* * * * * 4 votes
LX GTR Hatch
turbo awd
785 replies to this topic
#26 _Skapinad_
_Skapinad_
Posted 31 August 2012 - 09:03 PM
So cool..... I often toy in my dreams of putting a 2 door lj over a wrx ...... Living the dream, reliability, speed, handling and traction!
#27 _greenmachine215_
_greenmachine215_
Posted 01 September 2012 - 10:14 PM
I wish I could get a project moving as quick as you have looks like it took you a day to do the lot haha, killer job mate, I'm guessing you've done a bit of this sort of work in the past. I can't wait to see this thing done
#28 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 02 September 2012 - 09:41 PM
Greenmachine215, yes i have done a bit of this before, some of my other projects. turbo hatch http://www.gmh-toran...tch-rb30-turbo/
lx sedan http://www.gmh-toran...eft-over-parts/ hj van http://www.gmh-toran...7-hj-panel-van/
Started fitting the gear box and trans tunnel, this is the bit that worries me because of the amount of floor that needs to be cut out.
This is the monster that i have to fit.
Attached File  IMGP1783.JPG   169.26K   11 downloads
You can see how much needs to be cut out.
Attached File  IMGP1786.JPG   160.67K   11 downloads
Fitting the gtr floor, it follows the torana floor fairly closely.
Attached File  IMGP1799.JPG   149.99K   12 downloads
Attached File  IMGP1803.JPG   180.16K   11 downloads
Attached File  IMGP1804.JPG   200.83K   10 downloads
Edited by turbo76lx, 20 October 2017 - 05:53 PM.
#29 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 03 September 2012 - 12:05 AM
cool, so whats the go with the floor. will you use the skyline one for measurements and make something up, or actually use the skyline tunnel? and as for the rest of the bits your fitting up, do you just tack them in and show it all to the engineer(he obviously knows you can weld) and then weld it all into another shell?
#30 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 03 September 2012 - 07:22 AM
I will be using the skyline floor, yes just tacking it all into this shell to show the engineer. He did give me the go ahead to do
it in the hatch but i thought it would be safer if i set it all up in in another old shell and show him exactly what i plan to do.
I would hate to do all this to the hatch then find out he wouldn't pass it, so the time and effort i spend on the old shell will be
well worth it in the long run.
Edited by turbo76lx, 03 September 2012 - 07:23 AM.
#31 76lxhatch
  • 7,205 posts
Posted 03 September 2012 - 01:16 PM
That looks like a pretty good match! Love it when things actually go to plan
#32 _DomDom_
_DomDom_
Posted 03 September 2012 - 01:58 PM
Wow. that is a monster tunnel. I love these types of builds, modern driveline and underpinnings in an older car.
You obviously have the skills to do it well too.
Dom
#33 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 08 September 2012 - 07:47 PM
Shortened the steering column and made up a shaft between the torana steering knuckle and the skyline one.
Attached File  IMGP1810.JPG   129.91K   9 downloads
Harvesting more parts. Looking at trying gtr R33 rear subframe instead of the R32.
Attached File  IMGP1809.JPG   173K   8 downloads
Edited by turbo76lx, 20 October 2017 - 06:00 PM.
#34 76lxhatch
  • 7,205 posts
Posted 09 September 2012 - 08:05 AM
Is there a significant difference?
#35 Peter UC
Peter UC
  • 770 posts
Posted 09 September 2012 - 09:43 AM
I bit wider in track and a bit better geometry as far as I know
#36 _PB.72.LC_
_PB.72.LC_
Posted 09 September 2012 - 07:13 PM
god damn this is a good build thread.
#37 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 09 September 2012 - 10:25 PM
I'm trying the R33 rear end for a few reasons. Yes they are 10mm wider and better geometry, the arms give a bit more clearance
to the chassis rail. Also the front mount on the R33 lower arm is horizontal with the subframe.
Top arm is R33 the bottom is R32
Attached File  IMGP1819.JPG   225.82K   6 downloads
R32 arm
Attached File  IMGP1816.JPG   94.17K   7 downloads
R33 arm
Attached File  IMGP1818.JPG   121.39K   7 downloads
R32 lower arm front mount.
R33 lower arm front mount, my finger is pointing to where the top of R32 mount was.
Attached File  IMGP1817.JPG   97.2K   6 downloads
Edited by turbo76lx, 20 October 2017 - 06:08 PM.
#38 76lxhatch
  • 7,205 posts
Posted 10 September 2012 - 06:58 AM
Ahah! Sweet
#39 _Romper_
_Romper_
Posted 10 September 2012 - 07:19 PM
Awesome mate i love a good read....
#40 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 06 October 2012 - 10:00 AM
any updates????
#41 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 07 October 2012 - 08:46 PM
No real updates. Looking at using a stand alone system from Full Race to run the ATTESA system (centre diff torque split controler),
and using a vipec v88 for the engine management. One thing i have found is vic roads is refer to VSB14 so i should talk to the engineer again
to make sure he is still happy with what i am doing.
#42 _LS2 Hatch_
_LS2 Hatch_
Posted 09 October 2012 - 09:25 PM
Keep up the good work, I love it!!
#43 _The Baron_
_The Baron_
Posted 09 October 2012 - 10:18 PM
Check is in the mail!!................for the L98 version!
#44 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 22 October 2012 - 07:18 PM
Had the engineer come up the other day and have a look at it, he was happy with how i have planned to do the conversion.
He is happy for me to use an after market ECU but he does want me to run a catalytic converter even though the RB30 i am using
came from a nissan patrol which didn't run a cat. It will have to pass a basic emissions test. He dosen't need to see the car again until
everything is tacked in the hatch. Not much more work will happen on this project now until i finish painting the doors and guards on
the LX sedan, hopefully i will have that done and on the road by march.
#45 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 26 October 2012 - 05:10 PM
sweet
#46 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 25 December 2012 - 08:07 AM
Started setting up the rear end on another floor pan to make it easier to put it into the hatch. Cut up the lower trailing
arms and welded them to the sub frame as the front mounts and using some 50x50x5 angle for the rear mounts.
Attached File  IMGP2021.JPG   101.45K   7 downloads
Attached File  IMGP2022.JPG   152.44K   6 downloads
Attached File  IMGP2027.JPG   137.44K   6 downloads
Attached File  IMGP2031.JPG   172.55K   7 downloads
Edited by turbo76lx, 20 October 2017 - 06:42 PM.
#47 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 25 December 2012 - 08:26 AM
Here's the hatch i'm using.
Attached File  Image012 (2)_resize.jpg   130.69K   8 downloads
These are a few of the repairs i started a few years ago.
Repairing the lower radiator support, made up my own repair pieces.
Attached File  IMGP0037_resize.JPG   141.93K   7 downloads
Attached File  IMGP0070_resize.JPG   139.02K   7 downloads
Attached File  IMGP0071_resize.JPG   107.22K   7 downloads
Patched the sun roof.
Attached File  IMGP0034_resize.JPG   132.27K   7 downloads
Flatened the fire wall.
Stripped the 1/4's back to find 16mm of bog in both sides, started to straighten them but still need work.
Attached File  IMGP0209_resize.JPG   124.75K   6 downloads
Attached File  IMGP0210_resize.JPG   149.06K   6 downloads
East meets West
Attached File  IMGP1987.JPG   121.46K   6 downloads
This is the GTS-4 i will be using the drive line from, it's got the drive line from a GTR R33
Attached File  IMGP1990.JPG   157.92K   6 downloads
Edited by turbo76lx, 20 October 2017 - 06:51 PM.
#48 _LS1 Hatch_
_LS1 Hatch_
Posted 25 December 2012 - 09:31 AM
Awesome....totally awesome :D
#49 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 25 December 2012 - 01:29 PM
Faaaaark
Love people with the talent to do shit like this
#50 _V6 UC_
_V6 UC_
Posted 25 December 2012 - 03:08 PM
Awsome. The vipec v88 is an awsome ecu aswell. Ive just finished Wiring in a link g4 it's almost exactly the same minus a couple auxiliarys and extra inputs/outputs
Also tagged with one or more of these keywords: turbo, awd
