help needed
8 replies to this topic
#1 _les_
_les_
Posted 15 June 2006 - 11:04 AM
Can anyone tell me the part number of the screw that holds the arm rest on an LJ or if it is the same as most other Holden�s
#2 jpxu1
jpxu1
  • 570 posts
Posted 15 June 2006 - 03:11 PM
Hi Les,
Part # according to the LJ (June '75) Parts Book is 9416846. Same for front and rear/rear quarter.
Don't know whether it is common throughout the Holden range, but it's not listed in the HQ book or the LC book but I would imagine the screw is the same in LC's.
(The LC parts book refers to a generic listing of all screw sizes and you have to guess)
Hope this helps :spoton:
Cheers,
jpxu1 :D
#3 _les_
_les_
Posted 15 June 2006 - 06:36 PM
Hi Les,
Cheers,
jpxu1 :D
jpxu1
Thanks that what I needed
#4 _torana05_
_torana05_
Posted 16 June 2006 - 07:37 AM
Les, The lh-lx-uc have the same screw as the lc-lj, but they are longer.
Cheers,
Andrew.
#5 _les_
_les_
Posted 16 June 2006 - 11:53 AM
Cheers,
Andrew.
Andrew
Can you tell me the length of the LJ one from under the head to the point
Les
#6 _torana05_
_torana05_
Posted 19 June 2006 - 04:11 PM
Les, They are 2.5cm
Andrew.
#7 _les_
_les_
Posted 20 June 2006 - 07:38 PM
Les, They are 2.5cm
Andrew.
Thanks Andrew
Now for question no2 are the spark plug lead holder in demand on LH LX V8
#8 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 27 June 2006 - 07:06 AM
the ones that go onto the tappet covers? or the ones that hold all 4 leads together? either way, i'd say yes.
#9 _Yella SLuR_
_Yella SLuR_
Posted 27 June 2006 - 09:40 AM
Like these ones:-
Not reproduction, but new ones available from Eagle, with 11mm Eagle silicon leads. Pretty neat setup, provided that the extractors don't melt the plastic. Did have dizzy set up at 1 o'clock (Standing in front of car looking at the engine) when first fitted, but some leads didn't fit. Had to spin the rotor/dizzy round to 8 o'clockish position. All leads fit well now.
