LX V8 Exhaust Manifolds - Need Help!
9 replies to this topic
#1 _sstorana_
_sstorana_
Posted 13 November 2012 - 02:15 PM
Hi Guys,
trying to work out if I have the correct Exhaust Manifolds for my LX SS Hatchback.
Now the problem that I have is this... In the Parts Books, it states that the nubers are;
Exhaust Manifold - LH: 9930044, and
Exhaust Manifold - RH: 7436026 (Pre ADR27a), and
9934332 (ADR27a)
Now, What I have here, for the LHS is: 9930043
The thing is that I cannot find this part number in ANY Parts Catalogue from HQ through to VL.
Is this the correct one for the LX V8? Was it a misprint when they manufacturered them?
Now for the RHS. I have two different manifolds...
One has no part number cast into it. All it has is the word "Holden" on one side and a casting date of "27G7" on the inner side.
The other RHS Manifold that I have has the part number; 9941751 cast into it.. Again, I cannot find any reference to this number in any catalogues.
All I want to know is do I have an original one out of these two. I am leaning towards the first RHS one as it was on the car when I brought it.
Any help would be appreciated!!
Mick
#2 hanra
  • 11,033 posts
Posted 13 November 2012 - 03:02 PM
The info that obtained Mick is:
Drivers side 7437802 and passengers side 7424983.
I went through all this here:
http://www.gmh-toran...nra#entry656747
#3 _sstorana_
_sstorana_
Posted 13 November 2012 - 03:12 PM
Hi Brad
I assume that is for LH and not LX (post ADR27a)
Mick
#4 dattoman
Posted 13 November 2012 - 09:25 PM
As you know casting numbers and part #'s aren't the same thing
But someone will confirm I'm sure
#5 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,428 posts
  • Name:facebook dave
Posted 13 November 2012 - 11:11 PM
mick
i believe the rhs manifold on the lx has the long bolts to allow the fitment of the
block that contains the butterfly valve as per adr27a
i think the block is still available ex usa
as they were pretty much a standard gm part used by gm aust
cheers davemc
#6 _sstorana_
_sstorana_
Posted 14 November 2012 - 06:55 AM
mick
cheers davemc
Thanks Dave,
If anyone can ID the other rhs manifold, that would be great too.
Mick
#7 TerrA LX
Posted 14 November 2012 - 09:13 AM
mick
Pre 6/76 LX do NOT have the butterfly valve.
Can't help with part numbers but one would presume the short bolt one is pre 6/76 ADR27 and the long bolt one is post 0/76 ADR27a.
#8 TerrA LX
Posted 14 November 2012 - 09:28 AM
Top one looks like RHS Blue motor (all).
Bottom one looks like RHS Red motor (all)
Hope that helps.
#9 _1ARC_
_1ARC_
Posted 14 November 2012 - 09:58 AM
I have a RHS manifold with cast no. 7437802 with the two holes where the auto choke pipes fit into, for an LH set up, are welded. I guess that these were fitted to late LX. I have heard of the term 'butterfly valve' but I am confussed as to what it is. Does anyone have a photo of a manifold with butterfly valve set up?
#10 _sstorana_
_sstorana_
Posted 14 November 2012 - 11:18 AM
The "butterfly valve" is called the Exhaust Heat Valve.
I have just found this in an old Gregory's Manual for HX-HZ V8.
Looking at the picture form the Gregory's Manual, It looks like the bottom manifold in my pic is for HX-HZ (albeit less the long bolts)...
If that is the case, it looks like the top manifold is Torana LX - ADR 27a...
can anyone else confirm this??
Mick
