Lol, what can you expect, its a video magazine, the writers dont know the first thing about cars.
#501
Posted 08 April 2017 - 09:32 PM
#502
Posted 09 April 2017 - 08:01 PM
I had a look at that VL on youtube, it's a fair effort to build it in one year but I would like to know if its been engineered.
#503
Posted 14 April 2017 - 08:42 PM
Gave the drive shafts a clean up and some paint.
IMGP3397_resize.JPG 142.8K
7 downloads
Removed some of the lip on the fire wall and fully seam welded it.
IMGP3396_resize.JPG 131.84K
8 downloads
Added some more strengthening to the front suspension towers to make sure the load is transferred back to the rail where the original subframe mounted.
IMGP3398_resize.JPG 127.5K
7 downloads
Edited by turbo76lx, 21 October 2017 - 04:15 PM.
#504
Posted 07 May 2017 - 08:10 PM
Have contacted a few engineers to see if they were interested in taking on the project. I've chosen one, now I have to reassemble the car
so he can see where it's at and where to move forward from here. Hopefully he will look at it in a few weeks.
IMGP3419_resize.JPG 142.38K
10 downloads
IMGP3426_resize.JPG 140.6K
8 downloads
IMGP3434_resize.JPG 144.01K
10 downloads
Edited by turbo76lx, 21 October 2017 - 04:16 PM.
#505
Posted 07 May 2017 - 08:47 PM
#506
Posted 07 May 2017 - 11:59 PM
Last I heard it's still registered as a commodore whatever that means.
Greenslip check will tell if engineered etc
#507
_imj411_
Posted 08 May 2017 - 01:16 PM
#508
_Romper_
Posted 18 May 2017 - 08:00 PM
did you end up getting a reply from bonneville mate ? who is the new engineer you have in mind ?
#509
Posted 18 May 2017 - 09:48 PM
After a week Bonneville replied to my email. I'm going to get Peter Turner from Teched Australia to have a look at it on the 29th.
#510
Posted 29 May 2017 - 06:52 PM
Had the engineer, Peter Turner http://www.techedaustralia.com.au/ have a look at the project.
He is happy with what has been done, he wants an extra brace between the rear suspension towers and I
have to have retractable seat belts for the outer back seats. The car will have to pass the IM240 emission test
and also have a torsional rigidity test. The plan now is to get the car ready for the torsional test then
start the panel work.
Rear seat belts something like this.
IMGP3441_resize.JPG 123.59K
8 downloads
Edited by turbo76lx, 21 October 2017 - 04:18 PM.
#511
Posted 29 May 2017 - 07:27 PM
I haven't looked at the regs but it's interesting that retractable rear seat belts are required, although I was thinking about doing the same anyway so watching with interest.
Doesn't the inertia reel part have to be designed for a certain range of mounting angle? And did he give you any guidelines as to how the inner quarter would need to be reinforced to an acceptable standard for mounting the reel?
Another question, does Peter have a set of standard Torana or generic minimum results for beaming and torsion tests? I thought the actual car had to be tested prior to any mods to establish a baseline for final testing... a 'so long as it's as good as it was when you started' kinda deal?
I was thinking about making my own test rig but the thought of buying a dozen-odd dial indicators is a little off-puting...
#512
Posted 29 May 2017 - 08:37 PM
Peter said the seat belts needed to be upgrade because of the power increase. APV-S seat belts make different reals
that work at different angle. http://www.apvsafety...pose-seat-belts
I don't know if he has any torana standards for the torsion test he may just use the 4000Nm per degree for ICV's.
He had no doubts it would pass.
#513
Posted 30 May 2017 - 10:29 AM
Great to see it going forward!
#514
Posted 30 May 2017 - 06:53 PM
Ditto, awesome news.
#515
Posted 12 June 2017 - 08:18 PM
Made up some bars to replace the coilovers for the torsion deflection testing. Hopefully will get the test done in a few weeks.
IMGP3443_resize.JPG 143.59K
7 downloads
IMGP3445_resize.JPG 103.55K
6 downloads
Edited by turbo76lx, 21 October 2017 - 04:19 PM.
#516
Posted 13 June 2017 - 10:58 PM
Love your work mate!
#517
Posted 13 June 2017 - 11:30 PM
Hmm... not sure whether that was a serious suggestion or tongue-in-cheek Heath? The solid struts/spring eliminators are only used for the beaming and torsion tests, you need to eliminate any suspension movement (including tyres) so you can accurately measure how far the body flexes under the various loads.
#518
Posted 14 June 2017 - 06:06 AM
Heath is always serious but it would be fun to see how it handled on a skid pan with these in.
#519
Posted 14 June 2017 - 11:47 PM
#520
_LS1 Taxi_
Posted 15 June 2017 - 03:34 PM
#521
Posted 15 June 2017 - 08:46 PM
stunnung work glen
hpoe it all goes to plan from here on
so looking forward to the finnished result
#522
Posted 25 June 2017 - 08:15 PM
Decided to mount the seat belt reel besides the back seat so they don't stand out as much.
IMGP3454_resize.JPG 108.03K
12 downloads
Ground up a piece of flat bar to match the shape of the panel.
IMGP3451_resize.JPG 126.21K
10 downloads
Will also weld this comp plate over the outside when the engineer gives me the ok.
IMGP3455_resize.JPG 115.68K
12 downloads
Also made up some panels for the back out of some aluminium that i'll cover with some vinyl.
IMGP3449_resize.JPG 123.73K
6 downloads
Edited by turbo76lx, 21 October 2017 - 04:21 PM.
#523
Posted 25 June 2017 - 08:28 PM
in the previous 21 pages...I'm sure someone has already told you that you are a genius....but, .....you are a genius!! Love your work
#524
Posted 25 June 2017 - 08:32 PM
No genius here, I just know how to weld and hammer things into place.
#525
Posted 25 June 2017 - 11:18 PM
Also tagged with one or more of these keywords: turbo, awd
General →
General Discussion →
Factory 202 Turbo option and id plateStarted by _Holden red sponge_ , 06 Dec 2018 ![]() |
Holden Tech →
Engine →
Phenomenal 202 buildStarted by _RedKobra_ , 10 Jan 2016 ![]() |
Holden Tech →
Engine →
Poll
ENGINESStarted by N/A-PWR , 04 Sep 2015 ![]() |
Holden Tech →
Engine →
Heat proofing manifolds / wiringStarted by RallyRed , 01 Aug 2015 ![]() |
Holden Tech →
Engine →
Strata turboStarted by _luva15_ , 27 Jan 2014 ![]() |
