DELCO REMY INBUILT COIL HOLDEN 202 DISTRIBUTOR?
_stretchlc_
Posted 22 August 2012 - 05:23 PM
I can upload a few pics if anyone needs to eyeball it.
Posted 22 August 2012 - 05:45 PM
_stretchlc_
Posted 22 August 2012 - 06:41 PM
Posted 22 August 2012 - 07:02 PM
_stretchlc_
Posted 23 August 2012 - 12:45 PM
Posted 23 August 2012 - 04:15 PM
Posted 23 August 2012 - 05:15 PM
_stretchlc_
Posted 23 August 2012 - 05:27 PM
_glennhailstone_
Posted 16 September 2014 - 10:21 AM
I've been playing around with one of these for a while now, with my 186. Standby for more info.
_glennhailstone_
Posted 16 September 2014 - 10:48 AM
Hey Stinga, Did you have much trouble with trying to get your delco dissy going. Mine has been a nightmare.
I notice your coil nose is above where the wires come out of the dissy body, and not above the vac advance as directed by other members.
I can't get mine to run when the stator and reluctor teeth line up and the rotor is in line with the #1 plug terminal.
Could you please add some photos of where your reluctor and stator teeth are when your rotor is pointing to the #1 terminal.
I will be interested to see how you got your one to go, and any problems you had along the way.
Thanks, Glenn
_glennhailstone_
Posted 16 September 2014 - 10:57 AM
When rotor pointing at #1 plug terminal
Edited by glennhailstone, 16 September 2014 - 10:57 AM.
Posted 16 September 2014 - 06:06 PM
If that is the position of the reluctor tooth in regard to pick up coil that is supposed to be in phase with the rotor on the mark on dizzy then it needs "re-phasing".
_glennhailstone_
Posted 16 September 2014 - 06:19 PM
Any chance of getting that in English?
Posted 16 September 2014 - 06:33 PM
Like oldjohnno said,the "tooth" of the reluctor (inside cog) should line up with the outer "tooth" on the pick up coil (outside cog) while the rotor button lines up with the #1 post on the inside of dizzy cap that leads to the #1 plug lead.If they don't line up the pick up coil gets the wrong trigger point on when to send the spark.
Edited by EunUCh, 16 September 2014 - 06:34 PM.
