What's the Biggest Aspirated Engine you can put in a HX Ute
Posted 21 September 2012 - 10:35 AM
having trouble finding out exactly how big is too big(if there is such a thing ) when fitting an aspirated engine into a HX ute & getting it rego'd & engineered in VIC?
My 253 shit itself in my HX ute last Friday & my LS1 torana isnt going anywhere for along time so was thinking I would just throw it all in the ute 4 now since it will bolt straight in, bar a few little niggly things like fuel system & a few other mods.
The only thing is its got a Harrop blower sitting on top & I can't be bothered pulling it all of & fitting the std manifold back on.
So anybody out there know if it's ok to throw it in without reverting back to std?
Cheers, Nig.
Posted 21 September 2012 - 10:58 AM
http://www.infrastru...1jan2011_v3.pdf
The wording is a bit misleading when it talks about weights, as it says to base the maximum engine on the tare mass of the heaviest sedan with the biggest engine for the model. In a HX the model is the car itself eg Kingswood ute, Belmont wagon, Premier sedan, Holden van etc. I think they really mean series ie HX series. Which would mean you use the HX Caprice as the heaviest sedan with the biggest engine. One of these has a Tare of 1642kg. So for normally aspirated this would give you 5.0 x 1642kg = 8.210L (around 500ci). Blown is 3.0 x 1642kg = 4.926L (around 302ci). Note that these are the biggest possible, but not necessarily guaranteed to be passed.
Posted 21 September 2012 - 11:57 AM
No one will notice....
#4 _CHOPPER_
Posted 22 September 2012 - 02:14 PM
Posted 23 September 2012 - 01:55 AM
Have a look at the National COP if that is what Victoria now use. Page 11-12:
I Which would mean you use the HX Caprice as the heaviest sedan with the biggest engine. One of these has a Tare of 1642kg. So for normally aspirated this would give you 5.0 x 1642kg = 8.210L (around 500ci). Blown is 3.0 x 1642kg = 4.926L (around 302ci). Note that these are the biggest possible, but not necessarily guaranteed to be passed.
These rules seem so dumb to me.... You can have up to a 500 odd cube engine pushing out bucket loads of torque & power without even breaking a sweat as long as its n/a..... but as soon as its boosted it drops down to a 253/308 cube engine that would make 500 hp max & be that off its head you wouldnt be able 2 drive it anywhere. I just don't see the sence.
You would think it would make way more sence to just go with a power to weight ratio like Victoria's old P plate laws. That way if you got pulled over & "the man" thought the engine is way over powered for the vehicle, you could at least have fun watching you car on the dyno!!!
....and every time you spend $$$ on your car & your miss's asks why your at the tuners again you can say its because you "got done" again & it's the law haha.
#6 _LS1 Hatch_
Posted 23 September 2012 - 02:18 AM
http://paceperforman...ace-engine.html
Posted 23 September 2012 - 09:56 AM
Posted 23 September 2012 - 10:07 AM
#9 _CHOPPER_
Posted 23 September 2012 - 02:49 PM
A 308 with 10 psi boost could make similar HP to a stock 500 CID engine without the extra weight.
Posted 23 September 2012 - 05:16 PM
#11 _Bomber Watson_
Posted 23 September 2012 - 06:03 PM
That would have to be one of the stupidest statements i've heard in my life.
Your average 500ci engine with choice heads/cams/carb etc to make a nice mild streeter might push out 500hp.
You can put 15psi into a 300ci engine with stock cam heads etc and make the same power, with better fuel economy and a smoother idle and far nicer to drive around town.
#12 _tryhard_
Posted 23 September 2012 - 06:21 PM
#13 _Bomber Watson_
Posted 23 September 2012 - 06:26 PM
#14 _shan620_
Posted 23 September 2012 - 06:42 PM
Posted 23 September 2012 - 07:02 PM
All I meant was it doesn't make sence 2 me.... As in you can have your 202ci aspirated monster & have it producing 1000hp or have a 350ci aspirated producing 400hp but the 350ci is the one that's the illegal combo.... even though the 202ci is way,....WAY over powered compared to the 350ci.
I don't see the sence.
As for you saying its the stupidest comment you've ever heard that hurts my feelings bomber ;(
Surley there's been other posts more worthy of that title than that.
Posted 24 September 2012 - 01:20 PM
The use of the word "aspirated" is being used incorrectly here. Aspirated simply means to breathe or inhale. All internal combustion motors, blown or otherwise are aspirated.
What you guys mean is NATURALLY aspirated, because they are only breathing due the pressure of the atmosphere (= 1 bar).
Supercharged or turbocharged motors have forced induction, so they breathe more due to the higher pressure being applied.
Dr Terry
Posted 24 September 2012 - 04:02 PM
i thought i read on the VSCCS that there wasnt a engine size limit on commercials.
I don't think that applies to commercials built on a sedan platform like Holden utes. I think they are referring to vehicles like Hilux, F250 etc. Would be worth checking first though.
Posted 24 September 2012 - 07:06 PM
#19 _Terrible One_
Posted 30 September 2012 - 04:54 PM
Um...theres a few things wrong here. You think a 500hp boosted 308 would be off its head?
Posted 02 October 2012 - 08:49 PM
...... What I was saying was a 1000hp boosted 308ci is legal & a 300hp boosted 350ci is illegal.
THAT is what I don't understand.
#21 _Bomber Watson_
Posted 02 October 2012 - 08:51 PM
What you do with that capacity leaves some realm for imagination
Edited by Bomber Watson, 02 October 2012 - 08:52 PM.
#22
Posted 03 October 2012 - 09:15 AM
#23 _Quagmire_
Posted 03 October 2012 - 12:08 PM
#25 _Bomber Watson_
Posted 03 October 2012 - 05:39 PM
