308 oil pump
63 replies to this topic
#51 dattoman
  • 16,487 posts
Posted 26 August 2012 - 11:54 PM
They don't , not the originals anyway.
Been down that path years ago :)
Yes we did... but luckily found what you needed at the right price
Yes I did bid on those others... but since I don't actually need them... I didn't go very high
#52 76lxhatch
  • 7,205 posts
Posted 27 August 2012 - 06:58 AM
Standard gears won't go in the HV housing either, same difference in width/length
#53 hanra
  • 10,958 posts
Posted 15 September 2012 - 06:32 AM
Ended up buying a JP standard replacement. I know it's not the correct one, but Im a little concerned with using an old 2nd hand item which is so critical for the engine.
Also bought some NOS oil pump mount bolts as mine are to long.
The instructions on this specifically state not to pack the pump with grease (I was gunna use vasolene) but to prime through the oil sender hole.
#54 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 15 September 2012 - 08:23 AM
Dont use old second hand shit aluminium oil pump even if they have been recoed,they are rubbish.
#55 76lxhatch
  • 7,205 posts
Posted 15 September 2012 - 08:43 AM
There's nothing wrong with the original pumps and they are a rebuildable item, but like anything else it has to be done properly and a lot aren't. Use a hand pump or something to prime that will supply pressure as you can't just squirt oil into the sender hole - once primed with oil it will crank up fine, no need for messy vasolene
#56 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 16 September 2012 - 09:37 AM
Good info right there !
I can't remember the last time I purchased a new pump, I always reco the stockers.
JMHO
#57 _Got1UR1_
_Got1UR1_
Posted 16 September 2012 - 11:37 AM
FYI guys, NOS oil pumps are available from, Engine Parts 24 Seven Pty Ltd. PO Box 2588, Regency Park. Adelaide. P# 92061949. Bought 1 last week, $395 delivered to my door. Not cheap but correct if you need it.
#58 hanra
  • 10,958 posts
Posted 16 September 2012 - 12:04 PM
Yeah $395 is stretching the budget in this case.
This is as good NOS I can do...
#59 _Mint_
_Mint_
Posted 16 September 2012 - 03:55 PM
looks good Brad did you paint the housing?
#60 hanra
  • 10,958 posts
Posted 16 September 2012 - 03:58 PM
No mate. Not painted. Just cast finish.
#61 _Mint_
_Mint_
Posted 16 September 2012 - 04:13 PM
it will go rusty then
#62 hanra
  • 10,958 posts
Posted 16 September 2012 - 05:07 PM
Excellent......
I'll give it a good spray with ACF-50 then. Thanks for pointing that out.
#63 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 16 September 2012 - 06:48 PM
They are ally, they just dull off.
#64 _Mint_
_Mint_
Posted 16 September 2012 - 07:15 PM
not the JP ones like Brad bought they are cast iron the OE Holden ones are aluminium
Edited by S.S., 16 September 2012 - 07:15 PM.
