whats the differance between the LH and LX torana
20 replies to this topic
#1 _garth33_
_garth33_
Posted 09 September 2012 - 08:49 PM
ok it maybe a stuped qustion but i just got a LH torana and i need to no whats the differance between the LH and LX torana
#2 dattoman
  • 16,487 posts
Posted 09 September 2012 - 09:22 PM
I'll start
1. Headlights ... LH are rectngular unless you have a L34 or a 4 cyl.. .they were round ... LX are all round
2. Many trim options
3. Early LH has less pollution equipment... Late LX has everything :)
How many points do you want.... I can think of about another 40+ differences.. .all subtle... but differences all the same
#3 _judgelj_
_judgelj_
Posted 09 September 2012 - 09:26 PM
what about model variations - number of doors?
#4 _garth33_
_garth33_
Posted 09 September 2012 - 09:57 PM
think you for the info
I have a 1974 Lh 4door it has a bit off rust but it is only small it all so has the 202 red motor my 1st car to restore but i dont think it will be the last.
Got to say i love the body shape
#5 _torbirdie_
_torbirdie_
Posted 12 September 2012 - 04:07 AM
as stated ^ many minor differences but if you are stripping and replacing then one item that gives many headaches is the headlight dipper arrangement.
LX operates via the indicator stalk + a unique toggle relay.
LH....well I dont know what it has...Im guessing it still has the floor button?
#6 _CHOPPER_
_CHOPPER_
Posted 12 September 2012 - 01:23 PM
LH dipper was still on the floor.
#7 _LH8VD69_
_LH8VD69_
Posted 12 September 2012 - 04:48 PM
I'll add a couple of things. LH has a double skinned bonnet. LH inside of the boot looking back towards the number plate has more steel there. You will see circles. Also still in the boot looking towards the quarter panels there is more metal toward the top hanging down. Dip switch in the floor. Early LH had the park brake release as a symbol not the regular twist and pull words.
#8 _garth33_
_garth33_
Posted 12 September 2012 - 07:33 PM
ok one more qustion can i ues the LX work shop manual for some off my LH wrok i need to do?
thinks for all the info mach appreciated</p>
#9 _LXSS350_
_LXSS350_
Posted 12 September 2012 - 08:48 PM
Holden never had an LX service manual only an LH service manual. Holden like to cut corners with expendature LOL
#10 _garth33_
_garth33_
Posted 12 September 2012 - 09:09 PM
<p>my bad its the parts catalogue that i can get on a pdf
#11 mitchg
mitchg
    The guy with the Torailer
  • 3,111 posts
  • Name:Mitch
Posted 12 September 2012 - 09:18 PM
Swear there where different rear seatbelt mounting points between them? One had them on the C-pillar, another on the parcel shelf? My LX was on the shelf and the torailer was an LH and im pretty sure it was on the C-pillar. Not 100% though
#12 myss427
myss427
  • 1,636 posts
Posted 12 September 2012 - 10:20 PM
You are correct with the seat belts.
#13 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 12 September 2012 - 10:43 PM
And the instrument cluster text is some form of yellow with orange? needles rather than white needles on white in LH
#14 _LH8VD69_
_LH8VD69_
Posted 15 September 2012 - 02:32 AM
Just a couple of LH LX SLR differences. The LH insert on the seats , for example grey golfball insert on the black vynal only went 2/3 of the way up the seats back and front where as the LX went to the top. The LH rear seat was a nicer seat IMO as the backrest was made into a two bucket look seat with raised sections either side. Door trims had the grey golfball in this example in an oval pattern around the armrest in the LH where the LX had it running in a zig zag along the length. Debate still rages over the centre console too with LH's getting the flip up door at the front of the unit and the LX getting a tray instead. ( jury is out) Lima ur right about the white instrument for the LH and yellow for LX.
#15 _outer control_
_outer control_
Posted 15 September 2012 - 02:41 AM
Saw a 12/75 hatchback the other night with black engine bay and square headlights no charchoal canister and only ADR 27 tag and correct date coded L32 engine
#16 hanra
  • 10,983 posts
Posted 15 September 2012 - 06:18 AM
Weird!!! ^^^ My 10/75 sedan has a charcoal canister and is pre ADR27A.
Edited by hanra, 15 September 2012 - 06:19 AM.
#17 _CHOPPER_
_CHOPPER_
Posted 15 September 2012 - 02:51 PM
The chasrchol cannister came in 1/1/1975.
#18 hanra
  • 10,983 posts
Posted 15 September 2012 - 02:58 PM
Yeah that's why I found it weird that a hatchback had square headlights and NO canister?
#19 Dr Terry
Dr Terry
  • 3,325 posts
Posted 15 September 2012 - 08:30 PM
Black engine bay is OK for very early production LXs & there are 12/75s around, but I do have issue with the square headlights & no canister.
Dr Terry
#20 S pack
  • 15,727 posts
Posted 15 September 2012 - 09:04 PM
ADR 27 on the compliance plate is correct for a 12/75 build.
#21 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 15 September 2012 - 10:12 PM
My LX (2/76) has rear seatbelt anchors on the C pillars.
