Sealed the tail up with a coat of epoxy prime and finished getting the gaps right.
A9X_0475_resize.JPG 208.25K
28 downloads
A9X_0476_resize.JPG 145.79K
26 downloads
A9X_0477_resize.JPG 160.08K
26 downloads
Posted 22 October 2019 - 02:24 PM
28 downloads
26 downloads
26 downloads
Posted 25 October 2019 - 07:18 PM
Got the first coat of All-U-Need ploy primer on just need a few more coats and then start blocking it back.
A9X_0478_resize.JPG 245.88K
26 downloads
A9X_0479_resize.JPG 299.17K
23 downloads
Posted 25 October 2019 - 07:58 PM
Posted 26 October 2019 - 08:57 AM
I admire your thoroughness Glen. I wonder if panel tolerances make it hard for the manufacturers to deliver good fit. Fibreglass is pretty stable but there can be some variation there as well. Like someone else said, the only way to get good gaps.
I bought a bobtail set back in 1980
It came from the local Holden dealer at the time.
It fitted well, but with about 3mm gaps, which was about what the panel gap was.
The problem now is that there are multiple generations of moulds being used to get the parts.
A mould off an item that came out of a mould of another one etc etc etc.
Each time a mould is made from a part, there is a slight variation.
Flares are the best for showing the problem. The bottom edges get closer and closer together.
Posted 26 October 2019 - 11:50 AM
Posted 28 October 2019 - 03:24 PM
sanding sucks!!!
Posted 16 November 2019 - 05:42 PM
If you get arrested any time soon, at least you'll have no fingerprints!
Posted 17 November 2019 - 10:28 AM
Been there done that.
A good friend once told me that anyone can paint a car.
Its pretty true actually. The paint is the easy work. And its not too hard to fix a few little errors here and there.
Its the prep work that matters. Thats what really makes the difference
I was watching an Eastwood video the other night on youtube.
They recommend doing the sanding work with all panels in place.
They even bog through the door gaps, then run a couple of blades on a paddle pop stick through the join while the bog is still soft.
Helps with getting the lines nice between panels.
Just a thought.
Rob
Posted 23 November 2019 - 04:41 PM
Posted 23 November 2019 - 07:51 PM
Posted 23 November 2019 - 10:22 PM
Posted 14 December 2019 - 04:46 PM
Posted 01 January 2020 - 07:15 PM
Finished sanding the roof and put another coat of All-U-Need over both quarters, tail and roof.
A9X_0527_resize.JPG 268.86K
22 downloads
Posted 01 January 2020 - 09:22 PM
Looking awesome... can't wait to see photos with colour!
Posted 20 January 2020 - 05:56 PM
Another awesome project i was reminded of when returning to the forum, awesome to go back to the start and re read the thread. Great to see the paint prep happening, although it has been good watching the fab work im looking forward to seeing the colour on it
Posted 27 January 2020 - 07:05 PM
Posted 06 March 2020 - 04:11 PM
Still slowly working on it, roof and other quarter almost done.
A9X_0531_resize.JPG 288.85K
14 downloads
Posted 06 March 2020 - 04:23 PM
Looking good mate, I don't say much but am watching with interest.
Cheers gong
Posted 07 March 2020 - 12:09 AM
Posted 07 March 2020 - 04:19 PM
At this stage the shell is almost done just a couple of small spots need some more hi-fill so rapped up and now to start on the doors.
A9X_0535_resize.JPG 268.62K
31 downloads
Posted 30 March 2020 - 06:54 PM
Got the motor back from JPC and started fitting the manifold, sump etc.
The motor has, CP pistions 9.0:1, Spool I beam rods, Spool oil pump gears in N1 housing, APR head studs and main studs, Tomei cam gears, Nitto head gasket, Ross balancer.
The head has only had new valve spring, will be running the standard cams as I need to pass a full IMR240 emissions test.
Also had to finish off making the oil pick up.
A9X_0555_resize.JPG 256.55K
25 downloads
A9X_0560_resize.JPG 283.41K
28 downloads
Posted 31 March 2020 - 10:56 AM
This is so great. Loving every bit.
General →
General Discussion →
Factory 202 Turbo option and id plateStarted by _Holden red sponge_ , 06 Dec 2018 ![]() |
Holden Tech →
Engine →
Phenomenal 202 buildStarted by _RedKobra_ , 10 Jan 2016 ![]() |
Holden Tech →
Engine →
Poll
ENGINESStarted by N/A-PWR , 04 Sep 2015 ![]() |
Holden Tech →
Engine →
Heat proofing manifolds / wiringStarted by RallyRed , 01 Aug 2015 ![]() |
Holden Tech →
Engine →
Strata turboStarted by _luva15_ , 27 Jan 2014 ![]() |
