Street & Strip hatchback
481 replies to this topic
#301 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 30 August 2015 - 08:39 PM
I reckon the exhausts look fine in the open, I would just ceramic coat them for some level of weather protection ...
If using close fitting sheet metal, maybe allow for torque movement and put long slots or even mesh grill inserts in it?
#302 Bigfella237
Posted 30 August 2015 - 08:50 PM
It seems they'll register just about anything over there but surely you wouldn't be allowed to have an exposed white-hot turbo housing?
Plus it would suck driving at night with a massive glowing turbo right in front of you!
#303 _SYCH08_
_SYCH08_
Posted 31 August 2015 - 03:37 PM
yep our laws aren't that good will have to cover them up just in case i run someone over and  they burn themselves haha
#304 _greenmachine215_
_greenmachine215_
Posted 02 September 2015 - 12:04 AM
had a thought with your scoop to cover the turbo's. could you mod your existing scoop and buy another one to cut up and graft on some side pieces and make it a one piece scoop.
think of it as a Walkinshaw bonnet on roids.
#305 _SYCH08_
_SYCH08_
Posted 02 September 2015 - 07:40 PM
have been making some shapes this bonnet will be a plug to take a mound off when were done
something like this then cover the wast gates so will be only the air filters and top of intake poking out hopefully
#306 SHEEL
SHEEL
  • 345 posts
  • Name:Daniel
Posted 04 September 2015 - 12:43 PM
I reckon it looked better just with everything hanging out!!
#307 _SYCH08_
_SYCH08_
Posted 18 September 2015 - 05:15 AM
anyone in NZ im after a bonnet and hinges around waikato area would be good can have hole in it
cheers aaron
#308 _SYCH08_
_SYCH08_
Posted 18 September 2015 - 05:29 PM
so this is where we at made covers for pipes and wast gates.
went and had a chat with cert man this week and my bonnet is out as it turns out everything sticking out is fine its the cowl scoop its to wide with being over  400 wide im only aloud 8m  in front with no scoop im aloud 15m taken from 1/2 way up the windscreen to out in front that makes it over heigth so the fix is a standard bonnet with holes in it and this 1 for racing.
its funny not aloud scoop but am aloud my exhaust uncovered and have to have a bonnet and a hole as big as needed
#309 Bigfella237
Posted 18 September 2015 - 06:50 PM
But it's called "Engine protrusion sight-line" not bonnet protrusion, surely the width of the engine protrusions would be from the outside of one turbo to the other?
Meaning the width of the bonnet scoop is irreverent?
Although I wouldn't even pretend to know the laws over there, that's just how I read what you've posted.
EDIT:
Plus I wouldn't call a Torana an "Open Vehicle", the diagram clearly refers to a no-roof hot rod style body?
Edited by Bigfella237, 18 September 2015 - 06:52 PM.
#310 _SYCH08_
_SYCH08_
Posted 18 September 2015 - 08:15 PM
whoops scanned wrong side
because the turbos are narrower than 250mm im aloud 15m it dosent say how many protrusions im aloud
old rule i guess made for blowers and rams
#311 _SYCH08_
_SYCH08_
Posted 10 October 2015 - 05:11 PM
well got a tin bonnet thanks to j.e.d. on here put it on was working fine till i checked suspension bottom out the wheels hit the hinges so been trying different hinges mk3 cortina seam to be ok
filled the sunroof in as well used a commodore ute roof and some two pot panel glue
#312 _SYCH08_
_SYCH08_
Posted 10 October 2015 - 05:28 PM
so during the week i sprayed some rust kill  stuff inside and today sprayed some more etch primer  through inside then put it up on a rotatory  tomorrow start on the bottom then some colour
#313 _greenmachine215_
_greenmachine215_
Posted 10 October 2015 - 07:27 PM
a street registered pro stock car! our dipshit government really need to chill the f@ck out and let us do this. just think how many less drug addicts would be around if you could do this sort of think and legally.
bonnet looks trick mate, good to see your still chipping away at this. It must be frustrating at times knowing you still have a fair way to go.
#314 _SYCH08_
_SYCH08_
Posted 11 October 2015 - 04:55 PM
our government not much better this country's got plenty of dope heads too
got the under side done today so ill  do a bit of gaping this week then hopefully  some colour  next weekend  :spoton:
yep still a long way to go yet tho
#315 _j.e.d._
_j.e.d._
Posted 11 October 2015 - 06:57 PM
Nice work as usual mate. I know we talked about this but dumb memory...when you cut the replacement panel for the sunroof, did you cut it bigger & step the edge to sit under the lip of the sunroof hole? Is that just some tek screws holding it in place while the panel glue cures?
Tempted to do this with the HQ sunroof. What was the brand & where did you get the 2 pot panel glue? Cheers
#316 _SYCH08_
_SYCH08_
Posted 11 October 2015 - 07:07 PM
yep did cut bigger and step and screwed held it there i don't know the glue ill ask the beater he did say was about $150 a tube its a 2pac black stuff.
#317 Bigfella237
Posted 11 October 2015 - 08:22 PM
Probably some kind of panel bond epoxy, something like 3M Automix
#318 _SYCH08_
_SYCH08_
Posted 18 October 2015 - 06:53 PM
got diff sand blasted during the week and some jam on the suspension and diff over weekend
yep that's the glue for the roof
this is what the bonnet is up to as well were just making a plug for now
all going well tomorrow should have some color underneath too
#319 _SYCH08_
_SYCH08_
Posted 22 October 2015 - 04:12 PM
we have color
#320 _SYCH08_
_SYCH08_
Posted 22 October 2015 - 04:15 PM
got these back from getting coated too
#321 _scrubberv8_
_scrubberv8_
Posted 23 October 2015 - 02:14 PM
looking awesome
  :spoton:
#322 SHEEL
SHEEL
  • 345 posts
  • Name:Daniel
Posted 23 October 2015 - 04:05 PM
Holy Barbados Green Batman!!!
#323 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 23 October 2015 - 04:58 PM
Love your colour choice ....looking good
#324 HIBERN8
HIBERN8
  • 131 posts
  • Name:Mark
  • Car:1974 LH S
Posted 24 October 2015 - 12:59 AM
Looks delicious! Well done! Looking forward to seeing it all come together.
#325 _SYCH08_
_SYCH08_
Posted 24 October 2015 - 07:10 AM
yep barbados it is with black bonnet and windows not sure about the bumpers yet tho
