Difference between LC and LJ
73 replies to this topic
#26 _toranatime_
_toranatime_
Posted 22 December 2012 - 10:01 AM
Hmm they are different as i have just found out. I bought a set of repro guards and nosecone cheap from someone who had purchased and wasn't using them. The nosecone is lc and on the box of the guards it said they were to suit lj, and well of course i didn't check my original lc guard for differences because they were so damaged. So now i don't know what to do. The guards are fixed on and all panels are aligned but my headlight surrounds do not fit.
Will lj headlight surrounds fit if i modify the inner edge to fit up to the lc grille? Has any one done anything like this?
#27 S pack
  • 15,717 posts
Posted 22 December 2012 - 10:58 AM
The bonnet catch and support are not the same on LC - LJ.
I stand corrected again. The lock lever is different.
Dave.
#28 Bullet
Bullet
  • 217 posts
  • Name:Mark
  • Car:LC 2 Door S
Posted 22 December 2012 - 12:04 PM
I'll be in the same boat as you bud, keen to see if anyone has been down this road before.
Cheers Bullet
#29 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 22 December 2012 - 12:29 PM
Why not modify the LJ guards to fit LC headlight surrounds? Its only a small change...
#30 _oz772_
_oz772_
Posted 22 December 2012 - 01:38 PM
I think the inner front doors are different as well. The LJ's have a hole in front of the door handle for the ashtrays to recess into; LC doors don't have that hole.
#31 _LONA-CK_
_LONA-CK_
Posted 22 December 2012 - 06:53 PM
that is also correct oz772
Yeah Right. Thanks Guys. appreciated
I was mainly interested in body identifiers - I recently looked at a GTR car being sold as an LJ, but had clearly started life as an LC. Was just wanting check what to look for in this case.
I have a reasonable idea of XU1 Identifiers, So I was keen on just overall body difference.
Edited by Shaune, 17 December 2012 - 10:31 AM.
easy answer has the rear quater indicator lights been welded or bogged up or have they changed the rear quaters???
and the answer to the fellar that have lj guards on there cars and want them to be lc get a oxy a dolly hammer and a drill and go to work not to hard, just becareful how much heat you apply.
look fellars there are many changes between these 2 models 69 is dif to 70 and 70 is dif to 71 and 71 is dif to 72 and 72 is dif to 73...4cyl are dif to 6es and in there year they are also dif to each other, you would be here all xmas tring to write it all down has said before you need year as well as model
cheers gong
Edited by LONA-CK, 22 December 2012 - 06:57 PM.
#32 Bullet
Bullet
  • 217 posts
  • Name:Mark
  • Car:LC 2 Door S
Posted 22 December 2012 - 09:05 PM
Cheers LONA-CK for the advice, one question though, whats the drill for???
#33 S pack
  • 15,717 posts
Posted 22 December 2012 - 10:01 PM
You have to drill a hole and cut a slot in the outer face of the guard for a clip. You'll notice on the LC headlight bezel there is a screw hole in the upper ribbed part of the bezel, if thet make sense.
#34 _LONA-CK_
_LONA-CK_
Posted 23 December 2012 - 03:09 AM
S pack is on the money
and you will need to drill the hole under the first hole and then file this into a little square for the same clip
cheers gong
#35 _LONA-CK_
_LONA-CK_
Posted 23 December 2012 - 03:29 AM
here is a more clearer pic i found
cheers gongPosted Image
#36 dascind
dascind
  • 220 posts
  • Car:71 LC GTR
Posted 23 December 2012 - 08:53 AM
Gong
re the pic you have just posted. What is the colour of this Torry - looks like my Duchess Gold.
Cheers Dave
#37 Bullet
Bullet
  • 217 posts
  • Name:Mark
  • Car:LC 2 Door S
Posted 23 December 2012 - 12:39 PM
Cheers again for the info Gong, I know what I have to do now.
Looks like you just need a bit of patience and its doable.
Cheers Bullet
#38 _LONA-CK_
_LONA-CK_
Posted 23 December 2012 - 01:31 PM
hi dave i just pulled the pic from another members thread, it is dg
cheers gong
#39 dascind
dascind
  • 220 posts
  • Car:71 LC GTR
Posted 24 December 2012 - 07:30 AM
Gong - DG is indeed a very rare colour.
This pic makes it No. 3 in this colour that I am aware of - mine, Qld Torry Club and now this one.
ta Dave
#40 N/A-PWR
  • 9,636 posts
Posted 25 December 2012 - 06:50 PM
The LC GTR had an Ashtray in the Dash:-
#41 _Emu_
_Emu_
Posted 25 December 2012 - 11:16 PM
^^^^^ LOL, nice trim :D
#42 N/A-PWR
  • 9,636 posts
Posted 25 December 2012 - 11:44 PM
Thank-you Emu,
This material is burgundy velvet-teen. Dave I
#43 frash da bucket
frash da bucket
  • 1,890 posts
Posted 26 December 2012 - 11:05 AM
Wiper arms and blades are different too.
#44 _Bomber Watson_
Posted 26 December 2012 - 11:33 AM
All LC's had that.
#45 _stretchlc_
_stretchlc_
Posted 26 December 2012 - 01:22 PM
Different Accelerator Pedals
#46 _mikecatts_
_mikecatts_
Posted 26 December 2012 - 06:04 PM
69 to very early 70 LC had bump stops on the inner guard as to on front end.. Discovered that today.... and only 2 plates.. no compliance only body id and VIN... Both on LH side radiator support panel...
#47 _LONA-CK_
_LONA-CK_
Posted 27 December 2012 - 03:46 AM
stretchlc
that will depend on the year as this change came with the all aussie 4 speet from he opel in july 71
mikecatts
has these upper wish bones have square welded to them for the bump stops to hit and like the 1970 lc these 2 years dont have the seat belt bolts and triangle bracket welded in the rear parcel tray, but this is adr proved, like alot of the body changes.
and these points are the reason why i asked what year, has there are many changes between the parts and bodys of the lc and lj over the 4 years
the best way to do this is note the changes from 69-70 and then move to 70-71 and so on, i just aint got the time but if some one has a question just ask i dont mind answering them i just dont want to write a book
cheers gong
Edited by LONA-CK, 27 December 2012 - 03:53 AM.
#48 71xu1
71xu1
    Dave
  • 1,274 posts
  • Car:LC GTR XU1
Posted 27 December 2012 - 09:57 AM
lj doors also have a reinforcement panel welded into the top of the inner door frame where the inner belt mould (felt) attaches. Not sure when it was introduced.
Cheers Dave
#49 S pack
  • 15,717 posts
Posted 27 December 2012 - 10:09 AM
LC Torana have a chassis number pefixed with LC, LJ chasiss number is prefixed with LJ. :stirpot: :stirpot: :stirpot: :stirpot: :stirpot: :stirpot: :stirpot: :stirpot:
#50 frash da bucket
frash da bucket
  • 1,890 posts
Posted 27 December 2012 - 11:30 AM
Wiring harness is different
