GMH Starfire 1.9L 4cyl interest?
188 replies to this topic
#26 rodomo
  • 18,063 posts
Posted 19 August 2012 - 08:42 PM
I concede and appologise to the good Dr for my ignorance.
As I said, I have owned 2 VH Commodores with starfire engines and both had what appeared to be factory electronic ignition.
I also bought my eldest daughter a VC SLE with starfire and that was points ign.
Yesterday, I googled the Bosch site and there is no listing for the BIM-024 module for VH starfire, only the number for the coil, which is not an electronic ignition coil number either.
So...........................does the Sigma dissy bolt straight in without mods? :dontknow:
#27 _barana_
_barana_
Posted 19 August 2012 - 08:48 PM
well, ihave a crank angle sensor/dizzy out of a fuel injected 2.6 astron, unfortunately no holden 6/starfire to find out.
#28 _Sunbird_
_Sunbird_
Posted 19 August 2012 - 09:36 PM
I'm interested in your project. I've got a starfire and was tossing up whether to ditch it for something else, maybe a turbo diesel out of a hiace. I think i'll probably keep it for now. Be interested in what you come up with.
#29 _barana_
_barana_
Posted 22 August 2012 - 10:55 PM
B.W. gave me a good idea recently, a twincam barra falcon head cut down, 4 valves per cyl and a modern looking tappet cover ;) it would flow rather well too! but ill leave that one to the powercrazed mob ;) love to see it tho.
ot musings - - hmmm a turbo diesel 2.5 astron with the balance shafts removed would be cool in a torrie or a ld30 nissan turbo deisel 6 would be interesting
#30 hanra
  • 11,033 posts
Posted 23 August 2012 - 06:22 AM
What is the P/N on the stock dizzy fitted?
#31 _barana_
_barana_
Posted 02 September 2012 - 08:40 AM
just an update to my original post, as i can no longer edit it (time based editing i think?)
I have a proj in mind.....
yt stage III head cut down
roller rockers for less drag losses
roller lifters for less drag
vk maybe inj manifold
vs(sequential) inj computer reprogrammed to run a starfire - 2 coil packs of the v6 will do away with the losses of a dizzy.
reprogrammed with the knowledge of the good folks of delcohacking.net
thinner rings - with accompanying pistons for less drag
192 pistons to bring it to a 2.1L
rewelded and properly balanced 202 crank. capacity ? 2.3L
and secret weapon no 1!
#32 orangeLJ
Posted 03 September 2012 - 12:45 PM
would definitely be an interesting project.
budget?
#33 _CHOPPER_
_CHOPPER_
Posted 03 September 2012 - 04:34 PM
You get 15 mins to edit posts, after that you need to contact a mod/admin if it's really important.
#34 _vk4akp_
_vk4akp_
Posted 05 September 2012 - 12:17 AM
I wonder what would have to be done to make a Starfire run on E85 ???
#35 _CHOPPER_
_CHOPPER_
Posted 05 September 2012 - 02:02 PM
E85 will double the power of the 1.9 litre starfire.
Unfortunantly, two times nothing is still nothing.
#36 _Inj gtr202_
_Inj gtr202_
Posted 06 September 2012 - 07:31 AM
:iagree:
but who am I to judge.... I play with 202's.. :P
#37 orangeLJ
Posted 06 September 2012 - 10:25 AM
to make it run on e85... nothing.
To make E85 worthwhile? lots.
Compression for starters as that is the main benefit of running E85 (or boost... either way)
Then, to feed your new found power, bigger fuel lines (in E85 tolerant lines, no standard rubber) bigger pump and bigger injectors/jets
You'd also have to look at the suitability of other items in the fuel system (carby gaskets, fuel filters, tanks etc etc.
#38 _vk4akp_
_vk4akp_
Posted 11 September 2012 - 02:10 AM
What about if you used a EFI fuel pump off a VK Commodore. And a Megasquirt kit computer with an old school Falcon injector body that bolts on like a carby? Would the computer adjust via the sensors?
And what's the story with compression / turbo etc. Explane that more please?
#39 _barana_
_barana_
Posted 12 September 2012 - 10:39 PM
the accuracy that a throttlebody injection system provides is the same as a varijet. its pointless(ok MAYBE finer fuel spray). the flexability , power and economy is in multipoint fuel injection.
#40 orangeLJ
Posted 13 September 2012 - 03:02 PM
Do some googling.
The main benefit of E85 is its resitance to detonation (pinging)
To run a standard compression engine on the stuff would be near pointless, you'd make just as much power as PULP, E85 is not instant horsepower, you can't just fill the tank and expect it to be a rocket.
The reason people make more power with E85 is the ability to feed more boost into the thing or run higher compression. (or both!)
Its as close as you will get to street-legal methanol.
#41 hanra
  • 11,033 posts
Posted 24 September 2012 - 10:16 AM
I came across some silly hill billy doing this?
Edited by hanra, 24 September 2012 - 10:16 AM.
#42 _barana_
_barana_
Posted 26 September 2012 - 06:54 PM
niiiice! cept for the painted ports.
#43 _vk4akp_
_vk4akp_
Posted 25 January 2013 - 12:55 AM
Nice! Can you send me the link where you found that please? I'd like to grab any photo's and info. .-.-.
#44 hanra
  • 11,033 posts
Posted 25 January 2013 - 06:46 AM
No link. A hillbilly sent it to me after he took the photo on his phone.
#45 orangeLJ
Posted 25 January 2013 - 08:09 AM
looks too neat to be Bombers shed? lol
#46 hanra
  • 11,033 posts
Posted 25 January 2013 - 09:51 AM
Bomber's not up in the Hills with the 2 country folk.
#47 _vk4akp_
_vk4akp_
Posted 30 January 2013 - 12:13 AM
Other then the Roller Rockers, do you know anymore about the rebuild or it's intended future?
#48 _Matvex_
_Matvex_
Posted 30 January 2013 - 06:28 AM
I had a a15 (1.5l) Datsun 120y and I put a aftermarket sidedraght 40mm weber and extractors and it went like hell! But one day on the way home I heard a noise and after a inspection the rockers undid themselves and were sitting loose under the rocker cover.
But it was not only a performance improvement it sounded cool to as you could hear the weber sucking in air.
Maybe a weber or two on a star fire?
#49 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 30 January 2013 - 09:24 AM
The hillbillies starfire
The head had ports cleaned up,v6 com valvles had heads trimmed to stock diamater
3 angle seats,new guides,top of guides cut to suit teflon stem seals,spacers made for
valves seats to acheive 135lb on the seat.
The block had 40th off the deck,rods balanced to roughly a tenth of a gram at both ends.
crank balanced,chrome top ring,10.5 cr,7.9 dcr.
This thing was going to be fitted with twin 40dcoe carbs, headers into a 21/2 pipe so cam ended up 289ex,292in(adv)
litf 329in,315ex. on 1.5:1 erson rollers.(they are lighter than yella terra)
As far as the future of it,who knows,starfires by general concesus are bad but this was going
to fitted into a uc which probably makes things worse.
It will probably just sit for now,was all just a waste of time. :P
cheers.....one the hillbillies.
#50 _vk4akp_
_vk4akp_
Posted 05 February 2013 - 09:05 PM
Wow a lot of work for it to just sit and go to waste.
"starfires by general concesus are bad..." Got me beat why some people claim this?
I've had nothing but the best experiences with every one I've ever owned. And I've owned a few.
In what area's do you consider them bad?
