lj ignition switch wiring
6 replies to this topic
#1 TOERUNNER
TOERUNNER
  • 630 posts
  • Name:RODNEY
  • Car:73 lj gtr 73 lj 2 dr S
Posted 13 October 2012 - 01:19 PM
can anyone help me with the ignition switch wiring in a lj please,i am just refitting the wiring harness,i have plugged the large plug into the ignition switch but there is a single female spade terminal with 2 dark green wires in the same harness,there is 2 spare male terminals on the switch itself,does this wire plug onto one of these , cheers rodney
#2 TOERUNNER
TOERUNNER
  • 630 posts
  • Name:RODNEY
Posted 14 October 2012 - 02:03 PM
anyone???????
#3 rodomo
  • 18,039 posts
Posted 14 October 2012 - 03:33 PM
Did this used to be column auto? If my memory is correct, dark green is reverse lights.
#4 TOERUNNER
TOERUNNER
  • 630 posts
  • Name:RODNEY
Posted 14 October 2012 - 06:42 PM
thanks rodomo,the reverse wires are green but they go on the neutral switch at the base of the column in a auto,these green wires must go to the ignition switch,just not sure which terminal,or if they are spare,cheers rodney
#5 S pack
  • 15,726 posts
Posted 14 October 2012 - 06:44 PM
The Dark Green wire should be the temp light test wire. Plug it onto the vacant male spade connector inline with and at the opposite end of the ignition switch to the violet wire.
Edited by S pack, 14 October 2012 - 06:45 PM.
#6 TOERUNNER
TOERUNNER
  • 630 posts
  • Name:RODNEY
Posted 14 October 2012 - 07:23 PM
cheers s pack ,huge help , it's been nearly 4 years since i pulled the loom out, i marked all connections but must of missed that one, thanks mate cheers rodney
#7 S pack
  • 15,726 posts
Posted 14 October 2012 - 07:41 PM
No probs Rodney.
BTW, I presume this is your LJ S with warning light dash we're talking about?
