cheers in advance for any info
Posted 10 October 2012 - 07:20 PM
Posted 10 October 2012 - 09:49 PM
Posted 11 October 2012 - 12:02 PM
Posted 12 October 2012 - 01:23 AM
Personally I'd use the factory bolt hole, in an accident you have the force distributed between four anchor points not three.
A shame they come with that elongated mount but my guess is it'll be hidden away.
s
Edited by torbirdie, 12 October 2012 - 01:32 AM.
Posted 12 October 2012 - 07:51 AM
Steve the force isn't divided up between four anchor points
Would it be ok to use the one mounting pt in those where there are two floor mounting points. My best reckoning would be yes as possibly to meet standards the one point should be able to take all the force from that side
Edited by StephenSLR, 12 October 2012 - 08:03 AM.
Posted 12 October 2012 - 09:39 AM
The inertia reel type actually doubles the force that would be seen on the upper pillar and the floor mount and whether the mounts have been engineered for this on say an LJ is anyone's guess.
Edited by StephenSLR, 12 October 2012 - 09:42 AM.
Posted 12 October 2012 - 10:08 AM
Having another think about this, yes the upper mount would definitely experience an increase in force with a change from static to inertia reel with loop - not exactly double though.
I'm still convinced however if you mount to 4 bolts, each bolt will experience less 'trauma' in an impact than if you mount to 3 bolts.
I may have been thinking about the kinetic energy that's distributed between the four and my point is agreeing with what you're saying, let's say each lower side bolt does experience 25% each, it's better to mount to 2 lower side bolts than just one as that one bolt would then experience 50%.
Edited by torbirdie, 12 October 2012 - 10:22 AM.
Posted 12 October 2012 - 10:19 AM
The centre pillar pulley arrangment can only decrease the force on the floor mounts if there is significant/incredible friction across the belt.
Edited by StephenSLR, 12 October 2012 - 10:20 AM.
Posted 12 October 2012 - 10:42 AM
Edited by torbirdie, 12 October 2012 - 10:48 AM.
Posted 12 October 2012 - 10:52 AM
Use a centre pillar mount and suspend equal weights each side
Edited by StephenSLR, 12 October 2012 - 10:59 AM.
Posted 12 October 2012 - 11:09 AM
The diagram above has circled the load indication areas. The top mount definitely experiences load.
To do the experiment correctly one would install stress/strain meters on the two lower mounts then put the car in an accident for test one.
Then for test two remove the top mount completely and record the stress/strain on the two lower mounts.
Edited by torbirdie, 12 October 2012 - 11:19 AM.
Posted 12 October 2012 - 11:26 AM
Very convenient Stephen, your thinking will remain correct until someone gives you two lj's to crash into a brick wall along with a test dummy?
Edited by StephenSLR, 12 October 2012 - 11:30 AM.
Posted 12 October 2012 - 12:20 PM
what is wrong is your interpretation that the centre pillar reduces the load on the floor mounts in an inertial reel arrangement.
Edited by StephenSLR, 12 October 2012 - 12:35 PM.
Posted 12 October 2012 - 12:59 PM
Ah, I've just got it, I think the above is the misunderstanding in our debate.
I didn't exactly say the centre pillar reduces the load on the floor mounts, show me where I said that.
. I was confused as how you could think the top mount doesn't experience any forces.
Edited by torbirdie, 12 October 2012 - 01:00 PM.
Posted 12 October 2012 - 01:29 PM
here is what you did say:
what you have written here indicates that at the time of writing you believed that the total force necessary to arrest the occupant has distributed amongst four different points
Edited by StephenSLR, 12 October 2012 - 01:30 PM.
Posted 12 October 2012 - 04:25 PM
Edited by SLR Goat, 12 October 2012 - 04:27 PM.
Posted 12 October 2012 - 05:03 PM
lets just agree to disagree i think either mouting hole for the lower front plate will work okay either way while wearing the belt it sits even doesn't get caught or twisted and the locks work when i jolt forward
Posted 12 October 2012 - 06:34 PM
Posted 12 October 2012 - 06:55 PM
All good mate hows the band doing i think i have you on MSN messenger but i havent used it for ages
Posted 13 October 2012 - 10:13 AM
Posted 13 October 2012 - 10:47 AM
Yeah that was me way back before facesook came along
Posted 13 October 2012 - 01:18 PM
Posted 13 October 2012 - 07:54 PM
Got a SLR never had interest in buying a jeep must have me mixed up with someone else
