza
#184 _tuffgtr_
_tuffgtr_
Posted 26 May 2017 - 12:11 AM
Can someone please tell me any info on the Torana with these tags
ADR Tag: LC Torana 12/71 ALC39907A
Body Tag:  Model: LC82311
                   Body No:6239-A
                   Trim: 1823-48F
                    Paint: 568-13137
VIN Tag: 82311CH170357
Not sure if the VIN tag is correct for this car. Could you please check this also.
#185 _Blaser_
_Blaser_
Posted 26 May 2017 - 07:04 AM
Hi John
Bazza
Thanks Bazza, great info.
Interestingly working at a large Holden dealership since 1980 as a spray painter this car is Chrome yellow which I'd assume there would be very few of and the block No is prefix QL which I am lead to believe that the plants use to mix match at the end of model production as the ran out of parts.
John.
#186 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 26 May 2017 - 08:58 AM
Hi John
I have never seen or heard of an LJ with a 1974 colour from the factory, but if that is what the Body Identification tag says then it must be correct. Equally, I have never seen or heard of a QL prefix engine being factory fitted to an LJ. What is the engine number that you have?
Bazza
Edited by Bazza, 26 May 2017 - 09:10 AM.
#187 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 26 May 2017 - 09:10 AM
tuffgtr - Welcome to the GMH Torana forums.
Sorry to say that you have mixed tags there. The VIN is from a Brisbane built S Model 2 door completed Sept 1970, and the other tags are from an Adelaide built S Model 2 door from late December 1971. Can you see anything scribed onto the back of the ADR tag (that's the one wiith ALC39907A). The Body Identification tag describes an "S Model 2 door, Olive Green with Sandalwood trim.
Bazza
#188 _Blaser_
_Blaser_
Posted 26 May 2017 - 05:05 PM
Hi John
Bazza
Hi Bazza.
Yes the body tag is Chrome yellow 568-15893. I'm in the process of returning it to its original colour after a horrendous paint job in tangerine. Hopefully I'll post some pictures when I work out how. Motor is at mechanics so I'll get you the engine no when I'm there next.
Thanks again
John.
#189 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 26 May 2017 - 05:45 PM
Hi Blaser
Very interesting. I have since been advised of a couple more '74 LJs with 1974 colours. One colour chart that I have found states "Effective January 1974" - so I guess that explains it. I have also been made aware of more "CLJ" prefix Chassis Numbers. Always learning.
Bazza
#190 _Blaser_
_Blaser_
Posted 26 May 2017 - 06:32 PM
Hi Blaser
Bazza
I've also learnt how to post photos so hope this helps
JohnAttached File  IMG_1054.JPG   129.46K   5 downloadsAttached File  IMG_1056.JPG   272.47K   4 downloads
#191 _tuffgtr_
_tuffgtr_
Posted 26 May 2017 - 08:09 PM
Bazza
Thanks Bazza. I will see if I can chase up the correct VIN tag for you. Off hand do you know if i have enough to verify the car is not stolen/owes funds/written off?  Also can the car be registered in NSW without the third tag?
#192 _Ivan_
_Ivan_
Posted 21 June 2017 - 05:57 PM
Hello, can i find out about my tags please.
Car was bought in 1991 by me and was a dark green met with white roof, auto, drum all round cant remember eng size.
Small plate
82311C  H6 26251
Compliance plate
ADR 4, 5A, 7
March 1970
LC 07061B
Body Identification Plate
Model -        LC82311
Body -           No. 22745B         Brisbane built body Number are build number
Trim -            1192       41E  (41E = Gold trim)
Paint -           568         11401
Top –
Front Left guard number  - 07061B
#193 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 21 June 2017 - 06:49 PM
Hi Ivan
Nothing wrong there. - S Model completed in Sydney on 17/2/70 and sold by Fair Deal Car Sales P/L, 65 Church St, Parramatta  NSW the same month. There is no engine number recorded.
161 engine, Trimatic auto transmission, drum brakes and a 2.78:1 conventional differential. All the tag numbers line up datewise.
Bazza
#194 _Albert52_
_Albert52_
Posted 21 June 2017 - 08:01 PM
MR BAZZA Could it have had a 138 motor
#195 _Ivan_
_Ivan_
Posted 21 June 2017 - 09:11 PM
Thanks Bazza, awesome to hear, really love your work, it did have a 161 from memory, so really helps put it all together.
Ivan
Can I ask Bazza how it was complinced in March yet sold in Febuary. as I was told not possible.
#196 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 21 June 2017 - 09:29 PM
Ivan
I don't really have an answer but I have seen that happen a few times. More than likely an input error on the part of the operator or the tag stamped wrong.
Edited by Bazza, 21 June 2017 - 09:35 PM.
#197 _Ivan_
_Ivan_
Posted 22 June 2017 - 06:33 AM
Thanks again Bazza. Good info and some history if the car
#198 _Ivan_
_Ivan_
Posted 22 June 2017 - 07:14 AM
Any chance you know where the 2 tags go, skinny one and the body id one, i know compliance goes near wiper motor.
#199 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 22 June 2017 - 09:06 AM
For an LC, it depends on the assembly plant, month and year of the build.
Bazza
#200 _Puds22_
_Puds22_
Posted 10 August 2017 - 07:36 PM
Hi
looking at a LC 4 door Torana and it has these tags just wondering if anyone can tell me anything about the vehicle. I'm going to check for the body stamp tomorrow
