Uc torana v8 dual exhaust?
17 replies to this topic
#1 Torana_Boy
Torana_Boy
  • 157 posts
  • Name:Danyon Michalkowski
  • Car:UC torana
Posted 08 December 2012 - 02:48 PM
G'day guys
I'm installing a 253 into my uc. In fine with the conversion but I need some advice on the exhaust.
I want to run a dual exhaust.
Has anyone got photos or seen a dual exhaust over the diff and out the back in a uc with out modifying the body? I don't think there is enough clearance because of the different fuel tank.
Or my other 2 options are dump before the diff or just after and have the pipes sticking out behind the wheel like old pontiacs.
What are people's thoughts/advice
#2 _Brookes_
_Brookes_
Posted 08 December 2012 - 06:35 PM
UC Torana V8 Dual Exhaust Australia
Cannot find much info for you, but came across this image…
#3 Torana_Boy
Torana_Boy
  • 157 posts
  • Car:UC torana
Posted 08 December 2012 - 08:53 PM
Cheers mate I've got the extractors just trying to find the best way to run them
#4 _The Baron_
_The Baron_
Posted 09 December 2012 - 09:51 PM
Essentially the same for A9X but the diff centre is bigger.
I have a big drop tank with dual 2" which took 3 visits to the exhaust shop and then a bit of customer hammer work on a bend over the top but sits OK now.
Can be done!
#5 Torana_Boy
Torana_Boy
  • 157 posts
  • Car:UC torana
Posted 16 December 2012 - 09:02 PM
Excellent! Did you chop out the spare wheel well to fit the drop tank?
#6 _The Baron_
_The Baron_
Posted 16 December 2012 - 10:37 PM
Nope, Drop tank has a relief for the LH/LX (& A9X) spare wheel divit, where the tyre leans against the diff hump. UC, as you know, stands the spare up to one side.
Is that your real issue? getting past the spare wheel bulge?
#7 _V6 UC_
_V6 UC_
Posted 16 December 2012 - 11:41 PM
U will have to change the fuel tank to run twin zorst out the back. No room for drivers side.
#8 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 17 December 2012 - 07:38 AM
I would have expected that the RH tail pipe would have run under the chassis rail member on the floor, it being outside where the tank sits. Surely any worthwhile exhaust shop could tweak an LX tail pipe to sit in the location properly, or just make one out of 5 or so mandrel bends.
#9 Torana_Boy
Torana_Boy
  • 157 posts
  • Car:UC torana
Posted 17 December 2012 - 05:25 PM
Sorry what I meant was to fit the drop tank did you remove the uc spare wheel well so the tank sat between both rails like a LH-LX. Or was it in a A9X?
I would like to think a exhaust shop could get one to fit too. As it is my 6cyl exhaust sits under the chassis on the LHS and it looks like she'll fit on the drivers side just never seen the dual exhaust on a uc yet
#10 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 17 December 2012 - 06:14 PM
I had an LH/X twin system on our UC for years without any drama's, just had to twist the tailpipes around slightly to clear everything.
#11 Torana_Boy
Torana_Boy
  • 157 posts
  • Car:UC torana
Posted 17 December 2012 - 08:49 PM
That's exactly what I want to hear! The exhaust shop said It can't be done. So ill be going else where :)
#12 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 17 December 2012 - 09:23 PM
Exhaust shop could easily mod the tailpipes to fit better than I did, sounds like they couldn't be stuffed?
#13 Torana_Boy
Torana_Boy
  • 157 posts
  • Car:UC torana
Posted 17 December 2012 - 09:46 PM
Yeah I went to the 'best' exhaust shop in hobart they're doing my mates lx dual exhaust but won't do mine. Ill find someone. Whilst on the subject what size would you recommend for a mild 253. I don't want it to be quiet but not over the top. I was told 2 1/4 was the biggest I should go
#14 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 17 December 2012 - 11:22 PM
I was running a 253 with that twin exhaust, it was a 2'' system. Heaps big enough for that motor and sounded pretty sweet imo....
#15 Torana_Boy
Torana_Boy
  • 157 posts
  • Car:UC torana
Posted 18 December 2012 - 05:07 AM
Excellent 2" it is. Cheers for all your help mate!
#16 _The Baron_
_The Baron_
Posted 18 December 2012 - 07:29 PM
Yep A9X with a big drop tank!
#17 Torana_Boy
Torana_Boy
  • 157 posts
  • Car:UC torana
Posted 17 March 2013 - 07:29 AM
Just a update in case anyone else is looking for the info I was. The exhaust shop used a twin lx system and on the drivers the bloke chopped the drivers tail pipe. He re routed the tailpipe and it sits down a bit lower than the tail pipe but not lower than the bottom control arm mount. You can't even tell when the cars on the ground.
Ill take more photos when it stops raining :)
46247BFE-6B8C-4784-B4E3-AA690E7B7770-635
#18 _Dave350ko_
_Dave350ko_
Posted 09 March 2014 - 08:05 PM
Just wondering how hard is it to get a mod plate for 350 chev into a 76 lx hatch was a sl 253 I'm in Qld Mackay any help would be greatly apresiated thanks Dave
