#676
Posted 13 May 2019 - 09:24 AM
#677
Posted 25 May 2019 - 09:34 PM
#678
Posted 24 July 2019 - 06:50 PM
#679
Posted 24 July 2019 - 09:59 PM
Thats not at Scarborough Beach is it Laurie?How dare you suggest that Torana's were once treated poorly Brad.
The exhaust on this XU1 was glowing right to the end of the muffler. It was held flat for minutes.
#680
Posted 27 July 2019 - 07:55 PM
Update time. Having the shell dipped has turned out to be more work than I thought.
About 14 holes have been drilled in the shell that they never told me they were going to do so these had to be welded up.
Yes that is a hole drilled in the middle of the roof skin.
A9X_0404_resize.JPG 106.52K
13 downloads
Holes drilled in the wind screen channel and the top of the dash.
A9X_0406_resize.JPG 193.31K
12 downloads
I was surprised at the amount of rust that started to form under panels, I had tack welded the sill panel and two extra roof braces on to the shell and removed them when I got the shell home.
A9X_0412_resize.JPG 107.69K
11 downloads
A9X_0386_resize.JPG 209.6K
11 downloads
There are also spots where it looks like acid is still leaching out of the seams.
A9X_0399_resize.JPG 189.13K
12 downloads
A9X_0400_resize.JPG 213.49K
12 downloads
I was also surprised at the amount of body deaden-er and seam sealer that was still in the shell.
The black shape in the middle of the photo is one of the many big chuncks of body deaden-er.
A9X_0401_resize.JPG 133.04K
17 downloads
#681
Posted 27 July 2019 - 08:03 PM
I have had to strip and clean and sand every part of the shell so finally got the inside and underneath painted with KBS.
A9X_0414_resize.JPG 285.81K
21 downloads
One coat of silver KBS, still need to seam seal then a coat of black KBS.
A9X_0418_resize.JPG 233.63K
22 downloads
A9X_0424_resize.JPG 282.63K
18 downloads
A9X_0425_resize.JPG 269.09K
18 downloads
Edited by turbo76lx, 27 July 2019 - 08:03 PM.
#682
Posted 27 July 2019 - 09:00 PM
DSCN0462.jpg 124.49K
13 downloads
DSCN0453.jpg 131.03K
14 downloads
DSCN0456.jpg 124.81K
14 downloads
Thats disappointing Glen,
your body looks like mine did after they dipped the car the first time, it still looked rusty and crap was coming out of it.
After the second dipping the shell was spotless and there was nothing left in the box sections that I could see through holes.
The box sections were all rust treated as well as the rest of the car, and finally a sealer was applied to everything.
#683
Posted 27 July 2019 - 11:53 PM
I assume all the holes they drilled were to let air bubbles escape when they submerged the shell in their bath?
That kinda sucks.
You'd think it'd be worth them building a rotating cradle similar to a rotisserie so they didn't have to do that.
I have had to strip and clean and sand every part of the shell ~
That almost seems to defeat the purpose of dipping if you still have to do all that work afterward?
I hate the idea of that rust starting again in all the cavities you can't get to. Sounds like there should be a second stage dipping in some kind of rust prevention treatment?
#684
_Lazarus_
Posted 28 July 2019 - 07:53 AM
I guess you should just be thankful that it wasn't Heath on the drill
#685
Posted 28 July 2019 - 10:22 AM
Pm'd
#686
Posted 28 July 2019 - 11:47 AM
One thing I would do before you weld up the holes is pump them full of cavity wax (or the like) especially if they are hard to get at areas. I would have thought there should have been a final process of spraying a rust inhibitor. Cheers Ron
Edited by Cook, 28 July 2019 - 11:52 AM.
#687
Posted 13 August 2019 - 08:22 PM
Got the sill put back on and a coat of epoxy on it and the rest of the engine bay.
A9X_0428_resize.JPG 277.9K
19 downloads
A9X_0431_resize.JPG 182.39K
20 downloads
A9X_0435_resize.JPG 257.63K
22 downloads
#688
Posted 14 August 2019 - 07:47 AM
#689
Posted 19 August 2019 - 07:40 PM
Got the inside of the shell painted.
A9X_0437_resize.JPG 274.69K
17 downloads
A9X_0438_resize.JPG 279.64K
17 downloads
Also pulling the running gear out of this to get another car out of the back yard.
A9X_0436_resize.JPG 297.73K
21 downloads
#690
Posted 06 September 2019 - 06:01 PM
Big stuff Glen. Always a pleasure to get up to date on this.
Can't say it makes me super keen to have a car dipped though. At least you're well qualified to deal with hurdles though, lol.
#691
Posted 07 September 2019 - 08:40 PM
#692
Posted 21 September 2019 - 07:16 PM
Got filler on both sills and quarters and fitted the flares to check the gaps.
A9X_0448_resize.JPG 237.48K
26 downloads
A9X_0449_resize.JPG 92.76K
21 downloads
#693
Posted 22 September 2019 - 06:47 PM
Nice fit
#694
Posted 30 September 2019 - 07:47 PM
#695
Posted 05 October 2019 - 07:54 PM
Put a quick coat of epoxy/prime over the filler to seal it up.
Now need to take it off the rotator and do around the tail lights.
A9X_0454_resize.JPG 276.06K
12 downloads
#696
Posted 13 October 2019 - 07:21 PM
Started fitting the spoiler, the LH side was ok but the RH needs a lot of work.
A9X_0459_resize.JPG 143.93K
9 downloads
A9X_0458.1_resize.jpg 130.42K
9 downloads
Almost had to cut the whole side off and re-fibreglass it back on.
A9X_0462_resize.JPG 139.16K
9 downloads
Also had to build up both sides of the centre piece.
A9X_0464_resize.JPG 192.18K
9 downloads
Now just need to file and square up the gaps.
A9X_0469.1_resize.jpg 144.76K
10 downloads
A9X_0470.1_resize.jpg 158.93K
9 downloads
A9X_0471_resize.JPG 218.45K
9 downloads
Got a lot of holes that need to be filled in the hatch.
A9X_0467_resize.JPG 208.22K
13 downloads
#697
Posted 13 October 2019 - 08:12 PM
Get the spoiler nice and neat then take moulds and make a motza selling a product that actually comes close to fitting.
Rob
#698
Posted 21 October 2019 - 07:32 AM
#699
Posted 21 October 2019 - 09:50 AM
Better than anything done at the factory.
#700
Posted 22 October 2019 - 09:21 AM
Worth the effort, only way to get great gaps, looks good.
Also tagged with one or more of these keywords: turbo, awd
General →
General Discussion →
Factory 202 Turbo option and id plateStarted by _Holden red sponge_ , 06 Dec 2018 ![]() |
Holden Tech →
Engine →
Phenomenal 202 buildStarted by _RedKobra_ , 10 Jan 2016 ![]() |
Holden Tech →
Engine →
Poll
ENGINESStarted by N/A-PWR , 04 Sep 2015 ![]() |
Holden Tech →
Engine →
Heat proofing manifolds / wiringStarted by RallyRed , 01 Aug 2015 ![]() |
Holden Tech →
Engine →
Strata turboStarted by _luva15_ , 27 Jan 2014 ![]() |
