Nice looking 'old school' ute,sometimes going taller gears will give worse economy because the smaller engine will have to labor
for you to get up to speed which means foot buried more than usual.
I think a six usually ran 355 ratio on the stock wheel/tire combo. which equated to about 3000 rpm @ 100 kph....just above peak torque of engine.
A healthy 'in tune" 253 on 336 gears will probably give better economy if driven 'normally'(whatever that is),but because there is a bit extra
'power' there it will get used which may pull the the numbers down a bit.
Other alternative is a good six with triple SU's...you would be surprised at difference they make in pulling power...they won't rev harder on a stocker but get up nicer and make nicer power curve,,,bit of a cam and it would go a bit harder and still nice to drive....
Edited by EunUCh, 23 October 2014 - 05:33 PM.
