Started on the other side.
IMGP2989_resize.JPG 135.79K
6 downloads
IMGP2988_resize.JPG 127.21K
5 downloads
Edited by turbo76lx, 21 October 2017 - 03:10 PM.
Posted 08 January 2016 - 07:19 PM
6 downloads
5 downloads
Posted 08 January 2016 - 08:25 PM
Geez mate that first pic is bit rough!!!
Balancing the wheel on the quality control inpector's head like that....lol
Wish I had your skills.Top work.
Posted 08 January 2016 - 08:36 PM
Hahaha, wish I could train my dog to balance wheels in position for me.
Posted 08 January 2016 - 09:01 PM
Posted 08 January 2016 - 09:53 PM
gee some people are talented!
Posted 10 January 2016 - 12:06 PM
Got the other side flares done and put it on the ground to see how it looks.
This is with no springs sitting on the bump stops to check clearances.
IMGP3005_resize.JPG 119.05K
5 downloads
IMGP3003_resize.JPG 119.69K
5 downloads
This is at standard ride height, will probably lower it about 20mm.
IMGP3000_resize.JPG 137.42K
6 downloads
IMGP2999_resize.JPG 113.48K
4 downloads
Edited by turbo76lx, 21 October 2017 - 03:13 PM.
Posted 10 January 2016 - 12:35 PM
Posted 10 January 2016 - 12:51 PM
Posted 10 January 2016 - 06:46 PM
Posted 10 January 2016 - 09:54 PM
Soo much awesome in this build, everything from the stance to the engineering is insanely good.
Posted 11 January 2016 - 07:04 PM
Posted 11 January 2016 - 10:42 PM
Posted 12 January 2016 - 09:16 AM
Posted 13 January 2016 - 06:57 AM
Posted 13 January 2016 - 09:25 PM
Sittin pretty
Edited by Bart, 13 January 2016 - 09:25 PM.
Posted 15 January 2016 - 09:58 AM
Impressive work, love the engineering!
Posted 16 January 2016 - 07:56 PM
Another little job done, remade the front brake hard lines from the brembos the the brake line mount.
IMGP3012_resize.jpg 132.72K
5 downloads
IMGP3013_resize.JPG 176.19K
5 downloads
Edited by turbo76lx, 21 October 2017 - 03:15 PM.
Posted 17 January 2016 - 06:57 PM
Decided to try and for Currie Enterprises Johnny Joints to the front caster rods since the rubbers are flogged out.
I think these will be ok considering they are used in the suspension of 3 ton rock crawlers and the engineer is happy with them because of the urethane bush.
It's a pity it wasn't 0.4mm bigger in diameter then it could have been pressed in and not have to weld it.
IMGP3014_resize.JPG 165.23K
5 downloads
IMGP3015_resize.JPG 168.8K
5 downloads
Tapped a new thread for the grease nipple through the castor rod and lined it up with the grease nipple hole in the johnny joint then welded it on both sides.
IMGP3016_resize.JPG 182.31K
5 downloads
Also dropped the motor, turbo and dump pipe back in to see if the brake line will clear and be far enough away from the exhaust.
IMGP3020_resize.JPG 157.93K
3 downloads
Edited by turbo76lx, 21 October 2017 - 03:17 PM.
Posted 17 January 2016 - 08:10 PM
Nice
Posted 17 January 2016 - 10:05 PM
Posted 17 January 2016 - 10:15 PM
I agree, I love LJ 2 doors but the Hatch with flares, fat tires, lowered, gets meThe stance and colour when it's sitting on the bump stops I magic. Hatchbacks have to be the sexiest toranas around
Posted 18 January 2016 - 12:42 AM
Just read this thread. WOW congrats on taking this on. Thats one very unique hatchback and I wished I had such skills and money to do something this good.
Cameron
Posted 19 January 2016 - 02:46 PM
As always, this is awesome!
Edited by mick74lh, 19 January 2016 - 02:46 PM.
Posted 25 January 2016 - 08:34 PM
Started filling in the gap from cutting the body to clear the tyres, because I've had to cut so high I had to weld the two inner panels together first.
The fun of welding through tar, body deadener and paint.
IMGP3035_resize.JPG 115.17K
7 downloads
Little bit of rust in the lower 1/4 so easier to just cut the whole section out as this is covered by the flare.
IMGP3037_resize.JPG 136.81K
5 downloads
One side done.
IMGP3039_resize.jpg 147.23K
6 downloads
Edited by turbo76lx, 21 October 2017 - 03:18 PM.
Posted 25 January 2016 - 08:41 PM
General →
General Discussion →
Factory 202 Turbo option and id plateStarted by _Holden red sponge_ , 06 Dec 2018 ![]() |
Holden Tech →
Engine →
Phenomenal 202 buildStarted by _RedKobra_ , 10 Jan 2016 ![]() |
Holden Tech →
Engine →
Poll
ENGINESStarted by N/A-PWR , 04 Sep 2015 ![]() |
Holden Tech →
Engine →
Heat proofing manifolds / wiringStarted by RallyRed , 01 Aug 2015 ![]() |
Holden Tech →
Engine →
Strata turboStarted by _luva15_ , 27 Jan 2014 ![]() |
