Burtys UC To LX Conversion
#26
_berro59_
Posted 01 November 2012 - 10:54 PM
I am also originally a Darwin boy. How do you go with flash panel rust with the extra humidity?
The Torrie is looking great.
I have done the UC to LX conversion my too. Hard work but worth it!
Well done cant wait to see updates.
#27
Posted 02 November 2012 - 08:18 AM
I picked up the lanolin at a bearing shop.
#28
_berro59_
Posted 02 November 2012 - 11:13 AM
I will look into that myself.
I put a phosphoric acid over the panel. But it is a lot dryer here.
#29
Posted 02 November 2012 - 10:00 PM
Just been looking through you thread, much bigger job than I have to do. Realised as I got to the pages with photos of the rear end that I had looked through it before.
You can tell I used your method for the tail lights! Dirtbags was a lot more involved drilling out the spot welds and replacing the whole rear panel. I must thank you for providing the method. I went with it as seemed simpler and my UC was in very good condition so the least amount of cutting the better.
Thats the cool thing about this site, without it I either would not have attempted the conversion or tried it and made a big f****n mess!
I will take a photo of the lanolin can soon, it is also available at Landmark (the old westfarmers shops)
#30
_berro59_
Posted 03 November 2012 - 09:45 AM
Dirtbag was the reason I had a crack at the grafts too. GMH is awesome for info like that.
Yes unpicking and removing the whole rear panel is hard work but a lot easier to get the tail lights to be symmetrical. You will also get better access to hidden rust areas.
I laughed when you wrote about being scared to get the grinder in to the car for the first cut.I was the same! It takes big balls to do it. Especially as your UC it looked decent before the graft.
Mine conversion was hard work removing the inner guards and dash but I wanted it to look like LX/A9X
keep up the good work.
Berro
#31
Posted 04 November 2012 - 01:17 PM
Just thought I could shortcut the process! Dynamat etc and the like, have also seen foil backed foam with adhesive about 10mm thick. First hand report would be good.
#32
_berro59_
Posted 04 November 2012 - 05:44 PM
#33
_sjp67m_
Posted 04 November 2012 - 06:55 PM
About to start on the interior of the Torrie. Any recommendations with sound deadening materials? Im sure there is pleanty of threads and I am about to start searching.
Seen dynamat on a few customers cars they swear by it but I've never actually applied it
Locally cool drive are the stockists
#34
Posted 04 November 2012 - 07:52 PM
I do know it's expensive and there is a cheaper alternative that looks the same.
#35
_dirtbag_
Posted 05 November 2012 - 07:13 AM
#36
Posted 05 November 2012 - 05:53 PM
#37
_sjp67m_
Posted 05 November 2012 - 06:03 PM
Going to give dynamat extreme a go. Also going to use 10mm adhesive foam with foil backing instead of carpet underlay. I will take pleanty of pics as I go.
If you want give me a call 0451171575 I'll get you trade price
#38
Posted 05 November 2012 - 07:48 PM
#39
_sjp67m_
Posted 05 November 2012 - 09:42 PM
Bugger! Got too keen and ordered what I needed off ebay. Thanks for the offer anyhow.
Lol ok it's just I know they actually keep it Im stock surprising for Darwin !
#40
Posted 08 November 2012 - 08:13 PM
Posted 08 November 2012 - 08:15 PM
Posted 08 November 2012 - 08:19 PM
_sjp67m_
Posted 08 November 2012 - 08:31 PM
Also are you using anything to seal after ? Ie seam sealing the edges ?
Got a seam sealer gun was thinking of laying all the sound deadner down them sealing it in ?
#44
Posted 08 November 2012 - 08:39 PM
#45
_sjp67m_
Posted 08 November 2012 - 09:14 PM
#46
Posted 20 January 2013 - 07:56 PM
Time to start some more work on the front end. You can see where the front scoop meets the flares I had to cut a small wedge out.
While the scoop was bolted on I fibreglassed the seam from behind.
I put about four layers on the back of the flare to keep it rigid. Once dried the flares are now fixed in the position I wanted and the front scoop lines up with them nicely.
#47
Posted 20 January 2013 - 08:10 PM
It was a pain in the arse to weld in but we got there.
Also removed the old mounts for the UC headlights, hopefully I will start on the new mounts this week ( Thanks Franky!)
#48
Posted 21 January 2013 - 07:38 PM
Posted 21 January 2013 - 07:51 PM
Once the fibreglass was set I removed the spoiler. It now fits nicely back onto the flares and nosecone.
Posted 21 January 2013 - 09:17 PM
