quietening exhaust - without changing pipes or muffler
#1 _the gts_
Posted 30 December 2012 - 12:34 AM
Has anyone tried different ways of quietening the exhaust without changing the pipes or mufflers?
I have 3" pipes and was thinking of restrictor plates under the carb or in the exhaust.
I already have what i call 'bullets' inside the pipe. they are 2" diameter thick mesh filled with steel wool. They seem to work ok but are still not enough.
Any thoughts on the difference between steel mesh & fibreglass??
Obviously this is all for legal reasons
#2 _434LX_
Posted 30 December 2012 - 09:52 AM
Posted 30 December 2012 - 10:05 AM
You block as much of the diameter as possible without making the car too poorly running to get to the testing station.
Multiple flanges mean you can add multiple plates.
I found covering half the area of a twin 2.5 inch system (each pipe, one spot each side) prior to the rear muffler took 8db off the noise test result.
Still drove okayish and got the job done.
#4 _red roar_
Posted 30 December 2012 - 11:49 AM
Do exactly what Rexy has suggested, works a treatAt the flanged sections you add in thin plates - I made mine from aluminium sheet lying in the shed.
#5 _shan620_
Posted 30 December 2012 - 06:50 PM
#6 _the gts_
Posted 30 December 2012 - 07:13 PM
Ball valves with actuators on would be ideal Andy, you could tune it, 3" valves from the clave ar a little big though!
Posted 30 December 2012 - 09:30 PM
#8 _The Baron_
Posted 30 December 2012 - 10:05 PM
#9 _V6 UC_
Posted 31 December 2012 - 01:43 AM
#10 _the gts_
Posted 31 December 2012 - 03:50 AM
My internal pipe has been reduced to about 2" each side and the engine had to be retuned quite a bit to get it to run.
The 'bullet' is about 6" long, the end is blank but the sides are thick mesh, its actually 'wedge wire' if anyone knows what that is.
Yes I was considering fitting another set at the flange after the muffler.
What is better at sound deadening, fibreglass or Steel wool? I was thinking maybe fibreglass
Posted 31 December 2012 - 08:16 AM
#12 _the gts_
Posted 01 January 2013 - 04:59 AM
That was at approx 3-5m away and at the time but I cant remember the exact set up or the difference between bullets and no bullets and didnt have a tacho connected at the time.
I will be testing again next time I am back in Oz but pretty sure that it is still way too loud.
#13 _V6 UC_
Posted 01 January 2013 - 05:29 AM
#14 _the gts_
Posted 01 January 2013 - 10:09 AM
Posted 01 January 2013 - 11:57 AM
Moderately big cam (232 duration at 50 thou hyd roller)
Tested as per testing proceedure regulations. Engine rpm varies depending on the vehicle/engine being tested. 3600rpm in my case.
Microphone in regulated test position.
Initially 105db.
Plates got me to 97db. Bit of extra fiddling got me to the regulated allowed 96db.
Was clearly quieter at steady test rpm than on backoff, a common pattern according to the testing bloke.
#16 _Viper_
Posted 01 January 2013 - 12:29 PM
If you had a mechanical secondaries carby would it make it quieter to disable the secondaries?
#17 _Bomber Watson_
Posted 01 January 2013 - 03:02 PM
#18 _oldjohnno_
Posted 01 January 2013 - 03:11 PM
Holding an engine at half throttle no load and no rev limiter will likely cause it to rev untill the valves come out of the rocker covers Clint.
True, but you have to admit that once that happens they become beautifully quiet.
Ah, the tranquility....
#19 _Viper_
Posted 01 January 2013 - 04:54 PM
#20 _Bomber Watson_
Posted 01 January 2013 - 05:37 PM
TBH i think it varies greatly state to state and who is testing it and how much they dislike you and your car, as with most things.
#21 _V6 UC_
Posted 01 January 2013 - 05:48 PM
#22 _434LX_
Posted 02 January 2013 - 08:41 AM
#23
Posted 03 January 2013 - 06:55 AM
And, it matches my tail lights and the recess in the bumper! Just a fluke that bit.
Edited by Dave6179, 03 January 2013 - 06:56 AM.
#24
Posted 13 January 2013 - 02:37 PM
#25 _cruiza_
Posted 13 January 2013 - 02:46 PM
