Street & Strip hatchback
481 replies to this topic
#76 76lxhatch
  • 7,207 posts
Posted 22 January 2013 - 07:37 PM
Ah of course, forgot about the welding rule; I wonder if there is a way to drill and tap a tiny hole for a set screw or something silly, or otherwise remove the valve entirely?
#77 _SYCH08_
_SYCH08_
Posted 31 January 2013 - 06:19 PM
we have a seat and tread on rear tyres I changed the rear tyres from 32 x 16 x 15 slicks to 31 x 16.5 x 15 hoosier quick times in doing this i found the rear rims are 14s not 12s so I thought that's a bonus
now I have a seat I can start to mount steering column and pedals its starting to look more and more like a car :driving:
#78 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 31 January 2013 - 09:53 PM
Seat, engine, wheels, job done!!
Everything else is just extra weight :driving:
#79 _SYCH08_
_SYCH08_
Posted 05 March 2013 - 04:48 PM
Have not been doing much car shit lately fishing has been good tho
Have made new 4 bars cro moly now and started to think about steering column have looked at ididit and flamein river tilt columns but not aloud over here  because they have welded bits in them
so thought about shorting the torana one  this is where I'm stuck  has any body pulled this end off I've taken out roll pin sprayed CRC but it wont move are they pressed in or threaded in
I want to take about 140mm off it  if possible
#80 _SYCH08_
_SYCH08_
Posted 17 March 2013 - 12:40 PM
Went and brought this bearing $21.00 chop down the outer  column about 100mm pushed the old plastic bearing holder up in there then the bearing and factory clip back  then cut 80mm off top inside column and 60mm bottom pushed out roll pin took the top inside and put on bottom re-drilled press roll pin back in that gave me a double D shaft on bottom to match rack.
Then drilled out spot welds on mounting bracket move to top side welded back on. so now we have steering :driving:
#81 _sjp67m_
_sjp67m_
Posted 17 March 2013 - 12:51 PM
Dont you love it when people jusy make things sound so easy
#82 _SYCH08_
_SYCH08_
Posted 25 March 2013 - 06:14 PM
Rear sway bar time brought a competition engineering kit got some brackets cut out [ its dam handy having son work for a profile cutting outfit he cut all my brackets for me for free] and glued them in.
New moly 4 bars too
#83 _SYCH08_
_SYCH08_
Posted 25 March 2013 - 06:17 PM
Piece of cake didn't take very long at all
#84 _SYCH08_
_SYCH08_
Posted 14 April 2013 - 05:13 PM
Brake peddle time brought a willwood reverse swing peddle box and 2 7/8 master cylinders cut out some brackets and glued them on. not planing on running a booster.
#85 _SYCH08_
_SYCH08_
Posted 14 April 2013 - 05:18 PM
Engine mount time aswell am running a engine plate front and 1/4 rear plates.
#86 _SYCH08_
_SYCH08_
Posted 14 April 2013 - 05:21 PM
not done yet but it holds the engine up
#87 _DomDom_
_DomDom_
Posted 14 April 2013 - 10:28 PM
That is AWSOME. Great stuff.
Dom
#88 _SYCH08_
_SYCH08_
Posted 17 April 2013 - 08:19 PM
New toy time got this off old trade me. Nearly ready to start tin work.had to make the stand for it tho.
Edited by SYCH08, 17 April 2013 - 08:21 PM.
#89 76lxhatch
  • 7,207 posts
Posted 18 April 2013 - 08:01 AM
Sweet
#90 _SYCH08_
_SYCH08_
Posted 23 April 2013 - 03:38 PM
Seat time made some lugs up threaded them cut some triangles and glued them on and a nut strap for the harness's
#91 _SYCH08_
_SYCH08_
Posted 23 April 2013 - 03:45 PM
starting the tin work thought would start with the tubbs
#92 _SYCH08_
_SYCH08_
Posted 23 April 2013 - 03:50 PM
nearly ready to play with the swager
#93 _SYCH08_
_SYCH08_
Posted 01 May 2013 - 04:50 PM
Well for all you unlucky Aussies I had my first cert inspection on Monday it  PASSED that is the first time the cert man has seen my car was happy with it
I had to tie the A & B pillars to the roll cage, put some more bracing to peddle bracket  and change the bottom of the steering all has been done.
Makes me pretty happy with me efforts so far.
one thing that maybe a concern is the weight the car has to weigh in at under 1200kg for the size of the chassis been 3x2 that was our aim but do have way round that if we need to.
So defiantly a street car :driving: yeah-arr  jealous much!!!!
#94 _Bomber Watson_
Posted 01 May 2013 - 05:04 PM
Love ya work mate.
Great build.
#95 _SYCH08_
_SYCH08_
Posted 12 May 2013 - 03:31 PM
Tin work had a play with the swager its a neat toy just need the kids to swing on the handle a lot easier with 2 body's
#96 SmacT
SmacT
  • 978 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 12 May 2013 - 04:31 PM
Epic build. Great stuff.
#97 _SYCH08_
_SYCH08_
Posted 19 May 2013 - 05:38 PM
a bit more tin work inner tub to guard this fiddly stuff takes time
  • Attached File  002.JPG   306.76K   3 downloads
  • Attached File  003.JPG   363.64K   2 downloads
#98 _SYCH08_
_SYCH08_
Posted 19 May 2013 - 05:41 PM
took me all morning to do 1 side and about hour and a half for the other side what else do you do when its raining
  • Attached File  005.JPG   330.35K   2 downloads
  • Attached File  006.JPG   356.1K   1 downloads
Edited by SYCH08, 19 May 2013 - 05:42 PM.
#99 _SYCH08_
_SYCH08_
Posted 03 June 2013 - 04:00 PM
done the drive shaft loops and a bit more tin work
more tin
and more
#100 _SYCH08_
_SYCH08_
Posted 03 June 2013 - 04:03 PM
and more just the fire wall gearbox tunnel and boot floor to go
