* * * * * 4 votes
LX GTR Hatch
turbo awd
785 replies to this topic
#451 bullitA9X
bullitA9X
  • 4,168 posts
Posted 21 June 2016 - 09:50 PM
frOcking hell Turbo76lx and i thought my sons hatch is an epic build this is frOcking awesome love your work you my friend are a frOcking GUN!!!
#452 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 24 July 2016 - 06:39 PM
Still slowly working on the wiring, finding it hard to stay motivated.
Attached File  IMGP3121_resize.jpg   199.32K   12 downloads
Edited by turbo76lx, 21 October 2017 - 03:37 PM.
#453 _BARRY JACKPOT_
_BARRY JACKPOT_
Posted 24 July 2016 - 10:31 PM
Wiring sucks arse
#454 _LS1 Hatch_
_LS1 Hatch_
Posted 25 July 2016 - 01:44 AM
I like wiring...guess I am one of the few..
#455 _BARRY JACKPOT_
_BARRY JACKPOT_
Posted 25 July 2016 - 05:49 AM
I like it, when someone else does it and it works properly lol
#456 _mick74lh_
_mick74lh_
Posted 25 July 2016 - 07:10 AM
Keep at it Glen. We were frothing hard when we saw this machine. Can't wait to see it driving eventually.
#457 _Cappa08_
_Cappa08_
Posted 25 July 2016 - 03:18 PM
The quicker you do it, the more time you have to enjoy it!
Awesome build thread by the way.
#458 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 25 July 2016 - 07:38 PM
I normally enjoy wiring but the past month i've only been able to spend a few hours each Sunday to work on it.
#459 hanra
  • 10,969 posts
Posted 25 July 2016 - 07:54 PM
Yeah I find it relaxing.
#460 _BARRY JACKPOT_
_BARRY JACKPOT_
Posted 25 July 2016 - 11:16 PM
I find a massage relaxing
#461 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 15 August 2016 - 07:21 PM
Got most of the relays wired, now starting the engine bay wiring.
Attached File  IMGP3123_resize.JPG   154.96K   9 downloads
Edited by turbo76lx, 21 October 2017 - 03:38 PM.
#462 rodomo
  • 18,037 posts
Posted 15 August 2016 - 08:07 PM
I'd rather do wiring than mechanical work.................and I've been a mechanic for over 40 yrs. Neat work!
#463 Shiney005
  • 9,587 posts
  • Car:Toyota Mirai
Posted 15 August 2016 - 11:12 PM
Looking good Glen.
#464 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 28 August 2016 - 10:18 PM
Pulled the motor and gearbox out today to finish the engine wiring harness.
Attached File  IMGP3125_resize.JPG   172.81K   5 downloads
Attached File  IMGP3130_resize.JPG   185.25K   5 downloads
Edited by turbo76lx, 21 October 2017 - 03:40 PM.
#465 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 03 October 2016 - 08:53 PM
Got the wiring loom finished off, some of the sensors that the ECU will have is.
2x inlet air temp
coolant temp
engine oil temp
gearbox temp
transfer case temp
2x knock sensors
MAP sensor
fuel pressure
oil pressure
ATTESA oil pressure
speedo sensor
rear l/h and r/h wheel sensors
Attached File  IMGP3204_resize.JPG   152.79K   6 downloads
Gave the transfer case a quick freshen up and changed the disc and clutch plates from 12/7 to 10/9, the spare one had water in it luckily I only needed 2 clutch plates out of it.
Attached File  IMGP3206_resize.JPG   218.2K   5 downloads
Attached File  IMGP3215_resize.JPG   180.95K   5 downloads
Attached File  IMGP3213_resize.JPG   179.04K   5 downloads
Since I had a spare ATTESA cylinder I decided to drill and tap it to take a pressure sensor.
Attached File  IMGP3293_resize.JPG   146.08K   5 downloads
Edited by turbo76lx, 21 October 2017 - 03:43 PM.
#466 _LHSL308_
_LHSL308_
Posted 03 October 2016 - 09:18 PM
Awesome work Glen. Wish I had half your skill and know how.
#467 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 08 October 2016 - 06:32 PM
Fitted the the MAP sensor.
Attached File  IMGP3297_resizedetail.jpg   178.11K   5 downloads
Edited by turbo76lx, 21 October 2017 - 03:44 PM.
#468 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 09 October 2016 - 08:06 PM
Spent the day cleaning parts.
Attached File  IMGP3299_resize.JPG   152.07K   7 downloads
#469 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 22 October 2016 - 08:13 PM
Welder up the air temp sensor in the manifold and re-tapped it to 1/8 NPT, also gave it a bit of a satin finish.
Attached File  IMGP3316_resize.JPG   138.38K   5 downloads
Edited by turbo76lx, 21 October 2017 - 03:45 PM.
#470 Shiney005
  • 9,587 posts
  • Car:Toyota Mirai
Posted 23 October 2016 - 08:43 AM
Is part of the inlet manifold sandwiched between the head and the cams? (Forgive my ignorance about anything without pushrods!)
Edited by Shiney005, 23 October 2016 - 08:44 AM.
#471 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 23 October 2016 - 10:23 AM
The MAP sensor ( manifold absolute pressure ) has to be mounted between the throttle body and the head, having 6 throttle bodies
the area i mounted it in links all 6 together so the computer can measure boost and vacuum.
Edited by turbo76lx, 21 October 2017 - 03:46 PM.
#472 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 28 October 2016 - 07:38 PM
To tight to buy a new thermostat housing, so simple, I just made one.
Attached File  IMGP3319_resize.JPG   137.96K   7 downloads
Attached File  IMGP3320_resize.JPG   154.6K   6 downloads
Also started to extend the top timing belt cover, it had a crack and a piece missing so it was easier to cut the small section out and replace it at the same time.
Attached File  IMGP3322_resize.JPG   129.51K   8 downloads
Attached File  IMGP3323_resize.JPG   138.02K   6 downloads
Attached File  IMGP3324_resize.JPG   129.96K   6 downloads
Attached File  IMGP3327_resize.JPG   139.77K   6 downloads
Edited by turbo76lx, 21 October 2017 - 03:49 PM.
#473 _Bomber Watson_
Posted 28 October 2016 - 07:54 PM
Stunning.
#474 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 29 October 2016 - 05:35 PM
Got the cam belt cover cleaned up and gave the engine mounts a quick polish.
Attached File  IMGP3333_resize.JPG   160.5K   6 downloads
Attached File  IMGP3334_resize.JPG   151.31K   6 downloads
Edited by turbo76lx, 21 October 2017 - 03:50 PM.
#475 _Agent 34_
_Agent 34_
Posted 29 October 2016 - 07:35 PM
ditto
Also tagged with one or more of these keywords: turbo, awd
