Is this oil pump i have aftermarket??? Or perhaps high volume?
Posted 21 August 2012 - 07:53 PM
Posted 21 August 2012 - 08:04 PM
Posted 21 August 2012 - 08:05 PM
Posted 21 August 2012 - 08:16 PM
Posted 21 August 2012 - 08:23 PM
bradThanks datto. Yeah it seems to be cast. Solves that one!!
Posted 21 August 2012 - 08:31 PM
Posted 21 August 2012 - 08:39 PM
now all i have to do is sort out a tricky fuel gauge!
i have had to earth the sender unit to the fuel pipe to get any reading
but i don't believe it is accurate still
would hate to run out of fuel and have to leave the car on the side of the road
any hint's?????
cheers davemc
Posted 21 August 2012 - 09:39 PM
Posted 21 August 2012 - 09:53 PM
Posted 21 August 2012 - 09:56 PM
Posted 21 August 2012 - 10:21 PM
Posted 21 August 2012 - 10:56 PM
hey davemc , my sender was not reading correct so i pulled it out from the tank checked the up and down movement against the reading on the gauge , i ended up bending the arm slightly a little at a time to get it to read empty with only a few litres in the tank ....
Posted 21 August 2012 - 11:03 PM
Posted 21 August 2012 - 11:06 PM
Posted 21 August 2012 - 11:18 PM
Edited by S.S., 21 August 2012 - 11:20 PM.
Posted 21 August 2012 - 11:20 PM
what's 4 cubes between friends?Didnt VT's have a 304?
Edited by Quagmire, 21 August 2012 - 11:22 PM.
Posted 22 August 2012 - 12:24 AM
I've soldered a wire onto the fuel sender body housing assy and have it grounded to the body of the car because my fuel tank and straps are all 2 pac'd. The sender should read from about 12ohms to 75ohms I think...? I've got a short video of me bench testing mine somewhere I'll dig it up. But have no idea how accurate it is in the tank as I've not yet applied power or put fuel in it.
Posted 22 August 2012 - 12:57 AM
Righteo. I'll have a look over it for any markings.
The pump would be of a fair age id say, fitted when ever the motor had its rebuild with REPCO pistons.
In saying that though, when I had it off, internally it all appeared very good and measured up to spec.
Edited by ls2lxhatch, 22 August 2012 - 12:58 AM.
Posted 22 August 2012 - 06:58 AM
Posted 22 August 2012 - 07:55 AM
Posted 22 August 2012 - 07:56 AM
No, I mean VT. My VT has the exact same pump as my A9X, and it's exactly the same as the NOS one I have.
Posted 22 August 2012 - 08:10 AM
What I meant was the last of the Holden V8's were in VSIII not VT. Last sedans were VSIII Statesman and Caprice and the last Commodores were VSIII utes.
Posted 22 August 2012 - 08:18 AM
Posted 22 August 2012 - 08:45 AM
I don't know what the last production dates were for VS111 and VT series one, but either way it's a matter of wording. I didn't say the VT was the last car to be fitted with the Holden block I said, "The genuine Holden ones never changed, right up to the last Holden engine VT". I was under the impression the HSV XU8 was built to celebrate the last of the Holden engines, but the series 3 VS could well be the last of the Holden V8's considering Holden didn't update the ute or Statesman till the release of the VX.
Edited by yel327, 22 August 2012 - 08:49 AM.
Posted 22 August 2012 - 08:59 AM
