how to date code v8 engine blocks
v8 engine date code identific
44 replies to this topic
#26 yel327
  • 13,630 posts
Posted 11 December 2012 - 10:52 AM
Only one side on red blocks. It'll be 308 for sure on a 1971 cast block. HP was basically finished by the end of 1969. You only really find HP on HT Brougham engines plus a few months in other HT's. They are almost always 1969 cast blocks although the odd late 1968 and (from memory) early 1970 engines have turned up.
#27 v8xu1pete
v8xu1pete
  • 319 posts
  • Name:Pete
  • Car:LJ XU1 V8 (SALAMANCA RED)
Posted 11 December 2012 - 11:31 AM
Thanks for the info yel327. So, I'm reading my date code J151 as 15/09/71, a HQ engine, is that correct. Which side will I find the 308, driver or passenger, & will it be near the front or rear of the block.
#28 yel327
  • 13,630 posts
Posted 11 December 2012 - 12:39 PM
In between the back and 2nd from back welch plugs on the starter motor side of the block, directly above the water gallery drain plug. Will be one of the following:
Blank (early 253)
HP (early 308)
308
253
308 (on both sides) - black 308/304. Not sure if blue 253 and 308 past VK introduction had designation on both sides.
5.0L on both sides (VN - mid VR from memory)
Blank (Mid VR onwards 304 and 350)
#29 v8xu1pete
v8xu1pete
  • 319 posts
  • Name:Pete
Posted 11 December 2012 - 01:05 PM
Thanks mate, will check it out. Have I interpreted my date code correctly.
#30 yel327
  • 13,630 posts
Posted 11 December 2012 - 01:09 PM
Yes.
#31 _NZLH_
_NZLH_
Posted 15 December 2012 - 06:47 PM
Help please.I have a 253 with block number OR140027 and Timing cover number B232 and head numbers 2812174 anyone know what they mean? thanks
#32 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 15 December 2012 - 07:41 PM
253 out of a HQ, I think.
That should be QR, not OR, as the engine number prefix.
Edited by slr_v8, 15 December 2012 - 07:43 PM.
#33 v8xu1pete
v8xu1pete
  • 319 posts
  • Name:Pete
Posted 16 December 2012 - 12:21 AM
Date code B232 reads 23rd February 1972, engine no QR140027, in regard to the head number, HQ, most HJ, LH and early LX start with 28 so this is consistent with it being a HQ engine.
#34 TerrA LX
Posted 20 December 2012 - 07:44 PM
^ I third it being a HQ engine and am interested to know if it is rope seal (which I assume it is).
#35 v8xu1pete
v8xu1pete
  • 319 posts
  • Name:Pete
Posted 21 December 2012 - 08:35 AM
Block on left is first gen red neo seal, one on the right is second gen red rope seal.
Notice the difference on the rear boss where the dowel pins are?
The rear boss of my block date code J151 matches the pic on the left, so I presume mine has a neo rear seal. The 308 casting appears to have been ground off, perhaps when it was stroked to 355.
#36 TerrA LX
Posted 21 December 2012 - 08:22 PM
Oh yeah, caught up in the festive season :banghead: .
Thanx for clearing that up
#37 Statler
  • 6,314 posts
Posted 09 January 2013 - 02:36 PM
Date code of 73N4 on a QT block. Does that sound right?
#38 Blair
Blair
  • 67 posts
  • Name:Blair
  • Car:1974 LH SLR5000
Posted 31 March 2022 - 06:33 PM
my engine block is A282, any idea on what this means?
#39 S pack
  • 15,717 posts
Posted 31 March 2022 - 07:01 PM
A282. 28th January 1972.
#40 Blair
Blair
  • 67 posts
  • Name:Blair
Posted 01 April 2022 - 04:21 AM
Thanks, car is a 1974 Holden Torana SLR5000, A282 would suggest the engine was made 2 years before car. The actual engine number on block isnt readable... could this be wrong engine since it was made 2 years before the car? or is that normal?
#41 hanra
  • 10,968 posts
Posted 01 April 2022 - 04:54 AM
Not the original engine.
#42 Blair
Blair
  • 67 posts
  • Name:Blair
Posted 01 April 2022 - 05:01 AM
how do you know
#43 S pack
  • 15,717 posts
Posted 01 April 2022 - 06:41 AM
how do you know
No HT prefix 308 Torana engines were cast in 1972. The engine in your Torana is out of a 1972 HQ Holden. The engine number prefix will be QT.
The only other possibility is it could be an NT prefix NASCO replacement block.
Edited by S pack, 01 April 2022 - 06:42 AM.
#44 Blair
Blair
  • 67 posts
  • Name:Blair
Posted 01 April 2022 - 01:34 PM
O right. Thanks for that info.
#45 Dr Terry
Dr Terry
  • 3,324 posts
Posted 02 April 2022 - 07:39 AM
The other possibility is a 11QT prefix out of an HQ Statesman.
Dr Terry
