- Sand blast shell and and fix all the rust and get the body smooth and give it a nice paint job
- interior will be pretty much stock but will get a roll cage and a bench seat.
- will be doing a weld in chassis strenghtening kit
- rear end will be a 9" aswell as minitubs
- Engine is getting built by horse power engineering in qld, plans for engine are 355 cubes, callies compstar h beam rods, mahle forged pistons, 4 bolt mains conversion and a solid roller cam. heads will be hand ported vn heads flowing around 300cfm with a torque power pro paw single plane hi rise manifold. estimated hp will be between 550-600hp at the flywheel. Auto will most likely be a manualised trimatic with a 5500 rpm stall convertor. Car will be registered and driven on a regular basis and will see the 1/4 mile as often as possible. Aim is for it to run a 10.50 or better!!! also should mention wheels will be convo pros with some decent dish on the rear and hope to get a 265 or 275 under the rear with the minitubs. As soon as it has been sand blasted will have the engineer come look at it then start the chassis kit and minitubs!! anyways heres a progress pic, cheers ryan
![Posted Image](https://cache.gmh-torana.com.au/i125.photobucket.com/albums/p60/tuffgmc/torana3012_zpsee386e80.jpg)
