14:1 Compression Pistons for 202 to 210
147 replies to this topic
#76 N/A-PWR
  • 9,637 posts
Posted 31 May 2014 - 08:07 PM
Just what I thought,
One way or another we can do it
#77 rodomo
  • 18,037 posts
Posted 31 May 2014 - 08:55 PM
Maybe 2 starfire heads could bolt on to 253 to solve the low comp issue?
The valley might get a bit busy though?
#78 N/A-PWR
  • 9,637 posts
Posted 17 March 2015 - 01:10 AM
After looking for more dome 3.685" pistons,
I noticed a lot of other pistons around 93.5mm or so to use,
so picked these ones:-
http://www.summitrac...p50mm/overview/
and for a bit more of a skim:-
http://www.summitrac...lp-h1103cp-75mm
apparently, if you have a revving motor, we should add another thousandth piston to bore clearance,
so the top one could be alright for a 208 bore ( 3.685" ),
or if a bit small, we can use the bottom one, and give the bore a bit more of a skim.
#79 warrenm
warrenm
  • 2,117 posts
  • Car:1972 LJ Torana
Posted 17 March 2015 - 05:44 AM
Without reading all 4 pages, what rods do you intend on using?
#80 _Bomber Watson_
Posted 17 March 2015 - 07:23 AM
Considering you wouldn't be able to use small chamber head with those slugs at zero deck havnt you gone backwards?
#81 hip6
hip6
  • 201 posts
Posted 17 March 2015 - 08:55 AM
Should be working for nasa....when's this rocket ship gonna be ready for take off.
Hope to see it in this lifetime....it'd wanna be worth it.
#82 N/A-PWR
  • 9,637 posts
Posted 17 March 2015 - 11:28 AM
Hello Warren, great pick-up,
I was looking for a Dome top piston, of the W73 Northstar Piston that Oldjohnno has in his Holden 6 bible, and here too.
http://www.summitrac...w/make/cadillac
and realize the pin diametre is smaller 0.866 in the W73, vs the 0.946, which is quiet a bit bigger, for the Eagle 5.710" rod.
Search is on.
Great point DJ,
I was thinking of my 0.100" shaved, 186 chambered head:-
Attached File  IMG_6608.jpg   62.26K   1 downloads
Had a bit of time to look around again.
Gave you a like button, for the hurry-up.
#83 N/A-PWR
  • 9,637 posts
Posted 17 March 2015 - 11:55 AM
Attached File  Chamber Piston Assembly.jpg   71.2K   1 downloads
#84 warrenm
warrenm
  • 2,117 posts
Posted 17 March 2015 - 11:15 PM
Small chambered head is what you need, not large.
#85 N/A-PWR
  • 9,637 posts
Posted 18 March 2015 - 02:42 AM
No worries Warren thank's,
same as what DJ said too, backwards,
but I am happy with this heads performance for the moment,
so I was just seeing what pistons were available to help out.  :banghead:
Question:-
How much trouble is there to close chamber a head from an open one?
Edited by NA-PWR, 18 March 2015 - 02:51 AM.
#86 warrenm
warrenm
  • 2,117 posts
Posted 18 March 2015 - 05:52 AM
No problem at all, if you have the gear to weld cast iron, machine head surface etc.
#87 _oldjohnno_
_oldjohnno_
Posted 18 March 2015 - 06:00 AM
I'm not convinced the open chamber isn't actually better at high rpms. The little chamber is great for midrange but I think it may have too much quench area for high rpms.
#88 SA EH
SA EH
    Another Holden 6 tragic
  • 1,050 posts
  • Name:Jonesy
Posted 18 March 2015 - 06:28 AM
Then wouldn't the open chamber head make Dave's hopes of achieving 14:1 seemingly impossible??
Surely he would have to use the closed chamber to get anywhere near his goal.
#89 _oldjohnno_
_oldjohnno_
Posted 18 March 2015 - 12:13 PM
That would depend on the piston I guess. Or whether you were prepared so sacrifice a little compression for a better burn and less pumping loss - I certainly would be.
#90 N/A-PWR
  • 9,637 posts
Posted 18 March 2015 - 06:00 PM
Thank's for the great info fellows,  :D
I need a piston like this:-
http://www.chevydiy....evy-big-blocks/
these type of pistons have off-set pins to counteract the balancing.
If I cannot achieve the 14:1 CR/DCR, so be it.
There may well be imaginary calculations in the 80's that caused me to think all this could be done,
but I appreciate everyone's efforts to sort something out,
whether it be 12:1/13:1.  B)
#91 N/A-PWR
  • 9,637 posts
Posted 18 March 2015 - 06:04 PM
oops, they did the 14:1 in the 70's, and I was told by the horses mouth in 1981.  :banghead:
:Headbang2:
:innocent:
#92 _Macca97_
_Macca97_
Posted 18 March 2015 - 07:29 PM
Toyota 1hz motor with some sparkplugs and 4barrel holley :P 14:1 comp
#93 _oldjohnno_
_oldjohnno_
Posted 18 March 2015 - 07:33 PM
The first thing I'd do would be to work out exactly how much CR I could run with the available fuel and cam. Then a quick mockup with a flat top piston to check valve to piston clearance, just so you know how much pad you can put on the piston. You wouldn't need a lot - a pad with an area of about half of the bore and 4mm high will displace over 13cc. You certainly wouldn't need anything as big and ugly as the BBC domes.
#94 N/A-PWR
  • 9,637 posts
Posted 19 March 2015 - 12:13 AM
Great Man Oldjohnno.  B)
Like button for you.
#95 TerrA LX
Posted 19 March 2015 - 08:03 AM
This would be the first port of call.
#96 _ljxu1torana_
_ljxu1torana_
Posted 19 March 2015 - 08:06 AM
hey gave if you want your 14.1 c/r go and buy i can of compression.lol.
#97 N/A-PWR
  • 9,637 posts
Posted 19 March 2015 - 11:21 AM
So far into the research for CR vs Fuel use, using a 274@50 cam, at 13:1,
looks like we can run low octane ( 91 ) fuel for the street ( lower rev range, non power band ), and high ( 112 ) octane for the track ( WOT ).
but as E85 is readily available at the Petrol bowser, converting the fuel system to run E85, is the all round solution.
E85 is 112 octane, and keeps the engine cooler.
#98 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 25 March 2015 - 12:03 PM
Thats a very long duration cam- is that the cam you are currently running or is this the cam you are planning on using?
What is your motivation for running such a large duration? You could run 12:1 with less duration and end up with a similar result (just less stuffing around). I am guessing to are into it for a challenge, but at the end of the day it may not quite give you what you expect...
Not trying to be a dampner- I love a challenge also, and can see why you are keen to see it through...
#99 N/A-PWR
  • 9,637 posts
Posted 25 March 2015 - 12:57 PM
Appreciate your post Justin,
My challenge is the RAT theme as you know, using the wildest bits and pieces that can be put together.
My idea started by recreating past events that worked, package them all, to create my last Torana build:-
- curious to see such a duration/combination run.
- need idle low as possible, 750rpm will sound nice.
- higher the compression, the Cam's powerband cuts in earlier, and E85 is more efficient.
- aim is 128kp/h in first gear, hoping to use 3rd gear at 60km/h, without jumping all over the place.
- another short motor when needed.
Thats a very long duration cam- and can see why you are keen to see it through...
#100 _ljxu1torana_
_ljxu1torana_
Posted 25 March 2015 - 06:33 PM
and 400 k/ph in second gear.
