I believe you've still missed the Tridon reps point about pressure.
Would you like to point it out then, it would appear to me that his definition of pressure was just making sure it was completely immersed.
Posted 04 January 2013 - 06:43 PM
Posted 04 January 2013 - 06:48 PM
Posted 04 January 2013 - 06:55 PM
Posted 04 January 2013 - 06:56 PM
The way Understood the rep's conversation was that he meant that the Thermostat has to be under Pressure ( ie pressure pushing on the Thermostat and being fully submersed)
Posted 04 January 2013 - 06:59 PM
How much increase in pressure is going to be achieved by submersing it in a couple of inches of water???
None.
Posted 04 January 2013 - 07:16 PM
Posted 04 January 2013 - 07:19 PM
Posted 04 January 2013 - 07:22 PM
Edited by 76S.L.R, 04 January 2013 - 07:22 PM.
Posted 04 January 2013 - 07:38 PM
Yes not much, but just trying to make some sense of what the "mechanic" was trying to say as any other interpretation is bs.
Posted 04 January 2013 - 07:40 PM
Posted 04 January 2013 - 07:41 PM
Ok, so were there any indications that this presumed overly hot running condition was evident in the small amount of driving done immediately after the head gaskets were re[placed?
The reason I ask is, it is quite easy on the 253 & 308 to inadvertently install an inlet manifold to cylinder head gasket the wrong way around and block off the water passage from one of the heads to the manifold. Been there and done that myself. Spent hours and hours trying to work out why the damn thing was running so hot and it was the last thing we thought to check.
Posted 04 January 2013 - 07:43 PM
Posted 04 January 2013 - 07:53 PM
Posted 04 January 2013 - 07:55 PM
Just because a pot of water boils at 100deg C does not mean it wont continue to heat after boiling if heat is continually applied.
Posted 04 January 2013 - 08:00 PM
I reckon it's worth checking the above just to be sure.
Edited by 76S.L.R, 04 January 2013 - 08:00 PM.
Posted 04 January 2013 - 08:02 PM
Yes, but, air is not a good conductor of heat, ...
Posted 04 January 2013 - 08:07 PM
As an example let's look at the thermostat for a VS V6. It has a rated opening temp of 89 - 93 deg C and a fully open temp of 106 deg C.
We know that water boils at 99 deg C at atmospheric pressure, so testing the VS thermostat in a pot of boiling water is not going to open it up fully.
So how can we get the temp of the testing water up to 106 deg C or higher without reverting to using a liquid that has a boiling point higher than 106 deg C???
Pressure to raise the boiling point of the water so that a temp of 106 deg or more can be achieved.
I'm sure that is what the Tridon rep was alluding to when he commented that you need pressure, cause you won't get the thermostat to open fully in boiling water
Edited by torbirdie, 04 January 2013 - 08:16 PM.
Posted 04 January 2013 - 08:52 PM
I appreciate the info on the v 6 thermostat, but show me any workshop anywhere which has a pressurised vessel( with a glass lid)to test thermostats........rofl, I don't think the mechanic meant testing them in this fashion.
Regardless the OP was enquiring about a stat that was rated for 82C. If its not fully open before boiling there is something wrong with it and indeed find it hard to believe that he would think that it would need to be heated beyond boiling to fully open.
Just a minor point, water boils at 100C at 1 atm, did you have a crush on Barbara Feldon or something.........
Op: bubbles don't sound good, but have you been for a spin yet?
Posted 04 January 2013 - 09:02 PM
I was hoping to not start pulling the motor to bits, but if it still overheats now... then I'll have to assume the inlet manifold Gaskets are indeed the Wrong way around or Head Gasket's are stuffed as ive replaced everything else....
Posted 04 January 2013 - 09:34 PM
Edited by 76S.L.R, 04 January 2013 - 09:46 PM.
Posted 04 January 2013 - 09:45 PM
Posted 04 January 2013 - 10:03 PM
Posted 04 January 2013 - 10:05 PM
I put the one on that came with the Radiator, though it looks to be cheap assed shit?Have you tried a new radiator cap, make sure the system comes up to pressure.
Posted 04 January 2013 - 10:11 PM
Posted 04 January 2013 - 10:20 PM
After you take it for a drive and get it hot are the radiator hoses tight, like the system has pressure in it.
