How much $$ to build a strong 202
_sjp67m_
Posted 16 December 2012 - 10:16 PM
But how much would it cost to build a decent 202 ?
Obviosly with more power then standard but remember its a daily driver so it has to be within a reasonable budget :/
Posted 16 December 2012 - 10:37 PM
www.ebay.com.au/itm/370555436819#ht_1378wt_904
Edited by sibhs, 16 December 2012 - 10:41 PM.
Posted 17 December 2012 - 12:51 AM
A Standard 202 Short Motor ( Block ) is still a Strong Motor ( I have given them a Hiding ),
You can re-kit a 202 Bottom End for 500 Bucks, invest in a 30/70 cam and a Good breathing Head. Dave I
p.s. it is the labour charges that put the price up on your build.
p.p.s. There are 202 builds on this Site for sure.
_Quagmire_
Posted 17 December 2012 - 02:12 AM
horsepower is just a matter of $$$$ ....so how fast would you like to go?
what do you currently have?
and what condition is it in?
don't forget to factor in the added costs for a gearbox/diff if you go the chev route
the bango breaks behind standard 202's...a 350 will destroy it
_oldjohnno_
Posted 17 December 2012 - 06:04 AM
I like the look of this for $4000 delivered. Sounds like a good daily driver with that bit extra.
Keep in mind that it's basically just a long block, and to finish it off you'll need:
flywheel
balancer
fuel pump
dissy & leads
intake and carb(s)
air cleaner(s)
starter
alternator
extractors
All this can easily add up to another couple of grand. On a horsepower per dollar basis you'd almost certainly be better off with the smallblock, but some of us like the little sixes anyway.
_gmlj6_
Posted 17 December 2012 - 06:08 PM
Posted 17 December 2012 - 06:49 PM
Posted 17 December 2012 - 06:55 PM
Inlet opening and closing times. Old school way of measuring cams, not used anymore.
Posted 17 December 2012 - 07:15 PM
In just trying to decide what motor to go for in my hatch I know it's cheap to get a 350 crate motor
If you want a cheap, reliable and OK on fuel daily driver you can't beat an injected 304 conversion. Even cheaper if you run an auto like a TH350 or even the 4L60 from the donor car. Probably the cheapest and easiest conversion and hp uprgrade money can buy.
_oldjohnno_
Posted 17 December 2012 - 07:19 PM
what in the hell is a 30/70 cam?
Intake opens 30 BTDC, closes 70ABDC, or in other words 280deg duration. Used to be the thing to have in a street 186 in the 70's. That's how cams were classiified back then, I bet I'm not the only one here that used to call Bert Jones Racing Cams and order a 30/70, or a 36/76 or whatever...
Posted 17 December 2012 - 08:18 PM
I had better catch up with the new technology spec's - @.50 etc.
The old cams were simple grinds back then and when you say a 30/70 cam, it would be a normal cam lobe design.
These Day's as oldjohnno has explained to us, is that the shape of the lobe has different characteristics to make a valve perform. Dave I
p.s. I just said a 30/70 cam for street cam to use - it would also give good fuel economy with a breathing head.
_Emu_
Posted 17 December 2012 - 08:28 PM
As above, either an injected 304 or a carbed small block would be ideal. If you go the 202 I suspect you'll be over it within a month of it getting on the road and talking about a V8 conversion. Do it once, do it right.
Posted 17 December 2012 - 08:31 PM
Posted 17 December 2012 - 08:37 PM
Picture 12.png 378.77K 32 downloads
For $4K you can get a VN with injected 304 and a T700R4. Not much else of it will bolt in though.
Posted 17 December 2012 - 08:38 PM
Not everyone likes v8's.........Nor does everyone feel the need to put a v8 in absolutely every torana on the face of the earth.
Posted 17 December 2012 - 10:11 PM
as for 30/70 cams very gay you had to go the wade 40/80 full race cam that woke the little red up
_Emu_
Posted 17 December 2012 - 10:49 PM
Posted 18 December 2012 - 12:31 AM
I see you are playing Ball with us again,as for 30/70 cams very gay you had to go the wade 40/80 full race cam that woke the little red up
Wake the little Six up with a 52/ 90 11,000rpm knifed crank to scare your little mitts off
Posted 18 December 2012 - 12:42 AM
Should be able to get one for half that, if not less, if you only want it as a donor.
_Quagmire_
Posted 18 December 2012 - 02:19 AM
yep and in standard form they are doughy as hell at low revs...not as bad as a gen3 but still....Then another 5k to make it all fit if your half competent on the tools, 10 if your not.
i'd rather a crate 350 than the hassle and bs that goes with a 304 conversion..
#21
_oldjohnno_
Posted 18 December 2012 - 06:44 AM
I've got a bit of a soft spot for the little sixes, and in my opinion they are a natural fit for the little LC/LJs, whereas these to me look out of proportion with a V8.
The LH/LXs on the other hand look "right" to me with a smallblock V8, so long as it all fits under the bonnet. Especially a hatch with big rubber, it just seems a natural fit. At the end of the day it's all just personal preference I guess, but for me I'd be dropping an eight in the hatch.
#22
Posted 18 December 2012 - 07:56 AM
Cant beat LS power for the $$ these days.
or.....
put a 2J in it
#23
Posted 18 December 2012 - 08:02 AM
#24
_Quagmire_
Posted 18 December 2012 - 11:44 AM
he said cheap ......OP hasnt really come back with a budget?
or.....
put a 2J in it
i'd rather have a old school 350 ls1's look and sound plastic
and the bs involved fitting them is worse than a 304
seriously you'd spend 3k+ just on your mounts/sump/wiring and fuel system ...then you still have your motor/ box/donor car costs
and you still haven't looked at diffs
Edited by Quagmire, 18 December 2012 - 11:49 AM.
#25
_oldjohnno_
Posted 18 December 2012 - 12:17 PM
Bolts in - check
No engineering dramas - check
Compact and easy to work on - check
Unique sound - check
Compatible with banjo diff - check
Rips epic top gear skids - ch..... er....... I'll get back to you on that one
