Painted the switch block and fitted the switches to see how it looked, still need to engrave two plates to say what each switch does.
A9X_0134_resize.JPG 206.49K
39 downloads
A9X_0135_resize.JPG 205.19K
38 downloads
Posted 24 March 2018 - 04:07 PM
39 downloads
38 downloads
Posted 02 April 2018 - 08:54 PM
Wasn't happy with the washer bottle/catch can, decided to make it a bit lower and and raise the bottom to hide the washer pump and boost control valve.
A9X_0137_resize.JPG 345.95K
30 downloads
A9X_0139_resize.JPG 300.01K
28 downloads
A9X_0141_resize.JPG 284.54K
26 downloads
Welded in some tabs to mount the panel that has the ECU, fuses and relays on it.
A9X_0138_resize.JPG 202.77K
29 downloads
Patched the fan duct hole which had some rust around it.
A9X_0142_resize.jpg 208.05K
25 downloads
Posted 15 April 2018 - 06:05 PM
Welded up the fan duct hole and gave it a hammer and sand. Also started hammering some of the dints in the floor.
A9X_0148_resize.JPG 228.53K
25 downloads
Made up the battery holder with isolator switch. This will hold a Full River HC44 battery.
A9X_0150_resize.JPG 213.67K
25 downloads
A9X_0152_resize.JPG 229.33K
23 downloads
A9X_0154_resize.JPG 263.1K
27 downloads
Remover the hatch hinges and the body sealant and just some surface rust.
A9X_0160_resize.JPG 183.23K
24 downloads
Posted 25 April 2018 - 08:18 PM
Decided to make a trolley to hold the stud welder a few of my hammers and dollies so there at arms reach while I do the body work.
Also started to get all the engine parts together to take to JPC to get rebuilt.
A9X_0171_resize.JPG 259.78K
27 downloads
Posted 26 April 2018 - 09:58 AM
Problem with this build is most of the really cool fabricated bits will never be seen, started with a really good shell, can't wait to see it finished!
Posted 29 April 2018 - 06:58 PM
Had to make one good ignition switch from three.
A9X_0172_resize.JPG 377.17K
25 downloads
Painted the column.
A9X_0173_resize.JPG 162.75K
27 downloads
Posted 02 May 2018 - 08:45 PM
The door trims, roof lining and the trim kit for the top of the doors came today from Cools Auto Trim, had them done in black instead of slate.
A9X_0174_resize.JPG 154.35K
30 downloads
Posted 02 May 2018 - 10:30 PM
Bit of a let down?????????????..................... I thought a bloke like you could make 7 switches from 3?Had to make one good ignition switch from three.
Posted 03 May 2018 - 02:06 PM
Posted 06 May 2018 - 04:58 PM
Posted 31 May 2018 - 06:52 PM
Not finding much time at the moment to get far on the body work so just buying some more parts like new brakes.
355x32 discs with 6 piston front and 4 piston rear calipers, it might be a bit over kill when the hatch originally come out with 13" rims
and now is going to have 14" discs.
A9X_0178_resize.JPG 271.17K
44 downloads
Posted 02 June 2018 - 08:51 PM
Have 12mm clearance between the spokes and the caliper and 6.5mm between the inner barrel and the caliper.
A9X_0182_resize.JPG 227.22K
36 downloads
Posted 04 June 2018 - 12:33 PM
wow. that'll hurt your eyeballs when you pull it up!
Posted 04 June 2018 - 08:55 PM
At 25 pages, the thread is starting to get a bit long to go back through for stuff I can't remember. Are you incorporating the ABS from the donor car Glen?
Posted 04 June 2018 - 10:13 PM
No ABS.
Posted 22 July 2018 - 07:11 PM
Started on panel gaps and sort out which is the best nose cone to use, then need to modify the front section of the front flares and front spoiler.
A9X_0201_resize.JPG 287.82K
28 downloads
Posted 29 July 2018 - 06:11 PM
Gave to engine covers a better polish and fitted some Mine triple flow cam baffles.
A9X_0206_resize.JPG 240.96K
21 downloads
A9X_0222_resize.JPG 274.33K
21 downloads
Posted 30 July 2018 - 08:18 AM
Cam baffles Glen?
Posted 30 July 2018 - 08:44 AM
The RB engines have a tendency to fill the cam covers with oil then push it out the breathers these help separate the oil.
Posted 31 July 2018 - 08:38 AM
Very nicely explained. Something similar could work in high revving 308s as well.
Posted 01 August 2018 - 07:51 PM
glen it will be fast and you need to stop it
Posted 12 August 2018 - 05:17 PM
Gave the starter and alternator a clean up and some new bearings.
A9X_0225_resize.JPG 236.46K
26 downloads
A9X_0228_resize.JPG 289.04K
27 downloads
A9X_0230_resize.JPG 263.36K
26 downloads
A9X_0232_resize.JPG 221.85K
26 downloads
Posted 22 September 2018 - 06:54 PM
Playing around with extending the front of the front flares to spoiler.
A9X_0234_resize.JPG 242.29K
27 downloads
Posted 23 September 2018 - 10:19 AM
May have missed it in the thread.
Any reason the flares sit so high?
Crappy flares or mods for different sized wheels?
With the seat supporting it I almost though you were going to extend the bottom lip.
Would look different and good if you did.
Have seen photos of alod race cars with an extended lip.
Look good with it.
Posted 23 September 2018 - 04:56 PM
Better check in with your doggy Glen, looks a bit concerned with something he has seen.
General →
General Discussion →
Factory 202 Turbo option and id plateStarted by _Holden red sponge_ , 06 Dec 2018 ![]() |
Holden Tech →
Engine →
Phenomenal 202 buildStarted by _RedKobra_ , 10 Jan 2016 ![]() |
Holden Tech →
Engine →
Poll
ENGINESStarted by N/A-PWR , 04 Sep 2015 ![]() |
Holden Tech →
Engine →
Heat proofing manifolds / wiringStarted by RallyRed , 01 Aug 2015 ![]() |
Holden Tech →
Engine →
Strata turboStarted by _luva15_ , 27 Jan 2014 ![]() |
