keeping moisture out of compressor lines
26 replies to this topic
#26 _Quagmire_
_Quagmire_
Posted 28 May 2013 - 02:02 AM
Check out using 'brine water'. By simply adding some salt into your water/ice mix the temperature can be somewhat colder.
I'm too lazy to google it but you should have a read. Might be worth a try and it wont rust the copper. :google:
sounds pausible as
salt water doesn't freeze well
and it boils at a higher temp too :)
would dry ice work?
or would it be too cold?
#27 _Bomber Watson_
Posted 28 May 2013 - 07:48 AM
I dont think dry ice would contact the pipe as well as water.
And yeah the brine works we used it in the nade engine, got the water in the esky to -3 degrees, crushed up ice and salt.
