best head for 202
_qiksix_
Posted 04 November 2012 - 05:01 PM
Yes i know there are the jzeds(too many $$$ for most of us) duggans etc(if you can find them) but what else is out there, i've even seen ford heads on some, comon guys throw some ideas.
Getting bored might need a new project.
Posted 04 November 2012 - 05:08 PM
Basically, from what i gather, and generalizing a bit.
Drag racing, excluding jzed or duggan, you want a 9 port.
Hot street/drag you want a 12 port
Mild street you want a 12 port
Ford heads if you are handy with a mill and a lathe and feel like a frOck around.
_Quagmire_
Posted 04 November 2012 - 05:37 PM
Posted 04 November 2012 - 07:05 PM
just get a yt cheap and frockin easy
but not as effective and in the end will cost you more than a jzed.
Posted 04 November 2012 - 07:07 PM
Posted 04 November 2012 - 07:10 PM
Posted 04 November 2012 - 09:04 PM
_Quagmire_
Posted 05 November 2012 - 07:20 PM
only if your chasing mega horsepower....but not as effective and in the end will cost you more than a jzed.
and if your doing that the bottom end becomes the weak link
Posted 05 November 2012 - 08:16 PM
Posted 05 November 2012 - 10:10 PM
he did say he wanted the best head....
i would never use one again on an aspirated deal, if it had 20 psi in it that would be a different story.
_STRAIGHTLINEMICK_
Posted 06 November 2012 - 07:13 PM
Did u find a lack of low rpm torque?he did say he wanted the best head....
_Quagmire_
Posted 06 November 2012 - 07:21 PM
maybe check the yellow pages under escorts.....he did say he wanted the best head....
well somebody was going to say it.... sooner or later
Edited by Quagmire, 06 November 2012 - 07:22 PM.
Posted 06 November 2012 - 07:35 PM
no idea this was on a drag race eng but they are all the yt alloy's are open chamber.
After it was ported, chambers welded, hardened seats and guides replaced, machined and filled with good stuff the jzed looks real cost effective.
Posted 06 November 2012 - 09:15 PM
_Ned Loh_
Posted 07 November 2012 - 02:04 PM
Best budget head would be blue hi-comp bolt on.
IMHO
- best budget head. Black EFI.
- best base for moderate engine. Small chamber 12 port (or blue high comp as Rodomo calls it)
- best all out max hp is probably JZED, but I've not had anything to do with one.
_STRAIGHTLINEMICK_
Posted 07 November 2012 - 08:38 PM
Yep i agree ,a max effort alloy 12 port will cost at least 4 grand without rockers,getting close to JZ cost.no idea this was on a drag race eng but they are all the yt alloy's are open chamber.
_qiksix_
Posted 08 November 2012 - 09:52 PM
Posted 08 November 2012 - 09:54 PM
Looking into it
_qiksix_
Posted 08 November 2012 - 10:22 PM
_torbirdie_
Posted 08 November 2012 - 11:42 PM
"It was removed off a running car"................ Rofl........by Usain unBOLT ?
Edited by torbirdie, 08 November 2012 - 11:52 PM.
#21
_oldjohnno_
Posted 09 November 2012 - 02:53 PM
That's what i thinking too bomber, i'm an aspirated fan, don't know what it'd be like without a turbo. Did oldjohno ever get his done or further along.
Still not finished. Building a couple of 12 port manifolds at the moment, once they're out of the way I'll try to get the other engine finished.
#22
Posted 09 November 2012 - 04:31 PM
#23
_qiksix_
Posted 09 November 2012 - 05:01 PM
#24
Posted 09 November 2012 - 05:38 PM
i know of a 202 with a iron yt 12 port that just spun the rollers to 298rwhp on pump fuel with a flat tappet.
#25
Posted 09 November 2012 - 06:54 PM
Heres a thought... 9 port 173, VN valves and springs, good port job (I just bought a die grinder with steel and alloy bits) screw in studs, 1.6 roller rockers, bigger cam than I already have. Mmmmmm, grunt anyone???
Sounds like a good way to make very little HP.
Quick six, yeah mines mostly a joke and something to frOck around with when im bored, havnt actually done anything yet, nor do i have a car to put it in lol.
Kev, interested?
