Street & Strip hatchback
481 replies to this topic
#176 _SYCH08_
_SYCH08_
Posted 15 April 2014 - 04:00 PM
hi jeff
the price i thought wasn't to bad no real option other than getting one out of aussie so if you find something local its a lot less hassle.
still trying to find glass bumpers that's not happing at the moment not much luck emailing alfa Motorsport no reply yet.
John
i did wonder about  putting glass in but i didn't have any   i rang couple glass places today they said good luck so then rang rare spares they had one so handed over my gold now its on its way should be here in couple days got new rubber too
funny really a new windscreen is $350. bills the rear screen was $400.plus freight and tax but that's what rocking horse shit is i guess but now i have all my glass rather have it than not tho
#177 _j.e.d._
_j.e.d._
Posted 15 April 2014 - 07:00 PM
Hey Aaron, just call my mate Jeff (Jeffs Fibreglassing & Fabrication) & he does the fibreglass bumpers & they're only about $100 each he said.
He's based in Tuakau so pretty handy for you, & if you're after doors have a chat with him as I can loan him mine to get moulds off if it works out cheaper for you in the long run (my passenger one just needs some work done to it first).
His number is 021 108 6869, & I said you'd probably be giving him a call.
Here's his f/b page as well:
https://www.facebook...AndFabrications
Hope it works out for ya  :D
#178 _SYCH08_
_SYCH08_
Posted 15 April 2014 - 07:23 PM
cheers for that jase will call him tomorrow
rodney at heads racing in tauranga has door moulds he done my hatch
#179 _SYCH08_
_SYCH08_
Posted 23 April 2014 - 07:04 PM
thought it was time to re-fit engine has not  been in for a while
fits fire wall good plenty of room and the wipers too.
had my rear screen turn up too.
Edited by SYCH08, 23 April 2014 - 07:05 PM.
#180 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 23 April 2014 - 07:05 PM
God that looks like an F/N big carby.
Bigger is better.  :spoton:
#181 _SYCH08_
_SYCH08_
Posted 23 April 2014 - 07:06 PM
a
#182 _SYCH08_
_SYCH08_
Posted 25 April 2014 - 07:52 PM
Question time what is the hight for the nose cone  i'm mounting the support panel and trying to line up the body lines as don't want it to look to droopy in the front.
so on a stock car what is these heights
Edited by SYCH08, 25 April 2014 - 07:55 PM.
#183 _LXSS350_
_LXSS350_
Posted 25 April 2014 - 11:36 PM
In your set-up to mount a cut off radiator support panel you would have to use panel gaps
Doors to fender to plenum panel
Fenders to bonnet to nosecone
One of the things I learnt when doing full chassis is its a painful lot of fit unfit, change it around then fit then unfit (then curse). Its best to cut it out once nailed down on a non movable levelled work skid, and then welding in enough excessive braces on all the bits that will stay. You have to stop everything moving because as I have found a few mm's here and a few mm's there can lead you to excessive drinking and expensive breakages as you throw things around the workshop. (well for me anyhow).... LOL
As per this camaro its a matter of getting the panel gaps and levels right then working out permanent mounting systems.
The front of the Torana fenders and nosecone all bolt to the radiator support, and the bonnet catch pins the centre of the nosecone to the top radiator support panel. But its all about getting it bolted up as the panels will dictate and then balancing the gaps. Obviously perfect min gaps require work but your not dictated as much as a factory chassis. These unibody things have too many variances because of tolerances, years of twists,distortions etc.
To even attempt to transfer measurements like say the nosecone/rad support height from one of my hatchs you would end up in real trouble.
#184 _LXSS350_
_LXSS350_
Posted 25 April 2014 - 11:57 PM
Camaro fitting panel gaps and working out mountings.
#185 _SYCH08_
_SYCH08_
Posted 26 April 2014 - 06:38 AM
cheers colin
i think what i was trying to asking was from back to front if you ran a string line what is the difference is it 100mm or more or less
i have quite a bit of flex in the glass guards probable 50mm.
thats a cool workshop and car
i am off to cut and fold my fuel tank today
#186 orangeLJ
Posted 26 April 2014 - 10:58 PM
Love this project so so much!
Totally mesmerised. Keep up the awesome work
#187 _LXSS350_
_LXSS350_
Posted 27 April 2014 - 03:33 AM
cheers colin
Aaron
Yes obviously when I started cutting out the whole car besides composite panels I also have steel panels which hold their shape. With the edges being ridged I am able to square the panel via the gap from front fenders to door. That then gives you a chance to work out a set of temp holding props. At the start you simply must have quite a few sting lines and a few of those quality hanging line levels that you clip onto the string line. Slide along to make sure your line is tight and straight. I also run a laser line level on a triprod and with the different heads and stuff I can set it up and follow a body line or height from the one level point to any point along the car. It really helped when I replaced the 1/4 panels and outer sills to get them all spot welded in.
I have to walk away during summertime as it is too testing in hot weather for an old bloke. It is really slow and tedious getting it all back square when you don't have any of the standard factory fixing points, but that's the price of a full chassis, repositioned firewall and new floor. Lost count of how many times something is on then off then on again its frightening.
I am actually surprised you didn't do what I am doing and push the firewall back to move the main weight back. Even for drag racing it would help in f-r weight transfer.
#188 _SYCH08_
_SYCH08_
Posted 02 May 2014 - 07:21 PM
folded up this last weekend and bit trimming during the week off to glue up tomorrow
Edited by SYCH08, 02 May 2014 - 07:23 PM.
#189 Bullet
Bullet
  • 217 posts
  • Name:Mark
  • Car:LC 2 Door S
Posted 02 May 2014 - 08:03 PM
Nice job on the tank Aaron, looks shmik!
#190 _SYCH08_
_SYCH08_
Posted 04 May 2014 - 06:17 PM
a
a
a
a
#191 _SYCH08_
_SYCH08_
Posted 04 May 2014 - 06:40 PM
don't know what happen there but tank all glued up now over weekend time to go back to the front again and mount guards and support panel
#192 N/A-PWR
  • 9,639 posts
Posted 04 May 2014 - 07:37 PM
Nice Unit Aaron,
You have come along in leaps and bounds since I first Saw the Hatch ( huge wheel guards ),
and I like the Racing, quick fill Fuel Tank. Dave I
Keep up the Great work
#193 _LXSS350_
_LXSS350_
Posted 04 May 2014 - 09:19 PM
Aaron ... did I notice workshop muddy footprints ... was it another kiwi party weekend ...  i.e. lets catch a girlfriend.
Those poor old kiwi sheep have no chance  .... every-time they hear a noisy kiwi party followed by the Haka and then the sight of many sets of gum boots picking up speed .... its little wonder their bum tightens as they are running for their lives. ..... :clappin:
What fuel pump and delivery set-up are you planning on using?? Fuel economy (and rear tyre wear) is certainly not going to be some of your torana's better features .... LOL
Edited by LXSS350, 04 May 2014 - 09:22 PM.
#194 _SYCH08_
_SYCH08_
Posted 09 May 2014 - 08:53 PM
Heres a bit of porn for you LXSS350 go hard
#195 _SYCH08_
_SYCH08_
Posted 09 May 2014 - 08:58 PM
looking at this set up its a C&S from usa
Edited by SYCH08, 09 May 2014 - 08:59 PM.
#196 _SYCH08_
_SYCH08_
Posted 09 May 2014 - 09:02 PM
these turned up this week 4'' exhaust bends and some 2.5" for wastegates
Edited by SYCH08, 09 May 2014 - 09:03 PM.
#197 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 09 May 2014 - 09:46 PM
local supplier on those bends Aaron, or did you get them from over here?
#198 _SYCH08_
_SYCH08_
Posted 10 May 2014 - 07:42 PM
not local it was cheaper to get from usa than here the bends here are $125.each  so was $320 for 6 and two weeks wait.
I do try to buy local but some things no good have got other stuff coming but thats still 4 weeks away.
today's effort all tacked up
#199 _SYCH08_
_SYCH08_
Posted 20 May 2014 - 04:39 PM
it was time to clean up this corner
and bits
radiator support
#200 _LXSS350_
_LXSS350_
Posted 26 May 2014 - 05:16 AM
Aaron what fuel do you plan on using?
Sort of reminds me of our old 80's solution of "hell lets just hit it with  bigger hammer".
BBC where always a shoehorn job but we never once thought about twin turbo's and 4".... LOL thank god you don't try to put all that under a bonnet. Boy that just fills whatever limited space you have.
All very subtle
