Wow, that's a big turbo
No, it's just a small botle of JD.
Posted 27 April 2013 - 08:51 PM
Posted 27 April 2013 - 10:33 PM
wow, interesting build! cant wait to see it finished! the thing will be a weapon!
Posted 29 April 2013 - 07:28 PM
No it's a standard 700ml JD the turbo isn't the big when compared to the one on my other hatch.
IMGP2213_resize.JPG 153.47K
6 downloads
IMGP2212_resize.JPG 146.98K
6 downloads
Edited by turbo76lx, 21 October 2017 - 12:49 PM.
Posted 29 April 2013 - 07:43 PM
Started to make up the exhaust manifold, used the bracket i made to work out where i was mounting the turbo to make up a jig.
IMGP2224_resize.JPG 143.91K
6 downloads
Started making the colector by cutting up 4 peices of 1.5" sch 40 pipe and welding 2 together.
IMGP2228_resize.JPG 124.79K
6 downloads
After they were welded together i cut the peak off and cut out the side so they merge to one point.
IMGP2230_resize.JPG 141.8K
6 downloads
After that they are welded together and while still hot i hammered the sides flat to make more of a rectangular opening.
IMGP2232_resize.JPG 154.93K
7 downloads
From there i started planning how i was running the pipes.
IMGP2233_resize.JPG 145.01K
7 downloads
Edited by turbo76lx, 21 October 2017 - 12:52 PM.
Posted 30 April 2013 - 11:53 AM
Holly smolley!
Posted 30 April 2013 - 02:02 PM
Posted 30 April 2013 - 02:08 PM
Wow, your metal work is awesome. A real credit to you.
Question... when you make an exhaust manifold, with the welds which are hard or near impossible to get to like some of the ones up above, how do you make sure you weld it all up and don't miss bits?
Do you test it with water that it's sealed up?
Posted 30 April 2013 - 07:13 PM
Emu after i have all the runners tacked in position i will weld as much of the manifold except for the welds to the manifold flange and one joint on
each of the runner near the colector. Then i will brake each runner off and finish the welds off and then put it back in place and weld it to the flanges.
Bomber, no 6 just put the side ones on later.
This is the shape of the cut out of the side ones.
IMGP2236_resize.JPG 152.9K
6 downloads
IMGP2243_resize.JPG 128.72K
6 downloads
IMGP2231_resize.JPG 147.9K
6 downloads
Edited by turbo76lx, 21 October 2017 - 12:55 PM.
Posted 30 April 2013 - 08:35 PM
Lol cool, had me scratching my head trying to work out how the frOck that was going to work, but seening what you have done thus far didnt want to doubt the logic
Edited by Bomber Watson, 30 April 2013 - 08:36 PM.
Posted 30 April 2013 - 09:51 PM
Was doing the exact same! haha
Posted 30 April 2013 - 09:58 PM
Nice workmanship! I'd love to see some photos of a runner once you "break them off". I'm having trouble picturing what you described.Emu after i have all the runners tacked in position i will weld as much of the manifold except for the welds to the manifold flange and one joint on
Posted 05 May 2013 - 07:59 PM
Got the runners for cylinders 3,4,5,6 tacked up today.
IMGP2249_resize.JPG 137.33K
7 downloads
IMGP2251_resize.JPG 154.68K
7 downloads
IMGP2252_resize.JPG 138.29K
7 downloads
Edited by turbo76lx, 21 October 2017 - 12:56 PM.
Posted 05 May 2013 - 10:18 PM
Posted 11 May 2013 - 03:08 PM
Posted 11 May 2013 - 08:20 PM
Got all the runners tacked up then welded as much of the welds as possible. Then broke out the runners and finished welding and a quick polish.
Manifold tacked up.
IMGP2256_resize.JPG 131.82K
8 downloads
Trial fit.
IMGP2263_resize.JPG 152.43K
7 downloads
Cylinder 4 runner welded and polished, ready to be welded to the manifold flange and the colector.
IMGP2265_resize.JPG 140.51K
7 downloads
Edited by turbo76lx, 21 October 2017 - 01:00 PM.
Posted 11 May 2013 - 08:31 PM
looks like a metal spider lol,brilliant work,pity its under the bonnet
Posted 12 May 2013 - 08:23 PM
Braking out the runners to weld up each one.
IMGP2266_resize.JPG 154.76K
6 downloads
Manifold welded up but going to change the angle of the turbo flange and need to work out where i'm pitting the wastegate.
IMGP2267_resize.JPG 133.63K
6 downloads
IMGP2269_resize.JPG 141.81K
6 downloads
IMGP2270_resize.JPG 118.13K
6 downloads
IMGP2268_resize.JPG 141.78K
6 downloads
Edited by turbo76lx, 21 October 2017 - 01:02 PM.
Posted 12 May 2013 - 08:41 PM
Posted 12 May 2013 - 09:38 PM
Did you have any trouble with the flange warping after welding?
Posted 12 May 2013 - 10:03 PM
Very nice. This is a very interesting build and you are making me feel lazy with your great creativity.
Well done on taking on such an individual outside of the box build. Considering we are in 2013 I appreciate such thinking. This type of modification has so much relevance to the modern hotrod way of thinking.
Excellent
Posted 13 May 2013 - 07:32 PM
Thanks guys for the positive comments.
Jabba, the flange pulled about 0.5mm at no.5 runner, after i have finish the wastgate i'll take it to the machine shop and get the flange machined.
Posted 13 May 2013 - 09:29 PM
Mate Awsome Build I can just imagine Brocky driving the Torzilla in Rally Cross
Posted 14 May 2013 - 09:49 PM
Posted 15 May 2013 - 06:00 AM
The flange was 12.5mm thick.
Posted 26 May 2013 - 07:58 PM
Got the pipe from the turbo to the intercooler tacked up and changed the pipe from the intercooler to inlet manifold to allow for a 3 row radiator.
IMGP2282_resize.JPG 137.84K
6 downloads
IMGP2281_resize.jpg 149.77K
7 downloads
IMGP2280_resize.JPG 162.89K
8 downloads
IMGP2278_resize.JPG 142.03K
7 downloads
Edited by turbo76lx, 21 October 2017 - 01:04 PM.
General →
General Discussion →
Factory 202 Turbo option and id plateStarted by _Holden red sponge_ , 06 Dec 2018 ![]() |
Holden Tech →
Engine →
Phenomenal 202 buildStarted by _RedKobra_ , 10 Jan 2016 ![]() |
Holden Tech →
Engine →
Poll
ENGINESStarted by N/A-PWR , 04 Sep 2015 ![]() |
Holden Tech →
Engine →
Heat proofing manifolds / wiringStarted by RallyRed , 01 Aug 2015 ![]() |
Holden Tech →
Engine →
Strata turboStarted by _luva15_ , 27 Jan 2014 ![]() |
