2K Primer Questions
15 replies to this topic
#1 warrenm
warrenm
  • 2,118 posts
  • Car:1972 LJ Torana
Posted 29 November 2012 - 08:39 AM
I've got some questions for the painters.
I've been reading other posts about using 2K primers & Epotec 408 seems to be in common use, but I can't get this without ordering it, & waiting several days for delivery.
I can get HiChem products locally, is the "2K Epoxy Primer" the same sort of product?
Can all body fillers be used over these primers as I have a nearly full tin of "Super Bog"?
I intend to use an Acrylic colour coat & the info sheet for the Epotec 408 says that it isn't suitable under acrylics.
After seeing how dirtbag used 2k around the door openings etc. can this process be used over areas that have already been primed with acrylic primer surfacer & spray putty, as I don't really want to rub it back again.
Edited by warrenm, 29 November 2012 - 08:53 AM.
#2 TerrA LX
Posted 29 November 2012 - 09:24 AM
One question for you, can your hi chem supplier answer your questions?
Can you find a local, supplier of products who can?
This will help your selection alot if you have a good honest dealer you can talk to.
To answer your question honestly (and my opinion is more of an amateur than a pro) if you want a top quality finish and you don't know what you are doing (no offence) then you are really better off sticking with the one system and the one brand and following their instructions (and MSDS) to the letter.
This is one reason why when you take a half baked job into a pro to finish they usually want to strip it back and start again.
#3 _mikecatts_
_mikecatts_
Posted 29 November 2012 - 10:01 AM
Hi...
If using ANY 2k primer. It has to go on bare metal only... Making sure to condition the metal before and and make sure NO acid is left behind.. really pay attention to this step.
You cannot go over acrylic of any kind.. and 408 over lead fill only as well.
You can put acrylic primer over the 2k when done.. Making sure to cover any bog with the 2k...
Im currently using Epotec 408 as my holding primer..When panel work is done,, The 408 over ANY bog/filler then acrylic primer surfacer, then some "light" spray putty, then primer surfacer then colour...
Not too sure about other brands..
I got the run around and people said that I can etch prime, then 2k.. Nope... no acid based primers of ANY kind under 408.. I had to take ALL the etch off... what a job as most of the car was done in it... We live and learn..
I used thinners, sanding and sand blast to get the etch off...
Hope this helps..
Mike
http://www.gmh-toran...r-xu-1-rebuild/
page 8-12 might help you.
Edited by mikecatts, 29 November 2012 - 10:02 AM.
#4 warrenm
warrenm
  • 2,118 posts
Posted 29 November 2012 - 11:26 AM
Thanks for your input. Looks like this project will stay all acrylic, next project I'll use the 2k primer setup.
Thanks Mike I knew someone had given a heap of info but couldn't remember who.
The local supplier is a spare parts shop, with limited knowledge that is mainly the info from the product sheets.
#5 71xu1
71xu1
    Dave
  • 1,275 posts
  • Car:LC GTR XU1
Posted 29 November 2012 - 01:47 PM
A good product for your application is the dulux autospeed 488-s0014 2k epoxy primer. I will post up the data sheet when I get a chance. Will go over bare metal, seals acrylic, can be bogged over. Rubs mint good stuff. As with any 2k product make sure u adhere to correct OHS.
#6 _Bomber Watson_
Posted 29 November 2012 - 05:53 PM
Hi...
Not Quiet. 2k Urethane primers can generally be put over an acrylic, epoxy's yeah not really.
Epoxy's dont have to be over bare steel, they can go over previously painted 2k surfaces, polyesters and phosphates, though its kinda pointless using an epoxy with a phosphate.
Phosphates must go over bare steel, not over anything else. There pretty pointless IMO, i like epoxy's better as there more versatile.
Hope this clears it up a bit.
Edited by Bomber Watson, 29 November 2012 - 05:55 PM.
#7 71xu1
71xu1
    Dave
  • 1,275 posts
  • Car:LC GTR XU1
Posted 30 November 2012 - 12:10 AM
Sorry Bomber I dont get what you mean in the first sentence.
Cheers Dave
#8 _hatch black_
_hatch black_
Posted 30 November 2012 - 06:05 AM
Heres the process i use on all my restos,bare metal,deoxodine. then 2 coats of ppg epoxy eurathane,let dry over night or more key up with 240 grit paper body filler where needed followed by another coat of epoxy then 2k hi fill(wet onwet process) let epoxy flash of for about 20 mins,then put what ever top coat on.cheers hope this helps
#9 _Bomber Watson_
Posted 30 November 2012 - 07:11 AM
Cheers Dave
That most urethane 2k primers can be put over acrylic laquer.......
#10 71xu1
71xu1
    Dave
  • 1,275 posts
  • Car:LC GTR XU1
Posted 30 November 2012 - 09:42 AM
Cool Bomber thats my understanding of epoxy and what I have done with no problems. A mate of mine who was a paint rep suggested I try it. I found the autospeed a joy to use and so far seems to be holding out quite well over the acrylic and older repairs.
cheers Dave
#11 _Bomber Watson_
Posted 30 November 2012 - 10:00 AM
Ah i get ya now.
Yeah look theres a million products and although the basics have similarities there still all different.
Some urethanes cant go over acrylic, most can, some epoxy's can go over acrylic, shouldnt, just how it is haha.
#12 TerrA LX
Posted 30 November 2012 - 10:04 AM
I like the sound of the dulux autospeed.
#13 71xu1
71xu1
    Dave
  • 1,275 posts
  • Car:LC GTR XU1
Posted 30 November 2012 - 06:30 PM
I will try and post up the teck data sheet for it but yeah real enjoyable product can even be rubbed dry with 120/180 on the speedfile to flatten slight ripples out, crispen swage lines up a bit and to pick up lows it does this without too much clogging of the abrasives. It,s not really designed to fill but it also does fill quite well. Steps I use take off any crazed or flaking paint, rub whole car over with ecenentric sander with 120 grit dry, autospeed 2 coats, bog repairs recoat 2 coats autospeed rub 320 wet some will argue but I like to rub wet to keep the dust down, 3 coats of acrylic primer wet rub 600grit and finally colour.
Cheers Dave
Edited by 71xu1, 30 November 2012 - 06:34 PM.
#14 71xu1
71xu1
    Dave
  • 1,275 posts
  • Car:LC GTR XU1
Posted 30 November 2012 - 11:49 PM
Attached File  488S0014 AutoSpeed 2K Epoxy Primer.pdf   95.08K   52 downloadsAutospeed info sheet.
#15 warrenm
warrenm
  • 2,118 posts
Posted 01 December 2012 - 06:34 AM
Thanks again. The Dulux product looks like a good thing.
#16 _Bomber Watson_
Posted 01 December 2012 - 08:22 AM
That looks pretty cool, seems to think its an epoxy and a urethane :D.
Best of both worlds? Must get some and find out.
