* * * * * 4 votes
LX GTR Hatch
turbo awd
785 replies to this topic
#576 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 03 December 2017 - 07:06 PM
Put the wiper motor back together and stripped the paint off the wiper arm and linkages.
Attached File  A9X_0044_resize.JPG   208.39K   24 downloads
Attached File  A9X_0046_resize.JPG   317.13K   19 downloads
Attached File  A9X_0048_resize.JPG   393.96K   20 downloads
Attached File  A9X_0050_resize.JPG   366.41K   21 downloads
#577 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,418 posts
  • Name:facebook dave
Posted 04 December 2017 - 08:17 PM
your work son is impecable
#578 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 09 December 2017 - 05:27 PM
Finished painting the wiper link and reassembled.
Attached File  A9X_0051_resize.JPG   339.48K   21 downloads
The lower door skin turned up but needed a little more radius put into it.
Attached File  A9X_0053_resize.JPG   237.06K   22 downloads
Used the pan brake to bump the skin.
Attached File  A9X_0058_resize.JPG   263.49K   22 downloads
Cut off the lower skin, there was more rust in there then I thought.
Attached File  A9X_0059_resize.JPG   205.99K   22 downloads
Attached File  A9X_0060_resize.JPG   239.79K   20 downloads
Had to remake the corner of the door. Used the pullmax to make a joggle in one piece to replicate the original.
Attached File  A9X_0062_resize.JPG   168.24K   22 downloads
Attached File  A9X_0063_resize.JPG   183.15K   19 downloads
Attached File  A9X_0064_resize.JPG   194.67K   22 downloads
#579 hanra
  • 10,969 posts
Posted 09 December 2017 - 06:00 PM
Dags
#580 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 23 December 2017 - 07:03 PM
Wasn't happy with the bottom of the door so decided to cut the whole bottom out.
Attached File  A9X_0066_resize.JPG   228.05K   18 downloads
Folded up a new section.
Attached File  A9X_0069_resize.JPG   179.26K   19 downloads
Had to remake the joggle. Got some 3/4 key steel and make some new dies for the pullmax to suit the original joggle.
Attached File  A9X_0070_resize.JPG   129.75K   21 downloads
Attached File  A9X_0071_resize.JPG   159.8K   21 downloads
New section tacked in.
Attached File  A9X_0074_resize.JPG   157.1K   21 downloads
Attached File  A9X_0075_resize.JPG   148.72K   20 downloads
#581 _Romper_
_Romper_
Posted 24 December 2017 - 02:40 AM
just out of curiosity turbo76lx what is the law regarding engine clearances and clearances for everything else....ie....engine has to be x amount of millimetres (or centimetres is it ?) off fire wall and x amount of room between sump and k frame, exhaust has to be x amount off floor etc etc ?
its looking amazing as well mate you have unreal skills.
#582 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 24 December 2017 - 08:44 AM
10mm is what I have been told which is what I use on everything, engine clearance, gearbox, exhaust, steering.
#583 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 30 December 2017 - 05:42 PM
Trial fitted the skin and painted the inside with some KBS paint, hopefully weld it in tomorrow.
Attached File  A9X_0078_resize.JPG   172.99K   33 downloads
Attached File  A9X_0083_resize.JPG   178.1K   30 downloads
#584 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 31 December 2017 - 07:52 PM
Panel tacked in and the edges folded over.
Attached File  A9X_0085_resize.JPG   199.62K   30 downloads
All tig welded up, hopefully hammer it up tomorrow.
Attached File  A9X_0088_resize.JPG   152.98K   34 downloads
#585 SHEEL
SHEEL
  • 345 posts
  • Name:Daniel
Posted 03 January 2018 - 08:26 AM
I recently did this on a HQ door with a mig, need a lot of patience to control the heat.
How did you fare with the TIG? On the pic with the spot welds it definately looks like the heat doesn't spread as far.. looks more concentrated on the spot weld itself if you know what I mean
#586 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 03 January 2018 - 08:43 AM
TIG will concentrate the heat more than MIG also requires less amps, I welded this at 25 amps and used a small amount of 0.6 mig wire as filler.
#587 SHEEL
SHEEL
  • 345 posts
  • Name:Daniel
Posted 12 January 2018 - 04:35 PM
ah nice
#588 Heath
  • 18,385 posts
Posted 23 January 2018 - 07:10 AM
Doesn't matter how well you operate the MIG, Daniel - it will never be the same as the way Glen has done this repair with the TIG. Very different processes when you apply it to a bit of sheet like this.
Beautiful job BTW.
#589 SHEEL
SHEEL
  • 345 posts
  • Name:Daniel
Posted 05 February 2018 - 02:16 PM
maybe I should invest in a TIG!
#590 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 18 February 2018 - 08:02 PM
Haven't done much on the body, been a bit hot so started working on the console.
Folded up some aluminium sheet to match into the back part of the skyline console, the aluminium will be covered with black vinyl.
Mounted in front of the shifter will be a few switches for duel fuel map, duel boost maps, data loging, AWD system controls and a few other.
On the vertical face I was going to mount a few gauges but have decided mount a 8" tablet and configure it to display a guage page run from the Link ECU,
something like this
Attached File  A9X_0118_resize.JPG   265.22K   26 downloads
Attached File  A9X_0124_resize.JPG   285K   26 downloads
#591 _Bomber Watson_
Posted 18 February 2018 - 08:33 PM
Awesome.
#592 Bigfella237
Posted 18 February 2018 - 08:56 PM
#593 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 17 March 2018 - 07:42 PM
Got a switch block made for the console.
Attached File  A9X_0128_resize.JPG   207.12K   28 downloads
#594 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 18 March 2018 - 03:55 PM
Made up some mounts for the ETS-Pro and the G sensor.
Attached File  A9X_0131_resize.JPG   274.81K   24 downloads
#595 Heath
  • 18,385 posts
Posted 18 March 2018 - 09:09 PM
Neato as always. I really like your ally fab work. I want to try more of that myself on the next project.
#596 Peter UC
Peter UC
  • 770 posts
Posted 19 March 2018 - 11:50 AM
Looks like Shane has been busy with the router.
#597 Heath
  • 18,385 posts
Posted 19 March 2018 - 11:59 AM
Hope your boss doesn't get on the Torana forum, boys. Hahahaha
#598 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 19 March 2018 - 12:45 PM
No,no,no, all made by hand using a die grinder and a file.  :innocent:
#599 Ice
  • 15,200 posts
Posted 19 March 2018 - 05:36 PM
Impressive work as usual Glen
#600 Kantong
Kantong
  • 96 posts
  • Name:Anton
  • Car:Lx
Posted 19 March 2018 - 07:26 PM
I bloody love this thing, you have some cool equipment at your disposal too
Also tagged with one or more of these keywords: turbo, awd
