Removing dents from and straightening stainless trim
18 replies to this topic
#1 _judgelj_
_judgelj_
Posted 24 September 2012 - 04:24 PM
Can anyone share some advice/experiences relating to removing dents and straightening stainless trims such as those on the LC/LJ Torana (drip rail and window trims).
I tried using a punch (bad idea), pinched the drip tray trim which has a curved profile. This may work on the square profile trims below the windows on the door but i have not tried. I'm thinking there are dollys for the job but i'm not sure and can't trial and error my only set. Suggestions on tooling and work surfaces would be good too!
Cheers in advance
#2 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 24 September 2012 - 05:38 PM
You will have to make dollys to suit.
I have used small hardwood blocks in the past to use as a drift from behind.
This is a highly skilled task,good luck with it.
#3 76lxhatch
  • 7,207 posts
Posted 24 September 2012 - 05:39 PM
Have had some success using flat bar with a slightly rounded end onto blocks of wood before, unfortunately it kind of is a trial and error thing as you always seem to get a dent in a different spot and need a different shaped tool to get at it. Stay on the softer side (hitting against a wooden block seems to help a lot) so you don't stretch it, and try to work a larger rather than smaller area at once (so something much wider than the punch)
#4 _judgelj_
_judgelj_
Posted 24 September 2012 - 06:45 PM
That helps quite a bit. The more i look into it the more i realise there is a lot to it and no easy way out. Perhaps what i can try is to make some of my own dollys out of wood.
I was told about nylon hammers of some sort but then again these are very delicate pieces and would not need a big hit to get them straight. The bloke who restored my grille got the dents out without a sign of them every being there i cannot believe it. I always thought there is a crease left by any panel beating no matter what as the metal stretches and does no contract.
#5 _Pete_
_Pete_
Posted 24 September 2012 - 07:51 PM
I have made some nylon dollies/bits out of an old kitchen cutting board to use to tap out dents in trims. I've shaped and smoothed them to suit the mould I'm repairing. I use them like a wedge and hit the wedge with a light panel hammer, using either a sandbag or a block of soft pine to back up the moulding. It's delicate work though but it can be done with a careful touch for not much financial outlay .
#6 Ruts
Ruts
    How Fast!?
  • 1,118 posts
  • Car:Blown A9X replica, Black SS hatchback, LH SLR5000
Posted 24 September 2012 - 07:53 PM
There is actually a DVD you can buy that shows you how to repair stainless trims. The only problem is that I can't remember where I saw it.
Edited by Ruts, 24 September 2012 - 07:54 PM.
#7 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 24 September 2012 - 08:15 PM
http://www.youtube.c...1&v=MlTOg4tb_V8
s
Edited by StephenSLR, 24 September 2012 - 08:15 PM.
#8 _judgelj_
_judgelj_
Posted 24 September 2012 - 09:53 PM
Oh wow i didn't even think of youtube, to be honest sometimes i underestimate the variety of videos it has to offer.
Will give them a watch but im already starting to form some ideas in my head. I think one of the blokes here made a tool to do it but i dont think i have the patience.
#9 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 25 September 2012 - 09:34 AM
Check out this tool.
www.youtube.com/watch?v=AhlG44GxVzg
s
Edited by StephenSLR, 25 September 2012 - 09:39 AM.
#10 _judgelj_
_judgelj_
Posted 25 September 2012 - 03:32 PM
one way to reinvent a pin punch. some how i can't take it too seriously. he looks to be pushing pretty hard, i don't know how this doesn't stretch the metal?
#11 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 25 September 2012 - 04:52 PM
http://www.youtube.c...h?v=AhlG44GxVzg
I reckon its a little beaudy.
#12 Statler
  • 6,315 posts
Posted 25 September 2012 - 05:23 PM
I fitted the gutter mould to 'purple'..... FAIL! :unsure:
#13 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 25 September 2012 - 05:27 PM
I think he means in comparison to other methods where you have to beat a much larger area.
Not sure why the vid didn't work in my link.
s
#14 76lxhatch
  • 7,207 posts
Posted 25 September 2012 - 05:34 PM
Strange thing to say to begin with isn't it, its not much good if you can't stretch the metal with it (when desired). There are heaps of things like this out there but you can get the same results by hand with a hammer and some sort of tooling that doesn't cost you each time you need a different shape - scrap steel is free and its not hard to make almost anything you need.
#15 _judgelj_
_judgelj_
Posted 25 September 2012 - 09:29 PM
Mate i think you know what i meant... Stretched beyond what he intended. Just looks like he has to apply a lot of pressure. I wouldn't be convinced unless i saw it done in person.
#16 76lxhatch
  • 7,207 posts
Posted 26 September 2012 - 06:52 AM
I meant its strange for them to say it, its like saying "our tool won't damage anything because it doesn't do anything"...
Obviously its a nicety that would be useful in a situation where its difficult to control the force applied and this allows a bit more control and finesse. I don't think its necessary though as it can still be done with a hammer and punch (or suitable custom shaped "tool").
#17 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 26 September 2012 - 09:00 AM
My guess is there'd be one or two shapes that you'd use the most and having another shaped piece at the ready would be more convenient than spending time to make up something custom.
s
#18 76lxhatch
  • 7,207 posts
Posted 26 September 2012 - 11:28 AM
That's true for general panel work but once you get into the finicky stuff like this you end up making something different nearly every time. When I say tooling I just mean shaped pieces of steel or whatever works, the difference with enthusiasts is that we're happy to spend 10-15 minutes making something so that the end result is as close to perfect as possible rather than just selecting the nearest match off the shelf
#19 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 26 September 2012 - 01:14 PM
:iagree:
That's what it's all about.
s
