173 and a holley 350
_Kevy_
Posted 30 September 2012 - 05:43 PM
Posted 30 September 2012 - 05:51 PM
I'd be inclined to leave the 61's as well, but with no real experience with a 350 on a holden six thats a guess. .
_Torrie_Man_
Posted 30 September 2012 - 10:33 PM
_Quagmire_
Posted 01 October 2012 - 06:24 AM
i've had holley 350/500's on 302's and 253's/308's and they work fine
you just need to stay on top of the tune and jet em right which is easy enough at home with a few tools
_Kevy_
Posted 01 October 2012 - 06:31 PM
Posted 01 October 2012 - 06:58 PM
_judgelj_
Posted 01 October 2012 - 09:32 PM
Posted 01 October 2012 - 09:40 PM
_judgelj_
Posted 01 October 2012 - 10:40 PM
Posted 01 October 2012 - 11:01 PM
considering i've used a 600 on a mild 202 i'd say a 350 is a bit small lol.
overkill and you know it bomber
Posted 02 October 2012 - 03:52 AM
Edited by slr_v8, 02 October 2012 - 03:52 AM.
_oldjohnno_
Posted 02 October 2012 - 04:24 AM
Another thing I've found with the two barrel Holleys is that it takes more than just jet changes to get the best of both power and economy out of them. They tend to be quite rich off idle and at part throttle cruise and need bigger IABs and/or smaller IFRs to correct this. If you just jet it for all round performance the mileage is usually pretty ordinary even though there is no hesitations or flat spots. The 500s in particular also tend to have a rich peak at the very top end and need bigger MABs to address this. Thorough tuning makes a huge difference to the performance and especially the mileage of these things, and there's a big difference between one that's merely been jetted to run cleanly and one that's been tuned to give a constant fuel curve right through the range.
Definitely avoid those MickeyMouse sleeves, they're just a crutch for poor tuning or sizing. For a stock or stockish engine I think the Falcon Weber is a better choice than the 350.
Posted 02 October 2012 - 05:41 PM
Yeah that's the interesting thing.Try telling that to some people and they will spit their sausage at you
Admittedly i had the stiffest secondary spring in it haha, did slide the second stiffest in and it went a bit better, third stiffest was to soft. So yeah, to big, but it was just to prove a point to a mate on his combo (202, touched over yt stage 3, crow 626) that the 350 the engine shop he was going though convinced him to buy was to small hehe....
Posted 03 October 2012 - 06:33 AM
_oldjohnno_
Posted 03 October 2012 - 06:57 AM
600cfm isn't to big, 3x2" SU's flow much more than that.
True, but the different style of manifolding with the SUs means that the engine needs the extra flow.
Getting back to single carbs on a common plenum, I haven't tried a 500 Edelbrock on a 202 but I suspect that its secondary design would work very well on a six.
Posted 03 October 2012 - 05:41 PM
I love reading your posts johnno and the write up on building a holden 6 is legendary. Keep them coming. Yours and Dr Terry's posts are informative and constructive.True, but the different style of manifolding with the SUs means that the engine needs the extra flow.
Phillip
Posted 03 October 2012 - 06:15 PM
_Kevy_
Posted 03 December 2012 - 07:34 PM
_Quagmire_
Posted 04 December 2012 - 02:19 AM
yeah...but if you do the same with a 2bbl stromie and replace with a 4 bbl quaddie/holley on a 308I used to run a vacuum secondary 390 4BBL Holley on a mild 202, on a Cain manifold (old style big runner, not the later Redline style). It went pretty well, and was OK on fuel. It was just a blue bottom end with 30/70 Waggot cam and Yella Terra head with extractors. From memory it dynoed at about 100-110hp at the rear wheels. It was a much better car than the same engine with a 350 on it, especially on fuel. I used to tow my ski boat with the car (LX hatch) and the 390 was much better on the boat ramps than the 350. It was a Celica 5spd and 3.08:1 Salisbury, 265/50/14 tyres. It wasn't really any more powerful with the 390 over the 350, just more driveable.
you get the same result...if your careful with the right foot
Edited by Quagmire, 04 December 2012 - 02:19 AM.
Posted 14 January 2013 - 03:09 AM
Hi warrenm,
I found this 650cfm 2bbl carby for a good $1000:-
http://dambest.com/carbs/index.html
http://dambest.com/b...es/6502bbl.html
Looking forward to some extra flow. Dave I
Edited by TORYPOWER, 14 January 2013 - 03:15 AM.
#21
Posted 15 January 2013 - 02:19 AM
Just added another 2bbl as we don't have a dedicated Carby thread,
This 2bbl Holley, part #6425 ( normally 650cfm) has been bored out to 735cfm:-
http://www.vendio.co...orm/lid=4242801
would do very well on a Fully worked Six. Dave I
Edited by TORYPOWER, 15 January 2013 - 02:20 AM.
#22
Posted 15 January 2013 - 05:16 PM
#23
_oldjohnno_
Posted 15 January 2013 - 07:55 PM
As for doing well on a fully worked six, I can't imagine it running well at all with anything less than 450 - 500hp; numbers that are waaaaaaaaaay over anything I could dream of getting from a NA 202.
#24
Posted 15 January 2013 - 08:16 PM
#25
_oldjohnno_
Posted 15 January 2013 - 08:23 PM
