Burtys UC To LX Conversion
134 replies to this topic
#126 burty
burty
  • 153 posts
  • Name:BURTY
  • Car:UC torana
Posted 12 June 2019 - 09:25 AM
Interior finished and cleaned up, still obviously a UC dash and console but not changing it, said from the start not trying to hide the fact it is a UC besides I don't mind the dash and console plus its in such good condition.
I do have a couple of questions if anyone can help.
1. I still have no idea what the front seats are out of?
2. I have a gremlin in the wipers. When wipers are in the off position they sometimes randomly move halfway up the windscreen and stop. Not sure if its an earth problem or the wiper motor itself? So if anyone has had this happen before would appreciate any advice.
#127 burty
burty
  • 153 posts
  • Name:BURTY
  • Car:UC torana
Posted 12 June 2019 - 09:28 AM
New tires fitted. The old ones still had plenty of tred but were so old they were as hard as stone and probably would have fallen to bits if used.
#128 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 12 June 2019 - 12:17 PM
Ah the old UC done up as an LH/X. Probably be my next torana :-)
Job well done.
#129 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 12 June 2019 - 01:27 PM
Looking awesome! Is it ready for cruising yet?
re the wiper motor, there's a few threads around here on getting them to stop in the right spot. I had to rebuild mine, will see if I can find the how-to thread I used.
#130 burty
burty
  • 153 posts
  • Name:BURTY
  • Car:UC torana
Posted 12 June 2019 - 01:38 PM
Almost ready for cruising, should be registered by Friday & perfect cruising weather up this way this time of the year.
I did take a look at posts relating to wipers but none seem to relate to my issue? As mentioned they work fine 99 percent of the time just randomly move 1/4 to 1/2 way up the windscreen at times. Could possibly be the switch? As you know the UC has the wiper switch on the steering column, I'm not sure if the rest of the wiring set up is the same as the LH/LX?
I'm probably best putting it on the tech issues forum and see what feedback I get.
#131 burty
burty
  • 153 posts
  • Name:BURTY
  • Car:UC torana
Posted 25 July 2019 - 02:37 PM
Finally took the Torana on its first official cruise, was a great day in Darwin "Cruise for a Cause" and received lots of positive comments on the car. Didn't finish quite so well, smoke poured out from under the dash and engine bay 20 feet from parking at the finish of the cruise. Ended up riding home in the front of a tilt tray!
Turns out the thermo fan sh%t itself and cooked the switch, relay and wiring, further investigation once getting it home revealed there was inline no fuse. Luckily there was no further damage to the rest of the wiring everything is still working fine. I have decided to revert back to old school metal fan and fan shroud rather than rewire with new thermo fan.
  • Attached File  Car.jpg   42.24K   9 downloads
#132 RallyRed
  • 8,147 posts
Posted 25 July 2019 - 02:49 PM
lucky...could have neen much worse.
Car looks nice.
#133 burty
burty
  • 153 posts
  • Name:BURTY
  • Car:UC torana
Posted 25 July 2019 - 03:21 PM
Very lucky was not a good feeling at all I had visions of it burning to the ground. Quickly parked it, disconnected the battery and had X3 dry chemical extinguishers on standby.
#134 Rockoz
Rockoz
  • 4,032 posts
  • Name:Rob
Posted 25 July 2019 - 08:12 PM
One reason why I like having stuff on relays mounted close to the item using the power.
Keeps all the switches inside opening and closing very low currents.
That way it minmises the chances of the electrical stuff losing its smoke.
All electrical equipment is filled with smoke.
Once you let the smoke out you have problems.
It is really hard to put the smoke back in. But it can be done.
The easiest way is to buy new stuff that is fully charged with smoke.
Glad for you that it wasnt a whole heap worse.
Rob
#135 burty
burty
  • 153 posts
  • Name:BURTY
  • Car:UC torana
Posted 11 November 2019 - 08:54 PM
Managed to pick up BROCKY number plates. They used to be on a Prado up here but lapsed 2 years ago. Also had a dummy drop tank cover made and fitted.Attached File  55C93F10-4046-43BB-96A3-7B02A927667F.jpeg   108.47K   2 downloadsAttached File  55C93F10-4046-43BB-96A3-7B02A927667F.jpeg   108.47K   2 downloads
