Torana power steering kits.
172 replies to this topic
#1 axistr
axistr
  • 1,212 posts
Posted 01 October 2012 - 07:20 PM
G'day Guys,
I am still getting many emails asking about power steering and power steering kits, most of the answers can be found in the power steering thread, but due to so many pages to look through trying to find the answer I thought maybe it's time to start a new slimline version.
My situation is this, yes I am still doing the power steering kits due to so many Torana owners asking me to help them out.
I thought most of the interest had passed due to the slow down in orders and inquiries a while ago, but when I posted that I may stop doing them for a while.( due to Job changes, selling Axis Truck Repairs and moving house), I have been bombarded with inquiries & people asking for information. It seems that many owners have their Toranas in the build or near compleation and were going to get a kit off me at a later date, but I didn't know that at the time.
As I have said before these kits take a hell of a lot of hours to complete and are very labour intensive. To date I have built around fifty kits and I will need to do around twenty kits a year to make it worth while. I am now doing them from home and this has enabled me to concentrate a bit more on making more jigs to reduce the time involved in doing them. I also have an engineering shop laser cut some of the parts which saves me around three hours per kit, but I feel this is needed to enable me to concerntrate on puting the kits togeather.
Firstly I would like to thank everyone that has helped and supported me along the way. I know it took a while to get the whole power steering thing up and running so the least I can do it keep making them so we can all drive around tight corners one handed.
Some of the most common Questions asked are.
1) Do I supply the power steering pump & brackets.
Ans: No due to so many engine and belt drive systems fitted to these cars I found it to be to much of a head bang, If it was only four or five versions I would carry them. If you need a pump I can supply a new unit but I need to know what brackets you are using ect. My advice is with a V8 holden just get a VL pump setup and mount it on the front of the left head.
2) Cost.
Ans: I still invoice them through my company name Axis Truck Repairs P.L. Due to the sale of the business I have kept the name but my accountant has deregisted us for G.S.T. So invoices from now on will not have G.S.T added.
The kit will have a total price of $2,800. plus freight.
3) What is included in the kit.
Ans: The moded & reco rack assembly with new tie rods & ends is supplied mounted in the bracket which mounts to the Torana LH.LX.UC K-frame without any mods. The new tie rods come attached and are set to centre so you should be able to drop it straight in. The steering column adaptor included allows for a direct fit to the original Holden rag joint coupling, and two hydraulic fitting so the installer only needs to fit the supply & return hose connection from the pump.
4) Which rack do I get, and what tie rods do I get.
Ans: Everyone now asks me for the variable ratio rack so thats all I now supply. If in the future you need new tie rod ends, they are off the shelf at Repco. If you need the part number just email me with your rack kit number and I will give it to you or I can supply the rod ends for you. I have loged every rack built with all the specks writen down.
5) What steering arms do I use for the new tie rod ends.
Ans: I ask for the owner to send me their arms to me which I check & ream free of charge with the kit. The new tie rod ends have the same automotive tapper, but I like to set the tie rods a little deeper in the steering arm and cleen up the tapper to make sure its all good. If you are running LH front end setup use LH arms, LX use LX arms ect. You can use UC arms on LH & LX. If you are running HQ/A9X stubs you need to run A9X or Harrop arms.
P.S I do not need to ream new Harrop arms.
6) Will the kit fit with my big brakes,
Ans) Yes the kit will fit with after market big brake setups, but check to make sure you dont have any interferance problems with the standard Torana manual rack, if you dont have any issues with the torana rack you shouldn't have any dramas with the power steering setup.
7) Will the kit fit with an early Chev, Gen3 or V6
Ans: The kit has been fitted with Holden V8 & 6cyl inline. I have not supplied a kit for a Holden V6 yet but I would think sump mods would be needed. Chevy engines are no problem but Gen 3 engined will need around 15mm removed from the sump to clear the mount bracket on the drivers side. Tim A.K.A (dirtbag) pioneered this sump mod ( thanks Tim ) and can be seen in his brothers UC build thread.
Note: Hydraulic fittings.
Due to the lack of room on the Gen3 conversion I needed to supply more compact fittings, I have gone for banjo fittings and now supply all rack kits with these fittings. They are much more compact but more care must be taken when fitting. The racks are not realy designed for these fitting, but work well. Just make sure the copper washers are seated correctly and tight. Over tightening will streatch the banjo bolt and could leak down the track. I also recomend rechecking the banjo bolts a few weeks after installation.
I hope this has answered a few questions but feel free to ask as this is why I have started this thread.
Just for the record my hatch has now racked up just over 8,000 km since the conversion and haven't had to put a spanner to it.
Feed back.
After building just short of fifty kits I have only had two phone calls in relation to fitting inquiries. All the kits are assembled using a near new K-frame to make sure there are no clearance issues, if for any reason you do, you might have a slight bend or twist in your K-frame this should be easy to overcome with a bit of common sense.
But I would like a bit of feed back on any problems if any, and what has been you experience. What do you think of the overall driving experience. ? And do you think I could improve in any areas.
Many Thanks Lenny ( axistr )
Attached File  finished rack.JPG   40.74K   158 downloads
#2 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 01 October 2012 - 10:59 PM
:clappin: :clappin: Glad you have decided to continue to make the kits Lenny and i hope you get the required sales to make it worth while for you to keep going in the future.
I for one still would like to get one but now have to start saving again, after you said you were not making them anymore i had given up on power steering.
Once again, congratulations on continuing with the kit, you have made a lot of Torana owners happy again.
#3 Ando
Ando
  • 527 posts
  • Car:6/'76 L32 SS white & black. 9/'76 L31 SS gold. 5/'77 L31 SS Chamois. 3/'79 UC SL Deluxe hatch.
Posted 02 October 2012 - 06:37 PM
Hi Lenny,
Good to hear that you are continuing with the racks! I'm a canidate for a future purchase some time next year.
Thanks for clearing some of the questions I have had in mind. I did talk to you at Toranafest & will contact you when the time is right.
John
#4 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 02 October 2012 - 07:36 PM
I'm also a candidate, especially if you intend to produce A/C systems as per your car as well!
#5 _LXSS350_
_LXSS350_
Posted 13 October 2012 - 01:23 AM
Good to see Torana owners still get a chance to get a hold of your excellent rack conversions.
First rack with the plastic engine should be ready for a track test sometime over the next month.
This will run a KRC aluminium pump and tank. (not fitted up yet)
#6 axistr
axistr
  • 1,212 posts
Posted 15 November 2012 - 07:04 PM
Looking good LXSS350, carn't wait to see photos of the finished car, look neat.
Does the sway bar clear the tie rod bar by much ?
Lenny.
#7 _LXSS350_
_LXSS350_
Posted 16 November 2012 - 03:45 PM
At least an inch on any travel and/or lock.
#8 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 26 November 2012 - 01:05 AM
Best modification I ever made to my car was your rack Lenny. Thanks again for the time and effort you have put into these kits, has transformed the way the car drives.
Dave
#9 axistr
axistr
  • 1,212 posts
Posted 28 February 2013 - 06:58 AM
I have finally caught up on my rack orders and have even managed to put two power steering kits into stock ready to go. If any fourm members are after a kit just P.M. me.
Lenny.
#10 Cognac
Cognac
  • 36 posts
  • Name:Steve
  • Car:LH SLR 5000 - LX L31 SS
Posted 07 April 2013 - 12:44 PM
Hi Lenny,
Thanks for all your help and advice with the power steering conversion on my SLR5000. What a difference this brilliant conversion makes.
For anyone considering this mod you won't go wrong, Lenny produces a beautifully finished product and backs it up with first rate advice and help.
Thanks mate
#11 axistr
axistr
  • 1,212 posts
Posted 08 April 2013 - 07:42 AM
Thanks Steve, I am glad your happy with the power steering, now there is no reason why your wife can't drive it to.
Edited by axistr, 08 April 2013 - 07:43 AM.
#12 _PAC5000_
_PAC5000_
Posted 01 May 2013 - 09:33 PM
Hi there , not sure when you wrote this article but ! I have an lx torana 1977 sedan ,
Do u have the kit for it ? U still in the business ? Do u have stock now ?
Pac5000
Hi again, my torana has 308 black block, vn headed FYI , alternator on drivers side
Cheers pac5000
#13 axistr
axistr
  • 1,212 posts
Posted 02 May 2013 - 07:23 AM
G'day pac5000,
Yes I am still doing the power steering kits, I am doing some more kits for stock and hope to have some ready soon.
Best to hunt down a power steering pump & mounting brackets and pully off a VL V8 commodore as they bolt up to the front of the left hand side head so you can retain your alternator setup on the right.
Lenny.
#14 Dr Terry
Dr Terry
  • 3,325 posts
Posted 02 May 2013 - 09:22 AM
G'day pac5000,
Lenny.
To add to Lenny's comments, I believe that any Commodore V8 from VB to VL with provide the necessary pump & bracket kit for a Torana V8 conversion.
Dr Terry
#15 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 02 May 2013 - 12:10 PM
Those pumps wont fit if you're using a stock EFI banana manifold, throttle body is in the way.
#16 Dr Terry
Dr Terry
  • 3,325 posts
Posted 05 May 2013 - 08:24 AM
That is true, but we were only talking about keeping the original V8 alternator bracket intact. If you're running an EFI V8 just use the alternator & power steer se-up that it came with.
Dr Terry
#17 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 05 May 2013 - 03:51 PM
That's what I was going to do but the EFI P/S pump hits the chassis rail (maybe you'd have enough room if you trimmed the lip off the rail?  :dontknow:  ). I ended up using a Torrie alt bracket and modified a VL p/s bracket to suit a VK 6cyl pump with the remote reservoir. Was a PITA to figure out but works good now.
#18 axistr
axistr
  • 1,212 posts
Posted 06 May 2013 - 08:18 AM
I overcome the problem with the EFI engines by fitting a type 2 Sagnal pump to the right head and modifying the original VS air conditioner bracket to suit the new style compressor. The water pump serpentine pully has more grip than it looks in the photo, very hard to try and turn by hand.
Attached File  lhpump.jpg   89.34K   49 downloads
#19 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 06 May 2013 - 09:21 AM
it would spin the wrong way
#20 ls2lxhatch
  • 5,332 posts
Posted 06 May 2013 - 11:03 AM
It would still turn in the same direction but it would require a smooth pulley on the water pump which would probably slip.
Edited by ls2lxhatch, 06 May 2013 - 11:05 AM.
#21 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 06 May 2013 - 11:23 AM
very rarely disagree with you andy,
but if that belt is running from left of screen, over the pulley, to right of screen, that pump is turning clockwise, if the belt goes under the pulley it now turns anticlockwise.
#22 axistr
axistr
  • 1,212 posts
Posted 06 May 2013 - 11:49 AM
Yep the pump would spin in the wrong direction if it went under and thats why I didn't go in that direction. LT chev water pumps are reversed and I have see a couple of people stuff up when changing to gen 1 style drives systems.
#23 ls2lxhatch
  • 5,332 posts
Posted 06 May 2013 - 02:17 PM
Not sure how I got that backwards , but I did. :dontknow:
#24 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 06 May 2013 - 06:12 PM
#25 _missrb30_
_missrb30_
Posted 06 May 2013 - 06:21 PM
how come you don\'t run the belt underneath the water pump pulley?
Dumbest question of the year ? Hehehe
