Holden 202 engine block number
13 replies to this topic
#1 _CHEVED_
_CHEVED_
Posted 25 November 2012 - 07:40 PM
Hi can anyone tell me any info about a 202 block ser number HL 30399 what type and year Torana is this out of cheers.
Edited by CHEVED, 25 November 2012 - 07:40 PM.
#2 yel327
  • 13,630 posts
Posted 25 November 2012 - 07:53 PM
I don't have really comprehensive records for LH-UC engines, but this one is probably late LH or possibly early LX. It is a high compression 202. Once you get into 6/76 HL prefix is manual only, autos were XQL, but prior to 6/67 both were HL prefixed.
#3 _CHEVED_
_CHEVED_
Posted 25 November 2012 - 08:25 PM
Thanks for the info how are the numbers deciphered I'm after an early LH 1974 202 cheers.
#4 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 25 November 2012 - 08:46 PM
Don't the engine have some sort of code on them to say when the block was made? It would be good to check if I buy a LJ.
#5 _Skapinad_
_Skapinad_
Posted 26 November 2012 - 07:15 AM
yep, behnd the oil filter is the cast date....
#6 yel327
  • 13,630 posts
Posted 26 November 2012 - 07:18 AM
There is nothing to decipher in the number, it is the 29398th engine stamped for LH-UC Torana. This includes all 1.9L (starfire), 138, 173, 202, 253 and 308 engines used in the three series with a H engine number prefix plus any 130ci exports that may have made their way into LH (if any).
Don't get too concerned about how early or late it is. If it isn't original to your car that HL engine is as good as any other one.
#7 _Mike73_
_Mike73_
Posted 28 November 2012 - 08:46 PM
Your HL 29398 was before HL 7182* which was produced November 1977 so that means yours was produced before 1978 that is all my very breif record on HL engines reveals.
You need the last number of the code behind the oil filter to give you the year.
Mike
#8 _CHEVED_
_CHEVED_
Posted 29 November 2012 - 06:23 PM
Cool so what are the year codes for a 1974 LH Torana 202 engine block if u have this info it would be much appreciated cheers.
#9 liswar2
liswar2
  • 1,524 posts
  • Name:Wazza
Posted 12 February 2025 - 07:20 PM
How about. a HL 57068 number ?
Whats this from please, any one ?
#10 S pack
  • 15,717 posts
Posted 12 February 2025 - 10:04 PM
LH/LX Torana 3310cc (202ci) High compression.
Highly likely out of an LX Torana.
Edited by S pack, 12 February 2025 - 10:08 PM.
#11 liswar2
liswar2
  • 1,524 posts
  • Name:Wazza
Posted 13 February 2025 - 02:01 PM
Thanks….
#12 liswar2
liswar2
  • 1,524 posts
  • Name:Wazza
Posted 13 February 2025 - 02:08 PM
Nice recon .060 , mild cam stage 2
#13 yel327
  • 13,630 posts
Posted 13 February 2025 - 05:41 PM
I think that is LX around 5-6/76, from a manual car. But I don't have a huge amount of these recorded so timeframe might be out a bit. Autos used QL engines or XQL if after ADR27A introduction.
#14 claysummers
claysummers
  • 3,625 posts
  • Name:Clay
Posted 13 February 2025 - 08:09 PM
Yella terra block, wink, wink…….
