60 degrees static ignition timing?
#51 _Bomber Watson_
Posted 03 January 2013 - 07:12 PM
#52 _Bluejinx202_
Posted 03 January 2013 - 07:25 PM
Do MSD make a 202 setup specifically or do u have to adapt one from a different engine?You can MSD up for half the price of ICE gear....Or less....Just sayin.
#53 _Bomber Watson_
Posted 03 January 2013 - 07:45 PM
Or you can use your current dizzy, or a points dizzy to trigger the gear, the pro billet is a lot easyer to adjust though.
Then pick your control box and coil and leads and your away.
Im running a pro billet, Digital 6 and a HCV2 coil with 8.8mm leads, all MSD, cost around $600 all up from memory. If you dont need the features of the digital six then you can get way cheaper boxes.
At theh end of the day with the pro billet theres no more paying someone to regraph it, you can do it on the water if you wish during a tuning session, simple as. money saved there.
Edited by Bomber Watson, 03 January 2013 - 07:46 PM.
#54 _Bomber Watson_
Posted 03 January 2013 - 08:16 PM
They make a nice HEI setup for about $200 or so....
#55
Posted 03 January 2013 - 08:28 PM
11X12 is 11 inch diameter and 12 inches of pitch.
Isn't the pitch the theoretical distance the bost will travel with one rotation of the prop?
#56 _Bomber Watson_
Posted 03 January 2013 - 08:29 PM
#57 _tryhard_
Posted 03 January 2013 - 08:30 PM
#58 _STRAIGHTLINEMICK_
Posted 03 January 2013 - 08:38 PM
#59 _Bomber Watson_
Posted 03 January 2013 - 08:55 PM
#60 _Bluejinx202_
Posted 03 January 2013 - 09:41 PM
It is a steel one. I actually brought this up with Jerry my ignition man the other day.... I take it you would prefer a plastic one?Something else i just thought of, are you running the steel or nylon drive gear?
#61 _Bomber Watson_
Posted 03 January 2013 - 10:25 PM
Holden fitted a plastic gear for a reason. Holden never fittted a steel gear to a distributor.
#62 _Viper_
Posted 04 January 2013 - 12:22 AM
#63 _Ned Loh_
Posted 04 January 2013 - 07:04 AM
#64 _oldjohnno_
Posted 04 January 2013 - 08:09 AM
Edited by oldjohnno, 04 January 2013 - 08:13 AM.
#65 _Ned Loh_
Posted 04 January 2013 - 09:21 AM
There's no need for a hotrod ignition to get to 6500. As Mick said the factory HEI will do it easily if it's in good condition, even plain old points 'n coil will do it. The steel gear seems to be ok with points (I'm guessing the drag from the points has some dampening effect) but use a plastic gear with the Bosch HEI. Steel gear also seems to be OK with the Delco to over 7000. But I'm pretty sure there's more than just a wrong dissy gear stopping it from pulling rpms.
Yes exactly.
Oldjohnno, any experience (road/dragstrip/dyno/flow bench) with X2 cast headers?
#66 _oldjohnno_
Posted 04 January 2013 - 02:22 PM
Yes exactly.
No, but I'm sure they'd flow well enough to handle this sort of output even if they aren't the absolute optimum. I'm still not convinced it doesn't need an inch or two less prop pitch (as opposed to merely grinding the prop down, which would have an effect more like slipping the clutch than changing the diff ratio) but the only easy way to tell for sure would be to dyno it to see whether the problem is [A] the prop isn't allowing the engine to reach the power peak or [B] the torque and power curves are falling off prematurely. If it's [A] you'd change the prop; if it's [B] you'd fix the engine. And once you knew the output you could work out within very close limits just how fast the boat should go.
Edited by oldjohnno, 04 January 2013 - 02:24 PM.
#67 _Bomber Watson_
Posted 04 January 2013 - 07:19 PM
Much like a torque converter.
#68 _Bluejinx202_
Posted 04 January 2013 - 08:54 PM
Really wish it were that easy. Every boat is a little different. Weight, shaft angle, hull efficiency, engine power bands all make for a different result.Plus from what i gather an engine dyno sheet is very very usefull when it comes to getting a prop.....Select prop supplier, fax dyno sheet, ring through credit card details, wait by mailbox for perfect prop....
Just to show you guys that I'm listening though, I'll do some ringing around on monday and see if I can get hold of an 11X11 prop and I'll report back in a couple of weeks.
Where can I get a new plastic gear for my dissy?
#69
Posted 04 January 2013 - 09:00 PM
#70 _Bomber Watson_
Posted 04 January 2013 - 09:42 PM
Oh yeah, forgot about that, same as vehicle details make model weight engine diff ratio bla bla bla bla.....
TBH i have no idea where you buy dizzy gears, i have lots of second hand ones lol.
#71
Posted 05 January 2013 - 07:19 AM
Yep, i've seen the steel gears cause stray spark at higher rpm's several times.
Yep, and they advised dealers to replace them, where required, with iron gears for a reason too.
Erratic engine performance, misfiring and engine pinging.
Edited by S pack, 05 January 2013 - 07:20 AM.
#72 _Ned Loh_
Posted 05 January 2013 - 03:44 PM
Bomber - buy NEW gears. Don't ask me how I know that.
#73 _Ned Loh_
Posted 05 January 2013 - 03:48 PM
Would make sense to see if you can borrow a prop or two and test. What sort or RPM change would you expect from a one inch change in pitch?
#74 _Bluejinx202_
Posted 05 January 2013 - 04:02 PM
Probably about 4-500 rpmWould make sense to see if you can borrow a prop or two and test. What sort or RPM change would you expect from a one inch change in pitch?
I know a few people with boxes of props to use but I only found one bloke that did get an 11X11 but he didn't find that it get traction and reach good speeds so he had it re pitched to 11X12 (you can only put pitch on not take it off, without ruining the blade shape if more than 1/2") ill order one and if it doesn't work out I'll do the same and pitch it up and keep for a spare.
#75 _Ned Loh_
Posted 05 January 2013 - 04:14 PM
