Not a brake question but a brake fluid question ??
My Hydraulic clutch decided to start leaking whilst I was out and about.
I made a quick dash into a servo to buy some brake fluid to top it up so I could get home.
All they had was Dot4 , so I bought it.
The cap on my hydraulic clutch master cylinder states
(only use Dot3 Fluid)
Could I have done damage mixing the Dot 4 with Dot 3 ???
(only put in enough to half fill the reservoir
It was strange..after topping up the fluid I got home and it hadn't appeared to have lost any further fluid ??
Only reason I knew there was a problem because my pedal is usually firm from the instant you push it.
As I was driving i started to get free play, and by the time I stopped, I had to push the pedal to the floor to engage/ disengage the clutch ??
Anyway will look into it when I get time..but would Like an answer to my question at the top please..
Edited by Obey 1, 09 September 2012 - 10:11 PM.
