Street & Strip hatchback
481 replies to this topic
#226 _SYCH08_
_SYCH08_
Posted 01 September 2014 - 02:55 PM
Well the other half of my ordered parts finally showed up only took about 15 weeks just a hand break and cables.
so have ordered more stuff but through different place  this time got axles coming should be about 5 weeks away.
#227 _LS1 Hatch_
_LS1 Hatch_
Posted 01 September 2014 - 02:58 PM
15 weeks ?
Using carrier pigeon ?   :o  :huh:
#228 _SYCH08_
_SYCH08_
Posted 01 September 2014 - 04:28 PM
15 weeks ?
a turtle would be quicker
#229 _SYCH08_
_SYCH08_
Posted 01 October 2014 - 05:26 PM
so this is what i,ve been doing lately hand break in
trans cooler
#230 _SYCH08_
_SYCH08_
Posted 01 October 2014 - 05:29 PM
new back tyres 31-18.5-15 roadies
#231 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 01 October 2014 - 05:35 PM
gee i like that transcooler Aaron .perfectly placed.
where did you source that from bud
mmm.sportman pro's  too
Maz
Edited by madtoranajzedded, 01 October 2014 - 05:39 PM.
#232 _SYCH08_
_SYCH08_
front tyres and rims had to get wider fronts the old rims where 4" but we have to have at least 4.5" so ended up with 5" all for cert  there's not that many 4.5" wheels out there
i wanted convo pros but they only in 4 or 6
#233 _SYCH08_
_SYCH08_
Posted 01 October 2014 - 05:41 PM
Maz
 just off trade me i had to make the shroud and get the fan 7"  i hope it works up there
Exhaust time
a
a
Edited by SYCH08, 01 October 2014 - 05:39 PM.
#234 _SYCH08_
_SYCH08_
Posted 01 October 2014 - 06:10 PM
am just running 4" exhaust at the moment no mufflers yet hoping the turbo's are quite enough if not will put a slip in like lake pipes have later on
#235 _SYCH08_
_SYCH08_
Posted 01 October 2014 - 06:13 PM
big's n little's
#236 _LS1 Hatch_
_LS1 Hatch_
Posted 03 October 2014 - 02:20 AM
Wow, that is a lot of firewood!
#237 _SYCH08_
_SYCH08_
Posted 04 October 2014 - 05:31 PM
look what postman pat dropped off this morning strange 35 spline axle kit
#238 orangeLJ
Posted 05 October 2014 - 08:59 AM
Nice!
#239 _SYCH08_
_SYCH08_
Posted 19 October 2014 - 05:41 PM
started on radiator shroud went and folded this on Saturday morning
the fit was pretty good a little trim and grind in it went
got 2 16" fans on there hopefully will do the job.
Edited by SYCH08, 19 October 2014 - 05:45 PM.
#240 _SYCH08_
_SYCH08_
Posted 19 October 2014 - 05:51 PM
back on the ground again was happy with the exhaust clearance underneath its almost hidden
#241 _Old Man Butters_
_Old Man Butters_
Posted 21 October 2014 - 07:22 AM
How does it go over there??? If you can brake from 100 - 0 with zero brake distortion they pass it??? Lmao about looks like it anyway!!!! Lol loving it!!
#242 _SYCH08_
_SYCH08_
Posted 02 November 2014 - 04:56 PM
yep that sounds about right i think its 3x thou from memory
had these made up as well and got a parachute to help
am gunna have to paint the callipers to so they match up
any recommendations as to where to mount the chute body or diff ????
Edited by SYCH08, 02 November 2014 - 04:59 PM.
#243 _SYCH08_
_SYCH08_
Posted 02 November 2014 - 05:06 PM
done the radiator hoses too running -16 hoses hopefully big enough its only a -16 into the water pump
#244 _Agent 34_
_Agent 34_
Posted 02 November 2014 - 05:17 PM
that's a serious machine there
#245 _GMH-001_
_GMH-001_
Posted 02 November 2014 - 07:07 PM
Definately mount chute to diff or chassis in some way. Mounting to body will be disastrous as you will pull the beaver panel off it when chute initially inflates. Unless you can tie in the roll cage to the beaver to prevent it
#246 _SYCH08_
_SYCH08_
Posted 02 November 2014 - 07:13 PM
yep i should have said chassis or diff
#247 _GMH-001_
_GMH-001_
Posted 02 November 2014 - 07:16 PM
Ah well a diff is prolly more preferable. It will sit a little lower than the chassis so will have less tendency to lift the rear of the ground as it inflates
#248 _SYCH08_
_SYCH08_
Posted 01 December 2014 - 05:14 PM
got a blothru carb now carb is a 900cfm C&S with mega bowls and electric solenoids and a crank driven  fuel pump
it is a alcohol carb but can be changed back to E85 or petrol witch ill do but gives  me more options later if its not fast enough
other than that haven't really done much lately
Edited by SYCH08, 01 December 2014 - 05:22 PM.
#249 Ice
  • 15,202 posts
Posted 01 December 2014 - 05:32 PM
Jesus Christ what a weapon this will be
#250 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 01 December 2014 - 07:04 PM
^^^^^^agree^^^^^^
