14:1 Compression Pistons for 202 to 210
147 replies to this topic
#26 _Bomber Watson_
Posted 23 December 2012 - 08:33 PM
Thats because of the very different characteristics of methanol, nothing to do with the octain number or compression ratio...
#27 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 23 December 2012 - 08:39 PM
No arguement there, it was more a reply to the following comment:
as High Compression creates Hotter water
#28 _tryhard_
_tryhard_
Posted 23 December 2012 - 10:32 PM
methonal will run on anywhere from 10.5 till as much as you can create in a holden six, 14 to 1 I think your dreaming with a standard stroke 202. I fitted 245 hemi pistons into a 202 back in the 80's had to mill 135 tho of the top of pistons, bore the eye of the rod out .we shaved 235 tho of a 149 head fitted bedford truck valves ran a waggott 41 / 78 solid with a set of 45 webers and only had 13.5 to 1.
#29 _ljxu1torana_
_ljxu1torana_
Posted 23 December 2012 - 10:53 PM
my turbo 186 torana has 14.1 cr on full power.
#30 _Bomber Watson_
Posted 23 December 2012 - 10:55 PM
#31 N/A-PWR
  • 9,639 posts
Posted 24 December 2012 - 02:01 AM
Thank-you Vick, Bomber Watson, tryhard and ljxu1torana,
So now we have more information on the 14:1 CR subject to debate, as I see it now is if the original question was 14:1 cr static or dynamic compression pistons?
My guess it was static as the turbo-ed 186 proves the 14.1:1 dynamic cr at full power with the duration of the cam.
With the previous links to high cr's state to have a cooler combustion temperatures using cooler fuels, coated ( valves, combustion chamber and pistons ) which helps to keep the detonation further away, having said that, static 14:1 cr could well run on 98+ gasoline with the XU1 Cam's duration could well bring the dynamic cr to 9:1 ( that was a guess ).
I would also say that I achieved 250psi cylinder pressure using a 41/78 solid cam I bought from Rare Spares at the strathfield branch.
So here we are attempting to have a normally aspirated engine with a new comp high reeving 41/73 cam duration at a dynamic 9:1 cr.
If the cr was a dynamic 14.1:1 ( be like driving with a Turbo or supercharger on boost all the time ) then the static cr would need to be 17:1 or so which would need some serious components.
Now as questioned earlier, 14:1 static cr is difficult to achieve or was that 14:1 dynamic cr difficult to achieve?
I say this, if we had no combustion chamber and the cam had a short duration, the static cr would be through the roof.
So in saying that the static 14:1 cr is achievable somewhere in between. Dave I
#32 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 24 December 2012 - 08:06 AM
look at jag xjs lumpy tops and 253 lumpy tops as we looked at them years ago and they would fit but we never got around to building it.
#33 _gmlj6_
_gmlj6_
Posted 24 December 2012 - 11:46 AM
to me , it seems that, with the cam profiles and different fuels you can get like ms109 which is an oxygenated fuel or even things like q16, why would you need to try and get a comp ratio up to 14.1.
#34 _tryhard_
_tryhard_
Posted 24 December 2012 - 03:16 PM
If you are going to run that high a compression ratio on pump fuel get your dissy spun up to suit cam and don't go over 28 degrees all in timing at 4000 rpm about 18 in the dissy and 10 static on the crank this will save your motor.
#35 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 24 December 2012 - 05:31 PM
Hi Dave6179,
Yes, when I was reading the High Compression article I was thinking there is a lot of components to improve on,
and by the sounds of reducing the water temperature,
as High Compression creates Hotter water your engine should be at the right Temperature, if that makes sense. Dave I
I remember some ... OK, a lot, of years ago, I was inquiring info on plugs. A mate of dads had a book on plugs and stuff, as he was an old mechanic. The book said the 202 XU1 ran at 210 degrees, with Champion N11YCs. I'm using the equivalent of N9s, but I found N7s are better for performance, however... since fitting the HEI, the plugs I was told to use may be too hot as well.
#36 _stretchlc_
_stretchlc_
Posted 24 December 2012 - 08:03 PM
I think Jason was refering to the comp ratio being increased under boost Bomber, after all thats pretty much all a turbocharger does really!
Edited by stretchlc, 24 December 2012 - 08:04 PM.
#37 _ljxu1torana_
_ljxu1torana_
Posted 24 December 2012 - 09:39 PM
you are a good man there stretch.
#38 N/A-PWR
  • 9,639 posts
Posted 25 December 2012 - 01:05 AM
Hi lcxu105,
Great info there, I had a look around on Google with no direct results yet.
Thank-you gmlj6,
I guess I am seeing what the enginners were up to in the late seventies.
Great Idea's there tryhard,
I may not blow this thing up.
Yep Dave6179,
I just used N9Y's in the 186 head, but we are entering into a new field now - I had a Champion spark plug Mentor as he worked for them for the later part of his life - has passed now.
Great inputs here, now we need a strong bearing set to go with it. Dave I
#39 N/A-PWR
  • 9,639 posts
Posted 10 January 2013 - 10:09 AM
OK Readers,
I have come across this Write up Link about Compression if You would like to comment on:-
http://www.popularho...io/viewall.html
As it tell us more about compression in different ways.
ie - How good does your compression seal etc. Dave I
#40 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 11 January 2013 - 10:06 AM
I changed the thermostat to a 160 three days ago. Now runs up to 180, was getting up to 215 (everything is new and clean so must be something else making her run hotter), but does pull better! Just took it for a 200km trip yesterday, nearly 30 degree day, with all the family. Was pulling 160km/h (ssshhh) with ease, and loads more waiting. Was only 4000rpm/5th. Cam starts working at 3300.
#41 N/A-PWR
  • 9,639 posts
Posted 11 January 2013 - 10:20 AM
Hi Dave6179,
Great to see part of the Heating sorted, do you have a triple core radiator?
I use the V8 HQ as it has the hoses in the right place for the Six. Dave I
#42 N/A-PWR
  • 9,639 posts
Posted 11 January 2013 - 10:38 AM
p.s. when I was doing 80mph continually, the Six would over heat, after putting the V8 HQ Copper Radiator in, it was all fixed.
p.p.s. I heard the Aluminium Radiators are not good for cast iron Engines because of the Internal Flakes.
#43 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 11 January 2013 - 12:01 PM
Where your temp gauge goes into the head at the rear. Put in a t pice and run it back to the thurmastat houseing. will drop the temp a bit more and help the number 5 and 6 cyl. we use to run it to a mini radiator then back to the thurmostat houseing in the race cars and never had any heating problems what so ever. Even after 50 laps of holding it flat out only hit max of 85 deg.
P.S we also cliped the blades of the water pump to slow down the flow and only used a restrictor plat insted of a thurmostat.
#44 N/A-PWR
  • 9,639 posts
Posted 11 January 2013 - 12:04 PM
Great Information lcxu105,
Nice to see another way to deal with cooling, what size Radiator did you use?
#45 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 11 January 2013 - 12:51 PM
a filter would stop that
http://www.tefba.com/
#46 N/A-PWR
  • 9,639 posts
Posted 11 January 2013 - 12:56 PM
That is just what we need - thank-you Stinga.
#47 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 12 January 2013 - 11:04 AM
Hi Dave6179,
I do have a brand new V8 rad, had it in for a while to check it's performance... didn't make much difference. It's screwed to the shed wall at the moment, but after making more changes recently I might chuck it back in.
#48 N/A-PWR
  • 9,639 posts
Posted 25 May 2014 - 06:02 PM
Just Found these High Compression Piston Gems:-
Attached File  $_57.JPG   230.99K   3 downloads
http://cgi.ebay.com....em=281344861249
I wonder if we can use them in a 208ci as the Rods would need to be different. Dave I
#49 SA EH
SA EH
    Another Holden 6 tragic
  • 1,050 posts
  • Name:Jonesy
Posted 25 May 2014 - 06:53 PM
Have you considered 253 lumpy tops Dave?
#50 N/A-PWR
  • 9,639 posts
Posted 25 May 2014 - 06:57 PM
All New to me Jonesy,
I would LOVE to have Lumpy's in a Red 208. Dave I
or a Blue 208 Short Motor even
just need to know the How Too's
